Apr 29, 2018, 08:45 PM
DavidsPlanes
doxilia's Avatar
Weta,
Balsa skinned full foam cores are extremely strong under uniformly distributed pressure. You can skin a full (no cutouts) foam core wing with 1/32” (very thin) balsa and with the aid of a few strategically located strips of CF or FG between core and skin, you can have a bullet proof wing. The same goes for fuselage decks.
However, if you remove core material leaving “bridges” in the skins, the ability of the composite to distribute pressure drops drastically. And of course, any non distributed load or highly focused pressure point (e.g., a knife blade) will also slice right through the composite.
In short, so long as your foam core decks are adequately supported in a cradle when applying pressure on the model while inverted, they will also be bullet proof. A full composite bond is of course key in the ability of the composite to distribute forces - whether it be in flight on a wing or on a deck when starting an engine (which actually doesn’t require a super strong deck as is evident by the much weaker sheeted former structure).
David
May 08, 2018, 10:48 AM
I don't know how far you're willing to deviate from the original, but Steve Helms' Checkmate was basically a Joker copy.
Sep 10, 2021, 10:29 PM
1scalebldr's Avatar
Joker 60
I picked up a '90' size pattern plane @ Estate sale. Just the plane no info or anything. Plane was unfinished, damaged & obviously an old plane.
Looked good. Had OS 90 Surpass. 72" w.s. 76" fuselage. Thought I could get it in the air for a pattern practice plane while building my other Pattern planes. Plane had problems. I spent almost 6 weeks FULL TIME restoring/ repairing/ improving this plane. It's similar to the Joker & other planes of that era. Do any of you recognize this plane??? Here are 2 photos when purchased. Others result of 6 weeks hard work, much modification. Thanks
Sep 11, 2021, 03:27 PM
dhal22's Avatar
It can't be a Joker with out retracts or a nose gear.
Sep 13, 2021, 11:54 AM
?? Matt's original Jokers didn't have a nose gear, they had retracts on the mains and used the MK tailwheel assembly
Sep 13, 2021, 10:47 PM
dhal22's Avatar
My bad. Thought nose gear.
Feb 04, 2022, 01:32 PM
WITCH HUNTER EXTRAORDINAIRE
She is a beauty, Did you ever find what it was?
Discussion Joker 48" Number_6 Foamies (Scratchbuilt) 0 Nov 05, 2016 03:42 AM
Help! Junior 60, a GOOD QUALITY plan, not yet available, Can anybody help? Edubarca Vintage & Old-Timer Designs 33 Oct 25, 2015 12:57 PM
Help! Tiger 60 or Tiger 2 plans StayQuiet Balsa Builders 0 Sep 28, 2015 08:50 AM
Discussion joker 2/ maxi joker 2... the difference? aftica Electric Heli Talk 3 Sep 08, 2006 10:42 PM
