2 New AC/DC Chargers From Thunderpower
Thunder Power has added a new line up of chargers that replaces their previous products. There are 2 new chargers to choose.
ThunderPower releases a new charger line up for charging single or multiple batteries.
Thunder Power has added a new line up of chargers that replace their previous chargers. At this time they have 2 new ones to choose from. The TP610HVC is the smaller of the two, and offers a simple and safe form of charging for the beginner. The TP610HVC is a single port 10A capable AC/DC charger that packs a punch for a small economical charging device at only 130mm x 115mm x 61mm in measurement.
The bigger of the 2 chargers is the TP4X610HV, and this is pretty much the 610 X 4 in one package. It comes in at 220mm x 240mm x 68mm in size and that is not too bad considering you can do 4 times the charging. Both chargers are compatible of charging up to 6 cell Li-Po, Li-Fe, Li-HV batteries, but the TP4X610HV is also capable of charging Li-Ion. Both chargers also handle other cell types like Ni-MH, Ni-Cd, and Pb batteries.
For more information on the new TP charger line up click here.
TP610HVC Specs:
  • AC Input voltage: 100-240V
  • DC Input Voltage: 11-18V
  • Charge power: 100W Max
  • Discharger power: 5W Max
  • Charge current range: 1-10A
  • Discharge current range: 1-2A
  • NiCd/NiMH battery cell count: 1 - 15cells
  • LiPo/Li-ion/LiFe battery cell count: 1 - 6s
  • Pb battery voltage: 2 V - 24V
  • Weight: 380g
  • Dimensions: 130x115x61mm
TP4X610HV Specs:
  • AC Input voltage: 110V or 220V
  • Charge power: 4 x 100W Max
  • Discharger power: 4 x 10W Max
  • Discharge current range: 1-5A
  • NiCd/NiMH battery cell count: 1-15
  • LiPo/Li-ion/LiFe battery cell count: 1-6s
  • Pb battery voltage: 2V-24V
  • Digital Power: 3V-24V
May 01, 2017, 02:39 PM
Heligamist
BrokeDad's Avatar
I'm still using my TP610C. The thing is just super reliable. Nice to see them updating it with new models.
May 02, 2017, 09:24 AM
Wrecking Ball's Avatar
do they have IR meter?
Aug 09, 2017, 09:03 PM
Manual says it does IR but it doesn't. Menu does not match Manual and IR is not there. Emailed this to TP and got no answer.
Decent add to my charger but seems lacking compared to other chargers.
Discharge rate is max at .3 amps. Awfully slow process at that rate.
Jan 08, 2018, 01:54 AM
got this charger the manual says there is supposed to be a USB connection for computer control and IR meter function but nothing.
and this thing is awfully loud!!!!!! sounds like a EDF jet on my desk!
TP support is non existing!
this is the same thing as the Horizon Dynamite DYNC2050 so nothing new here
Apr 18, 2018, 09:54 PM
Based on current prices, you would be better off buying four TP610HVC's and paying an extra $10 for the group. Then you get the USB port, the ability to update firmware, and IR.
Oct 02, 2018, 08:32 PM
can you put a DC power supply for more power on the tp4x?
News Hitec X2 AC Pro 2 Port AC/DC Multi-Charger ndfly700 Electric Heli Talk 19 Dec 24, 2016 11:20 PM
Discussion Charging NiMH With ThunderPower 610 AC/DC - How To? David Wile Batteries and Chargers 2 Nov 18, 2016 04:25 PM
Discussion Hitec X2 AC Pro 2 Port AC/DC Multi-Charger Internal Resistance Meter jonnied1 Batteries and Chargers 0 Dec 10, 2015 06:38 AM
Help! Can I use a AC to 12V DC Adapter on a charger that normally uses an AC to 6V DC Adapt tlandon1955 Batteries and Chargers 5 Nov 16, 2015 06:40 PM
Discussion thunderpower ac/dc or passport ultra ac/dc scratchnbell Batteries and Chargers 18 Sep 16, 2010 09:58 AM
