Apr 25, 2017, 04:06 PM
Ianda217's Avatar
Alternative to epoxy/glass finish?
Has anyone ever used Sadolin PV67 as a finishing medium with glass cloth (instead of using epoxy)?
Apr 27, 2017, 07:47 AM
San Antonio TX.
sensei's Avatar
I have not used Sadolin PV67, but I have used a great deal of Minwax oil based urethane for applying 3/4 oz. fiberglass cloth over balsa wood as a finish medium, works great and easy to apply.
Bob
Apr 28, 2017, 11:33 AM
Ianda217's Avatar
Thanks Bob. I am building a big SR 71 (https://www.rcgroups.com/forums/show...-12-Scale-SR71) and one of my clubmates said that he uses Sadolin P67 instead of epoxy. It certainly seems easier to use and dries much quicker. I was looking for a second opinion on it. Looking through this forum, there is lots of water based PU but it doesn't go well with balsa.
Ian
Apr 28, 2017, 02:17 PM
A while back I saw a video of a product called Skinny Dip, haven't heard anymore about it since though, has any body tried it, and if so what were the results? It was a brush-on product that left a fairly durable finish for painting.
bhady
Apr 29, 2017, 09:13 AM
Play that funky music right
kenh3497's Avatar
"Sadolin PV67 Heavy Duty Varnish is a two-pack varnish"
Sounds like it is still a product similar to epoxy if you need to mix two components. In my book it is hard to beat epoxy for this application. With that said, some of the pattern guys that still build have been using silkspan with lacquer. Glass cloth could be substituted for the silkspan. Lacquer from the big box store can be used. I did a test on lacquer over cloth and it performed just fine.
Ken
EDIT: RE reading the Sadolin product info. It IS catalyzed lacquer.
Apr 30, 2017, 08:44 AM
exf3bguy's Avatar
Is there a problem with using epoxy?
Apr 30, 2017, 02:36 PM
San Antonio TX.
sensei's Avatar
There is no problem using epoxy from my standpoint, it is just much easier to use Minwax oil based single component urethane as the matrix to attach the glass to the surface. There is no mixing, no pot life to think about and no waste, it is very light, it permanently seals the balsa and kills the swell back from showing through the topcoat. That is about the most you can ask for from a single ply of 1/2 oz. or 3/4 oz. glass. Strength is not in question here because there is no strength worth mentioning in a cosmetic ply like what we are talking about.
Bob
Apr 30, 2017, 05:30 PM
Ianda217's Avatar
For me, the main attraction of something like the Sadolin product is the relatively short drying time. I don't mind mixing the two components, it's the waiting at least 24 hours before I can handle the parts again that bugs me.
May 01, 2017, 05:55 AM
San Antonio TX.
sensei's Avatar
By the way, I looked at your project of the SR-71. Very cool!
Bob
May 01, 2017, 07:52 AM
exf3bguy's Avatar
I always have laminating resin around for layups and to make up paste adhisive so it just makes sense for me to grab what I already have. Most systems have multiple hardeners avalilable. In most cases I can lay down one side and after a couple hours it's ready to trim and lay down another sheet of glass. As always many ways will work.
May 01, 2017, 10:30 AM
Ianda217's Avatar
Bob,
Thanks. I'm really enjoying the build although when the actual building is done, it's going to need more sanding than anything I've ever done before. I'm hoping for lots of dry weather so that I can sand it outside.
Exf3bguy,
Most of my previous models have been built up structures - WW1 and the like so I haven't done a lot of glassing. I'm looking for something that will make the job quicker and/or easier but will give similar results. One problem over here is that our average summer temperature is less than 65 degrees which does not make for rapid curing.
May 01, 2017, 03:35 PM
Rather than the Sad-olin Floor varnish .. Try some Eze Kote from Tower hobbies. for glassing your model
Much better than Miniwax polyU.
Water soluable :_) thicker, applies Much easier, dries faster /harder and is sandable within the hour .
Sans the Weight , Sticky Mess or toxicity issues with using Epoxy. Once tried, few revert to the Goo.
Yes not quite as strong, being only 90% of epoxy on glass cloth.... 10% seems a Very small price tough :-)
May 02, 2017, 05:22 AM
San Antonio TX.
sensei's Avatar
Yes sir, as always, you are a wise man my friend.
Bob
May 02, 2017, 05:47 AM
San Antonio TX.
sensei's Avatar
I just get a good laugh when guys talk about strength in the same sentence with the utilization of a single ply of 1/2 oz. or 3/4 oz. glass applied as a surface prep media only. I mean you just have to wonder about their credibility on any level after that. Now if we are talking about a structural layup with multiple plies, or even a single heavier structural ply, then an epoxy matrix is the only way to go! At least in my opinion, and you know what they say about opinions...
Bob
May 02, 2017, 10:43 AM
Ianda217's Avatar
Bare,
I've used Eze Kote on an Avro Vulcan that I built a couple of years ago. It was certainly easier than epoxy but, because of the water base, it warped some of the sheeting on the wing. As a result, I'm trying to avoid water based finishes.
Discussion Sagitta fuse finish? paint/covering/glass steener Sailplane Talk 38 Nov 07, 2015 01:49 AM
Discussion Alternatives to glass cloth epoxy fiberglass while retaining strengthening propertie? napOfTheEarth Composites Fabrication 22 Mar 29, 2009 11:20 PM
Help! Pannel lines in Epoxy glass finish? Leeroy1 Scale Fuel Planes 6 Jun 22, 2007 05:14 PM
Might sound crazy, glass cloth alternative for finishing chopperjoe Foamies (Kits) 5 Aug 02, 2004 05:27 PM
glassing : WBPU or finishing epoxy Stephane Scale Kit/Scratch Built 22 Mar 21, 2003 11:01 PM
