Apr 28, 2017, 05:28 AM
Scale RC Plane Lover
julescrafter's Avatar
update on engines (dummy)
Apr 28, 2017, 06:48 AM
Hi, Jules. It is clear that you master the art of doubling/folding the depron ...! How do you do it? What technique do you use? Tips?
Apr 28, 2017, 08:22 AM
You will need a heat-gun with variable temperature and a stationery wooden/ metal cylinder rod. Set the heat-gun to medium, and then heat the foam sheet from top to bottom with zig zag movement and to top again, flip the sheet and do the same. And then flip again on front side and do that again. Then place the sheet on top a stationery rod and then press gently and rub it inward into your direction, you must rub it inward or else it will break. Rub it until the sheet is slightly curved, and then rub it again to make more curve and so on if you want to make a cylinder or a tube. Don't force it or it will break. You can also use the table edge instead of metal rod.
Apr 29, 2017, 02:20 AM
2 update photos. Engines (dummy) already installed
May 05, 2017, 03:04 AM
I am very exited with his construction, because he is so easy and at the same time so great ... To see these plans when they are done ... To reinforce the construction, do you plan to line the model with some fiber and resin? For my models I use a resin made of thin film-coated cellulose glue, with alcohol to burn, and fiberglass of 25grs / m2. It can work very well, it dries quickly, it can be retouched (with alcohol directly) and once dry, it is very resistant. It is like using expoxi, but with the advantage that if needed, it can be removed, repaired, dissolved, rebuilt , Very easily.
May 05, 2017, 09:04 AM
I will just covering it with white matte oracal vinyl and paint it with light grey.
more update, dry fitting the wing
May 07, 2017, 08:41 AM
all control surfaces are in place, next its wingtips
Wing joints is a success, very rigid and strong.
May 07, 2017, 08:49 AM
SebastianG.'s Avatar
Awesome......
Can't wait for the Maiden......and the plans ;-)
May 07, 2017, 08:59 AM
Originally Posted by SebastianG.
Awesome......
me too, thanks
May 08, 2017, 04:25 AM
+1!!!!!!!!!!!!!!!!!
May 08, 2017, 07:16 AM
All retract landing gear are in place, next will be landing gear fairing/ cover on each wings
May 09, 2017, 08:06 AM
just arrived this evening, HQ quad racer prop 6x4x3 CW & CCW
May 09, 2017, 10:42 AM
HJG
HJG
HENRY
Hi
Very nice build, are you tape hinging your control surfaces, cannot make out the detail on the photo?.
Also can you please give details on the retract units used and did they need any mods is this going to be grass field
Usable?
Regards
Henry
Discussion fms 1700 mm beaver floatman Waterplanes 2 Dec 01, 2016 06:23 AM
Discussion Is their room for 2 3s batteries in FMS 1700 mm Corsair dhenry132 Electric Plane Talk 3 Mar 02, 2016 03:24 PM
Discussion 1700 mm size planes planes weedsnager Electric Plane Talk 3 Feb 21, 2016 11:44 AM
Discussion 120 mm EDF A-10 Warthog eatond Castle Creations 0 Apr 01, 2008 01:34 PM
