223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel - RC Groups
This thread is privately moderated by Mikey 68, who may elect to delete unwanted replies.
Apr 20, 2017, 09:57 PM
Trader Rating: 558
Mikey 68's Avatar
Sold
I have 2 left
Quantity: 223pcs
Shank diameter: 1/8" (3.175mm)
Application: Mainly used for DIY carving sanding, cutting, polishing / wood, metal, mold polishing.
Item Quantity (pcs)
1/2 x 1/2 Sanding Bands 20
1/2 x 1/4 Sanding Bands 20
Mounted Abrasive Stones 15
1/2 x 1/2 Mounted Rubber Mandrels for Sanding Bands 1
1/2 x 1/4 Mounted Rubber Mandrels for Sanding Bands 1
7/8 Rubber Polishing Wheel 2
3/4 Pink Aluminum Oxide Wheel 6
3/4 Green Aluminum Oxide Wheel 6
Stainless Steel Brush (7/8, 3/4,1/4 ) 3
Nylon Wire Brush (7/8, 3/4,1/4 ) 3
Copper Wire Brush 3
Fiber Glass 1 1/4 Cut-Off Wheels 10
1 Soft Polishing Woolen Wheels 15
1/2 Soft Polishing Woolen Wheels 30
3/8 Hard Polishing Woolen Points 10
Silicon Cut-Off Wheels 35
1 Aluminum OxidebCut-Off Wheels 30
Diamond Burrs 5
HSS Burrs/Drills 6
Polishing Paste 1
Wood Storage Box 1
Total 223pcs
Package Included:
223 x Rotary Tool Accessories
$36.35 shipped
Sold 223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 0 Apr 04, 2017 07:55 PM
Sold 223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 1 Feb 05, 2017 10:04 PM
Sold 223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 0 Jan 19, 2017 11:07 AM
Sold 223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 0 Jan 09, 2017 01:14 PM
Sold 223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 2 Oct 07, 2016 10:13 PM
