Thread Tools |
This thread is privately moderated by Blaze0021, who may elect to delete unwanted replies. |
Video
FMS Mitsubishi A6M5 Zero 1100mm Warbird Maiden Flight
This is the Maiden Flight of my FMS Mitsubishi A6M5 Zero 1100mm Warbird. I received this beautiful A6M5 Zero as a Birthday Present from the Cheer Central Suns J2 “Glitter” (Glitterati).. the All-Star Cheer Team that I Coach.
Out of the box, all of parts arrived pristine with no blemishes. Assembly of the model was very straightforward and simple. The only main modification was adding (16) Great Planes 7-Gram Sticky Back Lead Weights within the Plastic Cowl Interior to achieve the manual’s recommended 60-65mm Center of Gravity. Aside from this, the model was assembled and balanced in a short amount of time and ready for setup on the Spektrum DX8 Transmitter. The FMS Mitsubishi A6M5 Zero 1100mm is a smooth-flying, aerobatic, predictable, and gorgeous Warbird.. a plane that I’ve wanted to have in my fleet for quite some time now. This Maiden Flight is dedicated to my 2016-2017 Cheer Central Suns J2 “Glitterati” who honor me with this treasured present. With heartfelt gratitude.. thank you. UPGRADES / MODIFICATIONS: Receiver: Lemon Rx DSMX Compatible 7-Channel (End-Pin) Receiver / Stabilizer with Diversity Antenna (LM0033) http://www.lemon-rx.com/index.php?ro...product_id=131 Ballast: (16) Great Planes 7-Gram Sticky Back Lead Weights within the Plastic Cowl Interior http://www3.towerhobbies.com/cgi-bin...&I=LXK204&P=ML TRANSMITTER, RECEIVER, & SETUP: Transmitter: Spektrum DX8 (G2) Gain Settings: Aileron - 9:30 O'Clock, Rudder – 10 O'Clock, Elevator - 10 O'Clock High Rates: 100-Aileron / 25% Expo, 100-Elevator / 30% Expo, 100-Rudder, 0% Expo Low Rates: 70-Aileron / 20% Expo, 70-Elevator / 20% Expo, 100-Rudder, 0% Expo Flap System: Mid - 50% / Full - 75% Flap Delay: 2.0 Seconds Center of Gravity: 62mm – Added (16) Great Planes 7-Gram Sticky Back Lead Weights within the Plastic Cowl Interior. Battery: Admiral Pro 3S 2200mAh 45C Throttle Timer: 4 Minutes Lipo Final Voltage: 11.38 Volts out of 12.60 Volts (31%) Music: "Spectrum of the Sky" by Break of Reality Camera: iPhone 6 at 1080P / 60 FPS Headmount: http://www.amazon.com/Mount-Smartpho..._detailpages00 Thanks for watching and if you haven't already please click the Thumbs Up and Subscribe! |
Thread Tools | |
Similar Threads | |||||
Discussion | FMS 1100mm Zero vs HSD 1100mm Zero | deltaKshatriya | Electric Warbirds | 0 | May 02, 2016 03:33 PM |
