Apr 21, 2017, 10:00 AM
plans
Hi! I am looking for layout plans of 'classic' f3d racing planes or similar for colleting and study purposes..(take measurements, essentially) especially interested in sattler's Panther, cmad too swet and larson vendetta FAI
here is my the drawing actually i am working on for my racer
thank you!
Jun 02, 2017, 08:20 AM
errata corrige
I realized in the drawing i posted there were mistakes.. here i the current one in which i am working on (.pdf file)
Jun 03, 2017, 04:22 PM
JOE MOCERI
Here are a couple that I have in my files that I have found on other web sites.
Joe
Jun 06, 2017, 08:50 AM
I already got there plans, but anyway, thank you, Joe!
I am still looking for the plans of the harold sattler's FAI panther..
Aug 03, 2017, 11:37 AM
progress
this is the definitive layout. I am unable to find the coordinates of the du 90091 airfoil.. I will opt for the MH24 (different from the one in thepicture)
Aug 03, 2017, 07:28 PM
If you're going to cut cores and sheet them, I don't recommend the MH24. That airfoil needs high accuracy like you get from machined molds. An SD6060 is much more forgiving and very close in performance. It also has much more friendly handling at slower speeds because of the more gradual taper to the trailing edge. If you do a vacuum bagged SD6060 with a feather edge core and glass and carbon mat or light cloth cloth coming together in the trailing edge, you can get a really nice TE, even with a balsa sheeted wing.
Jim
Aug 04, 2017, 10:35 AM
thanks!
Thank you for your input, jim.. very appreciated
Giovanni
Aug 04, 2017, 11:32 AM
I forgot to ask if the sd6060 airfoil has to be used both for the root and the tip.. l
Aug 04, 2017, 03:44 PM
Personally, I would recommend the same airfoil from root to tip.
Jim
Aug 05, 2017, 08:06 AM
ok
thanks!
Sep 27, 2017, 08:02 AM
dkane's Avatar
I was asked to identify the width of the Hover, Stiletto canopy. I have tried sending both a PM and email with the info and it doesn't seem to go through. Therefore, I am posting it here.
The width is shown on the calipers. It is about .800" just before the radius into the top and is measured at the widest point in top view. It is also tapered from the base to the top.
Hope this helps.
DK
Sep 27, 2017, 08:57 AM
Thanks!
Yes, it really helped! Thank you very much!
Giovanni Pavan (Italy)
Sep 27, 2017, 09:02 AM
and at the base it should be about 2.85 cm
Sep 27, 2017, 09:07 AM
Ok.. maybe i am annoying someone.. but the FINAL correct drawing for the fuselage is this:
I changed a bit the lowest part of the nose from the original, because i wanted to make the plane similar to the Sattler's Panther
Sep 27, 2017, 09:09 AM
the WC wing it should be 140 cm of wingspan, root 27 cm, tip 16 cm and it is placed a bit on top tomfull enclose the pipe
Discussion Vintage rc plan Beech 17 Stagger wing plans?? KOMET 44 Scale Fuel Planes 6 Jun 05, 2016 08:52 PM
Plans. Anyone interested in plan swapping (royalty free plans of course). rsieminski Sport Planes 4 Mar 13, 2002 02:24 AM
Plans,plans, and more plans omega blood Parkflyers 0 Jan 06, 2002 04:31 PM
