Apr 18, 2017, 11:05 AM
Build Log
The Thing, cheap, simple, and lots of fun!
My dad modified a design that was given to us. The result was amazing, it flies great, slow, fast, rolls like it has ailerons, inverted flat spins (kind of), tail touches, tight loops and many more. It doesn't like to be inverted but it will. Hope you enjoy it.
Total cost is under $50 without transmitter when using Dollar Tree foam board, you will need to buy 2 sheets to make one.
Time, my first build took about 4 hours but once you get the hang, you should be able to get the build times down to about 30mins. I suggest you make templates and save those.
I will post a build video soon.
Fuselage is DTFB that I covered with 2" packing tape and the parts are hot glued right on to the tape.
Motor 1400kv 2212 $5.10 http://www.valuehobby.com/power-syst...12-1400kv.html
Prop $1.30 for 2 http://www.valuehobby.com/accessorie...low-flyer.html
ESC 30amp $8 http://www.valuehobby.com/power-syst...e-30a-esc.html
Servo, 9g $2 http://www.valuehobby.com/radio-syst...cro-servo.html
Battery 3s 1600mAh $15 http://www.valuehobby.com/power-syst...600mah-3s.html
Motor mount and servo mounts are 3D printed by us. But you can glue the servos down and build a motor mount, put in about 3 degrees down and 3-5 degrees right thrust.
Battery, receiver, and ESC are Velcro-ed on.
The part in the middle of the plans is the stiffener that gets folded in half, glued to the bottom all the way forward.
Some have used 10mm square glued to the bottom and a Slow Stick motor mount glued to the bottom.
Apr 18, 2017, 11:06 AM
Videos
Build Video
The Thing, Cheap, Easy, Fun flying Foam Board (21 min 1 sec)
Stunt Video
The Thing Stunts (3 min 35 sec)
Apr 18, 2017, 11:07 AM
Reserved
Reserved for more stuff
Apr 18, 2017, 01:25 PM
Flying RC Models for 60 years.
Sixter's Avatar
Cbaldwin I like it It's Cool and your design is Different! Looking foreword to viewing a video! Thanks for sharing it with a very detailed parts list, and the plans Thats how you start a Build Thread
Bobby
Apr 18, 2017, 03:24 PM
Following. Would love to see a bit more detail of the plans and the various parts. Keep up the good work!
Apr 18, 2017, 03:54 PM
Thank you!
What details are you looking for, I will try to get them for you?
Apr 18, 2017, 08:28 PM
looks very nice.
I've built your model in sketchup so I can cut it out on the CNC. Here it is if anyone cares to use it..
Apr 18, 2017, 08:48 PM
Originally Posted by Blackkrystal73
looks very nice.
That is great! Thank you for the help!!!!
Apr 21, 2017, 10:44 PM
Build Video
I just posted the build video in the Video post
Discussion The Internet of "Things" ...........how many "Things" are on yours ? rockyboy2 Life, The Universe, and Politics 5 Jul 21, 2016 01:49 PM
Discussion Coolest thing I saw @ SEFF 2010... Coolest thing I WISH I saw @ SEFF 2010... jfetter SEFF 17 May 11, 2010 09:21 AM
Discussion When things go wrong? When things go right? Kimber The Builders Workshop 1 Apr 10, 2010 04:54 AM
Discussion What one thing is missing in the performance of your DLG and what one thing would you Thermaln2 Hand Launch 32 May 08, 2009 04:29 PM
Is this a Good thing, or a BAD thing? Gary Warner Life, The Universe, and Politics 16 Oct 15, 2004 04:36 AM
