Should identical motors "cog" the same?
I have two Eflite 60 400kv motors. One is right out of the box and cogs strongly. One I got used and has only a small/moderate amount of clogging. Is the used motor bad? Iavenot run it yet and don't have a good way right off. Any ideas?
Thx, Mel D. |
You may be onto something here. Two identical motors should have the same amount of cogging. Cogging is determined by magnet strength, magnet size, hammerhead shape, air gap, stator slot & pole geometry and skew angle - all of which should be identical in identical motors.
It's possible that the used motor have weaker magnets. You can verify that by measuring the Kv, because weaker magnets result in higher Kv. It is not difficult to measure Kv yourself. The bearings in motors are usually tighter until run-in. Make sure you take that into account when comparing 'cogging'. |
One thing to check. Make sure the wires aren't touching each other. If they are, when you spin the motor the moving magnets create a current in the coils and it will resist wanting to turn. That could easily be mistaken for strong cogging.
And when that happens, the Kv goes up. And by measuring the Kv, and comparing it to stock Kv, one can determine if the magnets got demagnetized - which would also explain the weaker cogging. |
In most applications, cogging doesn't matter. It really only matters in slow speed or positioning applications. One of the biggest factors in cogging is the number of poles and the number of slots. Certain combinations cog more and certain combinations cog less.
All of the above.
Could be a slightly misaligned magnet, no problem. Do both motors have the same number of slots/teeth, and same number of magnetpoles? (I would not put it past them ![]() Disconnect motors completely from controller, and don't let the connectors touch/short. Crank both motors by hand, one could have excess/more cogging (magnetic bumps). That makes it more difficult for controller to start the motor. Not a big deal. Cogging, the magnetic bumps you feel when cranking the shaft by hand, or the lack of cogging, says nothing about motor power, efficiency, iron type/grade, quality, magnet strength or quality, max.current, max. power, Kv, Rm, Io, Kt. Too many motor design variables effect cogging. Cogging depends a.o. on number of magnetpoles versus statorpoles, magnet strength, distance between magnets, magnet (mis)alignment/placement, magnetshape etc. This effect can be put to good use: en.wikipedia.org/wiki/Reluctance_motor Don't forget to disconnect motor(s) from ESC when checking for magnetic cogging, and don't let the connectors touch. Otherwise the ESC may short the motor wires (depending on ESC type/make, yes/no power), thus causing the motor to act as a shorted generator → brake action (e.g. when you want to stop a prop in a glider). Crank the motorshaft with your fingers with wires connected and motorwires shorted, you'll feel the difference. Vriendelijke groeten ![]() |
Many times, I've seen two identical motors, brand new, never been connected to anything, and fresh out of the box they have different 'cogginess' but perform identically. No relationship between price/quality either... same situation with a $15 Suppo or a $60 Scorpion.
No knowledge of the various ..Theories.. re cogging causes .
Do know though that in taking a previously cogging less motor and rewinding it with thicker wire and slightly fewer turns has resulted in quite strong coggings. This has happened several times.. So hardly a chance result. One motor I had to Re - rewind with more turns /thinner wires. So the ESC could actually manage startups. 'Splain that Ricky ![]() |
How did you notice the cogging?
Thanks to all.
1. Motors are physically identical as close as I can tell. 2. Motors are disconnected from ESCs. 3. They are mounted on a twin I am finishing up. I just grabbed each motor in turn and said WHOA!!! They don't match.... 4. I have no idea how the low cog motor was treated. Got it used with a Phoenix 80. |
The winding doesn't matter for cogging. It has no influence on cogging at all. It's purely the design of the magnets and steel. Unless, of course, the lead wires are shorted together.
Thread Tools | |
Similar Threads | |||||
Discussion | Cogging not the same on two identical motors... problem? | racer944 | Power Systems | 10 | Dec 15, 2016 08:35 AM |
Help! | Should all the motors speed up around same RPM? | MoyRC | Multirotor Drone Electronics | 5 | Oct 11, 2016 09:22 AM |
Discussion | can two identical brushless motors run off of the same ESC? | bamm | Power Systems | 7 | Aug 22, 2007 08:52 PM |
Got my Rocket 3600 motor. Almost no cogging, should I be concerned? | BING! | Power Systems | 10 | Jun 19, 2005 10:34 AM | |
Should I be able to use the same motor setup on any plane of the same weight ? | NetForce2K | Power Systems | 2 | May 01, 2003 11:56 AM |
