Apr 19, 2017, 05:41 PM
Flying wing - ailerons and elevator at the same time?
In flying wings we've got the ailerons and elevator at the same control surfaces, so I'm wondering what happens if I use both of them at the same time? how the servos are gonna react?
Thanks.
Apr 22, 2017, 05:06 PM
-insert witty saying here-
Hemikiller's Avatar
Almost all modern radios have an "ailevator" mix for flying wing aircraft.
Jul 31, 2017, 11:27 AM
treefinder
springer's Avatar
If you have the two functions mixed correctly, when you pull back on the stick, both surfaces go up, if you push it right, the right one goes up and left goes down. If you are pulling up elevator and using ailerons then both may go up, but the one on inside of turn goes up more. The trick is get proportions right.
May 20, 2019, 02:34 PM
Need Help
I know this is late but how do you make your rc plane like my Ares gamma pro v2 not use its aileron and elevators at the same time? How do I counter act the alievator?
May 20, 2019, 05:37 PM
Entropy is happening!
Jim.Thompson's Avatar
I have just googled the model and found this : Ares gamma pro v2
Which reveals that it is a conventionally configured aircraft (with a tail).
As such, it should not be set up in your tx. with ailevators or any mix that is designed for a tailless model. That is what this thread is about.
Your model set up (in the tx.) should be a simple 3 axis set up with no mixes, just dual or tripple rates.
Post back if you still are not clear on this.
Jim.
Help! Elevator and aileron for "flying wing"? renyizhang Electric Plane Talk 10 Dec 01, 2015 06:30 PM
Discussion Learning heli & fixed wing at the same time, best to stick with mode 2 or 4? Hybone Electric Plane Talk 4 Nov 07, 2015 08:27 AM
Discussion Learning heli & fixed wing at the same time, best to stick with mode 2 or 4? Hybone FPV Talk 0 Nov 06, 2015 07:28 PM
3 Aerobird Challengers Flying at the same time briancerveny Beginner Training Area (Aircraft-Electric) 7 Aug 19, 2005 04:33 AM
use of ailerons & rudder at the same time slabs Beginner Training Area (Aircraft-Electric) 19 Oct 09, 2001 07:39 AM
