Runcam Micro Swift - Tiny CCD FPV CAM - 5.6g - RC Groups
Apr 19, 2017, 09:54 AM
nitbeat's Avatar
New Product
I've been waiting for a while now for a lightweight tiny CCD FPV Camera,
after the Swift mini, here comes the Runcam Micro Swift !
RunCam Micro Swift 600TVL 2.1mm IR Blocked 1/3 CCD FPV Camera PAL/NTSC 5.6g
https://www.banggood.com/RunCam-Micro-Swift-600TVL-2_1mm-IR-Blocked-13-CCD-FPV-Camera-PALNTSC-5_6g-p-1144546.html
The Micro Swift is a very small (19x19) FPV camera, with 2.1mm lens and CCD sensor which is very unique these days..
Looks like it'll have all the nice tuning feature we all love in normal hs1177 CCD camera's such as:
WDR, AGC, DNR and other configurable settings..
NOTE: the lens is M8 Screw so you can't use the standard lens for an upgrade (M12)
Additional great benefit is that CCD sensors aren't sensitive to vibrations like the CMOS (rolling shutter) so
no more jello effect in the video !
Read more about "Rolling Shutter Jello Effect Explained" if you want here
RunCam Micro Swift Camera Holder Mount Bracket
https://www.banggood.com/RunCam-Micro-Swift-Camera-Holder-Mount-Bracket-OrangeBlack-For-FPV-Racer-p-1152416.html
User Manual Here - click here
Details
Model RunCam Mi​cro Swift
Image Sensor 1/3" SONY Super HAD II CCD
Horizontal Resolution 600TVL
Lens 2.1mm​ Lens(M8)​ ​
Signal System PAL / NTSC
S/N Ratio >60dB(AGC OFF)
Electronic Shutter Speed PAL:1/50 ~ 100,000; NTSC:1/60 ~ 100,000
AutoGain Control(AGC) YES
Back light compensation(BLC) YES
Min.illumination 0.01Lux/1.2F
WDR D-WDR
DNR 2DNR
Day/Night Color / Auto / B&W
Power DC 5 to 36V
Net weight ​5.​6g
Dimensions 19mm * 19mm * 19mm
http://shop.runcam.com/RunCam-Micro-Swift
Apr 19, 2017, 10:03 AM
Fan of just about anything RC
SoloProFan's Avatar
Nice, a new step towards even higher quality tiny FPV flyers.
Apr 19, 2017, 10:15 AM
nitbeat's Avatar
Yeah indeed !
Although I'm a fan of casing, this hybrid case + PCB looks pretty nice
Apr 19, 2017, 10:21 AM
youtube.com/danknee
Danq0's Avatar
what!! the mini just came out, just as I suspected they are creating a whole line up of swift's
Apr 19, 2017, 10:22 AM
Merch's Avatar
Now this is starting to get exciting
Apr 19, 2017, 10:23 AM
youtube.com/danknee
Danq0's Avatar
do you guys know if this is just a swift mini without the casing? would be awesome to swap cases to make my mini a micro!
nevermind, took a closer look at the two and they are different
Apr 19, 2017, 10:29 AM
Time For Me To Fly!
fastmax's Avatar
Very cool! These will sell like hot cakes!
Apr 19, 2017, 10:46 AM
nitbeat's Avatar
Yeah, I was thinking the same, the mini kinda stuck in between in the gray area
Apr 19, 2017, 10:54 AM
Quad Erat Demonstrandum
scousethief's Avatar
The mini's suit the smaller 130/150 X frame racers as well as obviously sizes above , the standard stretched X on the smaller frames sometimes have a lower frame height which makes the camera protrude so to some it can be unsuitable, you can of course change that by simply using different stand offs.
This will be quite nice on the 130 and under micro frames it will make a refreshing change from the cmos cameras.
Apr 20, 2017, 05:06 AM
nitbeat's Avatar
Yeah, finally jello time is over
Apr 20, 2017, 05:19 AM
This looks awesome! I even have a brushed FPV quad I reckon I will try this on...
Apr 20, 2017, 06:46 AM
silently addicted..
muteFPV's Avatar
Yep, can't wait as well. Mine should arrive shortly. I believe it will be a great combo with an ATX03 on a micro build.
Preorders will start tomorrow but delivery will be a bit delayed, expected to start on 15th May.
Apr 20, 2017, 08:00 AM
YEAH !! hang on i like jello especially with peanut butter
With a bit of luck no more "yay i can see , uhoh darkness oh yay theres the light again " moments in turns
Apr 20, 2017, 09:12 AM
Merch's Avatar
Runcam Micro Swift Unboxing (9 min 9 sec)
Apr 20, 2017, 12:18 PM
nitbeat's Avatar
haha
Originally Posted by Merch
wow that was FAST ! thanks for the unboxing man
New Product Runcam Swift Mini 130 2.5mm Micro FPV Camera PAL/NTSC 22*22mm----Free Review BGjim FPV Equipment 73 Aug 20, 2017 06:01 PM
New Product Runcam MICRO Swift - tiny CCD FPV camera muteFPV FPV Talk 38 Aug 19, 2017 07:07 AM
New Product Eachine OKKAN EK1119 1100TVL CCD 150 2.3mm M8 Lens Tiny FPV Cam---Discussion Thread BGjim FPV Equipment 57 Jul 05, 2017 09:25 AM
Discussion FPV Latency Comparison (CCD / CMOS board cam, Mobius, RunCam, Foxeer, Sky-HD01) daneelgiskard FPV Equipment 1 Jan 28, 2016 11:51 PM
