A-10 Thunderbolt II 1700 mm - with plans when finished - RC Groups
Apr 23, 2017, 03:25 AM
Scale RC Plane Lover
julescrafter's Avatar
Build Log
The original plan was to build A380 after my C-130 RC, but then switched to Boeing 747. One day I saw my fellow Facebook group member build an A-10 then I postpone again the B-747project. I already bought 5 servoless retracts without strut and wheel from Hobbyking for 747, I will use 3 of them on A-10. Usually I post my complete build in here, this is my first time posting on a project that is still on progress.
Model specification :
- Material : 3mm polyfoam/ depron foam
- Glue : hot glue
- Cover : Vinyl with paint
- Landing gear : 3 servoless retracts
- Sound jet effect with portable MP3 player
- Motor : 2 x 2826 - Turnigy 2200 kv (pusher prop)
- ESC : 2 x 40A
- Servo : 9 x 9 gram
- Prop : 2 x 6x4
- Wingspan : 1700 mm
- Airfoil : Clark Y
- Flying weight : 1600 gram (target)
Apr 23, 2017, 03:28 AM
3D printed pilot
My first time using 3D printer for my RC part, this is pilot figure and strut for front landing gear that I printed
Apr 23, 2017, 03:32 AM
Cockpit and nose section
The progress build photos of cockpit sections. Dry fitting the cockpit-tub
Apr 23, 2017, 03:34 AM
Mold for Canopy
I will use vacuum forming to mold the canopy. First I print the canopy shape with 3d printer and cover it with 2 layers of thick putty.
Apr 23, 2017, 03:37 AM
Battery hatch opening, GAU-8 and dry fitting front canopy
Apr 23, 2017, 11:17 AM
psychedvike's Avatar
Nice!
Apr 23, 2017, 11:59 AM
Originally Posted by psychedvike
Nice!
thanks
New progress, late at night. Middle fuselage
Apr 25, 2017, 06:54 AM
Hi jules do you know this work?
https://www.rcgroups.com/forums/show...10-Thunderbolt
Apr 25, 2017, 09:26 PM
Originally Posted by enriqueigl
wow that's the famous indoor A-10 , amazing work!
More updates on mine
The wing will be detachable
Apr 26, 2017, 10:40 AM
designing plans for engine section. The 2 motors will be at the end of the two exhausts
Apr 26, 2017, 11:02 AM
Nice!!!!
Apr 26, 2017, 12:55 PM
An itch?. Scratch build.
eflightray's Avatar
Pusher prop ?
I did mine in front of the nacelles.
Ray.
Apr 26, 2017, 09:45 PM
Nice!!!!
thanks
Originally Posted by eflightray
Pusher prop ?
Ray.
Yes sir, pusher prop
I need to hide that prop. I will use 6x4 inch prop or 5x5 (4 blade) inch
Apr 27, 2017, 02:28 AM
eflightray's Avatar
Originally Posted by julescrafter
thanks
Looks comes before efficiency ?
But you only see the props, where ever you put them, when not flying.
Ray.
Apr 27, 2017, 03:02 AM
Exactly
For me looks is everything, then flying is secondary
Ray.
Discussion fms 1700 mm beaver floatman Waterplanes 2 Dec 01, 2016 06:23 AM
Discussion Is their room for 2 3s batteries in FMS 1700 mm Corsair dhenry132 Electric Plane Talk 3 Mar 02, 2016 03:24 PM
Discussion 1700 mm size planes planes weedsnager Electric Plane Talk 3 Feb 21, 2016 11:44 AM
Discussion 120 mm EDF A-10 Warthog eatond Castle Creations 0 Apr 01, 2008 01:34 PM
