Apr 28, 2017, 04:19 AM
FrSky-MKT
New Product
FrSky volunteer application - New R9&R9M long range RC system test!
Progress Update 20170628
Hello everyone, thank you for your patience! Our long range system R9&R9M is ready and we will contact the testers who are chosen, but first round test will be held only for FCC users. The second round will come soon and I will update the information for you.
Progress Update:
We apologize to everyone who actively participate in this event, due to the problems of this long range system, we still need some time to improve the hardware and software. So the event will be delayed, please be patient and we will update the information in time. Thanks for yours understanding.
Volunteer: Please leave me your message if you want to help us to test samples
More detail information here: https://www.rcgroups.com/forums/show...ange-RC-system
Overview
R9 Receiver
R9M Module
Features
  • 900MHz working mode ( 868MHz for EU areas )
  • Two auto-detected modulations of PXX or CPPM
  • Light weight combination
  • Long range ( 1.5KM@10mW and 10km@1W or farther ), low latency and high precision RC system
  • 4 optional RF power from 10mW to 1W (10mW/100mW/500mW/1000mW )
  • Self-healing ACCST frequency hopping link
  • Smart Port enabled, realizing two-way full duplex transmission
Retail Price (Tax Excluded): Name: {62C52BC2-DF16-49F6-8F7E-D87566A8070A}.jpg
Description:
Apr 28, 2017, 04:31 AM
Carbo (-nator) ;-)
Here is an example of my low-altitude-RSSI-test with X4R and GPS and 3d-distance.
I am interested in testing the long range equipment too.
Apr 28, 2017, 05:28 AM
Snappy FPV // Flying Fischkopp
snappyhh's Avatar
sure ... like to participate
Apr 28, 2017, 05:40 AM
I am also interested in testing the long range equipment too.
Apr 28, 2017, 10:29 AM
I would also be interested If still a place is free ;-)
Apr 28, 2017, 02:54 PM
fchansa's Avatar
I am also interested in testing the long range equipment.
Have a large open area @ the baltic sea - perfect 4 long range FPV AND LOS.
Can compare to existing TBS XFire.
Apr 28, 2017, 05:13 PM
I would do it, I have much experience with UHF R/C I'm a ham since 1979.
Apr 29, 2017, 02:36 AM
I would like to know how long the battery with the Horus holds.
You sure since you can pull 1W out of the?
If I use crossfire, I can max 500mW, otherwise it starts strongly to buzz. At 500mW light buzz. So i need to use repeater and extern Lipo.
I would already be interested in how this works without them.
Apr 29, 2017, 04:58 AM
Hi, i'd like to test this. Living in the EU so i can test the EU frequencies for you.
Apr 30, 2017, 10:42 AM
Hi, I would like to give a try to your long range system. I have done a few reviews of 2.4 GHz radios and receivers. You can check the entire list of items I reviewed on my RCGroup Blog Post.
Currently Im using my Taranis with a L9R receiver. This new long range system looks like a response from FRSKY against other systems like TBS Crossfire. Looking forward to see the outcome, let me know if you need some help!
May 02, 2017, 03:58 PM
How do you manage 900 and 868Mhz with one module? Normally those frequencies require seperate modules else the sensitivity decreases when using for other frequencies. Or are there seperate modules available for EU and US frequencies? Or how can you set which one to use?
May 03, 2017, 01:21 AM
Count me in. Located in EU.
@rangarid, why do you think sensitivity would decrease ?
Is like switching from 5.6G to 5.9G in the video band, about 3-4% shift, did you seen any report stating that a certain channel is optimal in 5.8G ?
Though, obviously the antennas should have different tuning for 868/900.
May 03, 2017, 03:52 AM
Most of the common 868 and 900Mhz RF modules i know support both frequencies, but if you for example use the 900Mhz rf module it has a better sensitivity when using for that frequency and the sensitivity decreases the more you move away from that frequency.
For 5G WIFI and so on you wont move too far away (distance) anyways so range does not matter much there. But on a long range RC system it matters... Most of the 5G video transmitters have too much power anyways so range should not be a problem with good antennas. But on 10mW the sensitivity is very important.
May 04, 2017, 09:35 AM
Registered Slopeaphile
awmeade's Avatar
Hi Andrea,
Yes please - I'm very interested to work with you in testing this new unit. Andy, based in the UK.
May 05, 2017, 02:38 AM
Proud to eat Kraut ;-)
Julez's Avatar
I'd love to do a test as well. I'm located in Germany, and I like to try out new stuff with a bit of expertise:
https://www.rcgroups.com/forums/show...hardware-hacks
New Product FrSky New Arrival R9&R9M long range RC system AndreaHuang FrSky 5284 Today 02:44 PM
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14451 Jan 08, 2019 09:04 AM
New Product NEW RLink 433 Long range UHF system flymaesky FPV Equipment 1 Feb 17, 2018 04:28 PM
Discussion Comparative Range Test Data on Various Systems (Long Post) Mel Duval Radios 62 Jun 17, 2015 02:27 AM
