Pretty much ready for maiden flight!
One of my motors needs to be replaced, but should still work for a couple sessions i hope.
Somewhat tricky build due to you need to use some specific parts to work with available space.
I decided i wanted this frame so i could easily mount my runcam2 hd cam. BUT when the runcam2 is mounted, it does not appear that im gonna be able to run 5inch props which i kind of a bummer... :/ Without a runcam2 on the back it will easily run 5inch props. I will be running Q4040 dalprops on my racerstar 2205 2300kv motors. they seemed to be nice on my 195 kim setup but i didnt use a runcam on that build...
I ended up getting new foxeer arrow ccd 2.5mm lens. It has voltage osd which is nice. I was gonna try a much cheaper cmos cam kinda like a fatshark cmos cam, but the connector was at the bottom and there is hardware right where the connector is which would be snapped off on a crash most likely... the foxeer connector is at the top.
The TBS Unify vtx i used has U.FL connector which is good bc less chance of vtx damage if/when antenna lead gets yanked (it will pop off instead of rip off). I used a 10mm lead with 90degree sma connector i believe. the flat backside of the TBS VTX i have allow it to fit in the mix pretty well. I also picked up a dipole antenna i can connect via UFL connector if i decide to lighten my load a bit.
(better pics soon/smudged lens :/)
