Oct 17, 2004, 07:51 PM
Plane speed /prop pitch/ RPM formula??
Sorry I'm rather mathmaticly challenged. Could someone tell me how to calculate theoretical plane speed from a give prop at a given RPM??
Oilman.
Oct 17, 2004, 08:16 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Pitch speed = RPM x Pitch x (60/63360)
eg: 8000rpm x 6" x (60/63360) = 45.45mph
The 60/63360 converts from inches per minute to miles per hour.
Plane speed can be anywhere from ~80% to ~95% of pitch speed depending on a whole host of variables including p-factor (prop efficiency), airfoil shape, size, weight, construction materials, yada, yada, yada.
Good luck!
Latest blog entry: DIY Benchtop CNC
Oct 17, 2004, 08:19 PM
thnks Mark.
Mar 04, 2009, 01:06 PM
Night flier
well according to my calculations. my prop will b traveling at about 165!!!!! MPH,thats crazy lol. i will b using a 5x5 prop with a mega 16/15/4,and a 4s lipo lol. will b in a slipstream wing. so its goin to b fast......! Cant wait to get it built. going to b a handful lol
Mar 04, 2009, 01:19 PM
Space Coast USA
hoppy's Avatar
A high reving high pitch prop on a piper cub will still make it fly like a piper cub. The plane has to be "fast" designed to take advantage of high pitch speed power plants.
Your slipstream would fit in that Fast category! Have a ball.
Mar 04, 2009, 02:54 PM
Dr Kiwi's Avatar
Sorry, but you won't get pitch speed that high: 2200Kv x ~14v (under load) = 30800rpm. But you can't get Kv x V with a prop on, so reduce that to 85% of Kv x V...26180rpm
Now do the pitch speed calculation: 26180 x 5/1056 = 124mph.
One other suggestion - get a 5x5 EMP prop rather than the lousy 5x5 APC E or better yet use a Zagi Carbon 5.1x4.9.
Mar 04, 2009, 05:13 PM
vintage1's Avatar
Pitch alone isn't enough. You need to calculate plane wetted area (wing area mostly) L/D ratio, and profile drag, to get the drag versus speed curve, and make a power versus speed curve.
That tells you how much power you need..
Then prop for a pitch speed about that speed.Most props work best at the 'geometrical pitch speed' - they actually still produce lift and thrust at almost zero angles of attack. And that is where they are most efficient too.
If you are building a slender racer, ultimately wing area dominates the drag equation.
Mar 04, 2009, 08:42 PM
OFF TOPIC POSTER
Thread started in (04) WOW but is it in a solid or gas state? Robert
Mar 22, 2009, 07:15 PM
mike early's Avatar
where's the online calculator for this?
Mar 22, 2009, 10:43 PM
Space Coast USA
hoppy's Avatar
Try this one for kicks -
http://flbeagle.rchomepage.com/softw.../webocalc.html
Aug 19, 2012, 11:42 AM
hi.. my ques it that.. if suppose due to the repulsive forces at the tip of the fan, a fan rotates.. how do i calculate the speed rpm of the fan with the given repulsive force.. could u help me out with formulas..
Nov 28, 2012, 09:20 AM
markr7737's Avatar
http://brantuas.com/ezcalc/dma1.asp
try this
Nov 28, 2012, 12:26 PM
manuel v's Avatar
You can use my Convertidora.
https://www.rcgroups.com/forums/show....php?t=1191623
Conversiones.
De Pulgadas a Centimetros.
De centimetros a Pulgadas
De gramos a Onzas
De Onzas a Gramos
Pies cuadrados a Decimetros cuadrados
Decimetros cuadrados a Pies Cuadrados
Pies cuadrados a pulgadas cuadradas
Pulgadas cuadradas a Pies cuadradas
De kilos a libras y onzas.
Calculo de KV Ratio
Duracion de bateria
Velocidad del modelo
Velocidad de perdida. Con datos en sistema Imperial y Metrico.(corregida)
Area para DF,
Para servos de oz a kilos.
Calculo de empuje para helices 2,3,4 y mas palas.(no muy confiable) en proceso de corregir.
de Centigrados a Fahrenheit.
Proyeccion de consumo de Ampers de 2s lipo a 3s, 4,5,6,7,-10S lipo.
Con formulas para el Kv y lectura del Drill press.
Nov 28, 2012, 06:25 PM
Jack
jackerbes's Avatar
The Calculator page at flybrushless.com has a pitch speed calculator that works fine:
http://www.flybrushless.com/tools
For flying speed estimates I knock off 30% for draggy builds and 20% for the sleekest. If I want to know the real speed I send my eLogger for a ride with the GPS module attached.
The sell a pitot tube type air speed sensor for the eLogger too, I don't have one of those and they are much more complicated to install.
The drag is just too much of a variable for you to get anything but an approximation, if you really want to know you have to measure it.
They also have doppler effect speed interpreters you can put on a hand help cell phone too. Those listen to the inbound plane to estimate the speed. They don't work too bad I hear.
Jack
Nov 28, 2012, 06:29 PM
Police radar guns work OK
How to calculate thrust, given RPM, prop pitch and prop diameter? Hogster Power Systems 19 Sep 25, 2014 09:15 PM
Discussion Stall Speed, Prop Pitch Speed,..what's the sweet spot? Rob Schaffer Modeling Science 2 Nov 28, 2006 11:26 AM
Prop pitch x Speed Hamilton Neves High Performance 3 Jun 10, 2005 03:54 PM
Prop pitch speed and static thrust dvint Electric Plane Talk 15 Jul 17, 2002 10:13 AM
