Advanced OSD speed alarm for ET Vector - RC Groups
Apr 17, 2017, 01:04 PM
Question
Hi. I am running Vector beta 12.60 and notice that I got always an alarm of LOW SPEED on OSD.
I do set on advanced osd screen setup ( configure alarms for gps groundspeed ) the low alarm enabled and the trigger value to 40 Kh . Used the display alarm text to display ... LOW SPEED STALL.
My OSD still showing forever the info on ground stoped and even in air when I am flying at 70 Kh or more.
Could it be my error, anything else I must check or this is normal to Vector and the alarm never clears?
Maybe JohnET or others knowing the program could help.
Tanks
JMCNeto
Apr 18, 2017, 05:16 AM
because rust never sleeps....
HugoRogers's Avatar
Tanks
JMCNeto
Interested to try this out, but I have to admit that I am confused by the user interface.
For groundspeed, if I would like a low speed threshold configured, I tick the Low Alarm Enabled checkbox, and the High Alarm Checkbox is also selected (with a black block rather than a tick)
Why is this?
How do I know if my "Alarm Trigger Value" will trip if the measurement goes above or below this value ?
Apr 18, 2017, 09:57 AM
JohnET's Avatar
Hello,
Please open a support ticket and provide your config file and a log file from a flight where this occurred.
When you select hi or low, the other one is essentially "greyed out" so it can not be selected.
Regards, John
Apr 18, 2017, 10:58 AM
HugoRogers's Avatar
Originally Posted by JohnET
Hello,
Regards, John
Thanks for the clarification John.
Apr 19, 2017, 04:08 AM
HugoRogers's Avatar
Hello,
Regards, John
John / EagleTree
For info, using the "block/mixed" state on a checkbox is not the way to show it is disabled. What you should do is actually *disable* the checkbox ! :-)
Using the mixed state, implies that this is a nested checkbox and there are sub checkboxes, some of which are selected and some of which are not.
Please refer to Windows UI guidelines for checkboxes :
https://msdn.microsoft.com/en-us/win.../hh700393.aspx
I think what might work better here is a radio button pair, where the user can either select High or Low. Much easier to understand I think.
Hope this helps.
Apr 20, 2017, 09:01 AM
Ticket closed but remains doubts
... Explained that I must wait 10 seconds on a speed greater than the low limit to clear the alarm.
But the question is HOW THE ALARM IS TRIGERED ?
When not flying , just preparing and moving aroun with the plane I got the ALARM.
Could it be my error ?
How is the alarm deployed ? Is it just after beeing flying at minimum speed or else?
Could you please inform?
I will try reduce the value and test again but meanwhile it will be good to know how to check.
Tank you
JMCN
Apr 20, 2017, 10:06 AM
HugoRogers's Avatar
Tank you
JMCN
Is it simply because the value is below the alarm level when you have not taken off. If you have a "LOW" alarm then that would fit wouldnt it?
Discussion Using Pixhawk for flight controls, and EagleTree Vector for OSD Belicopter FPV Equipment 5 Apr 10, 2017 02:39 PM
Discussion Vector Advanced OSD Display simple question alaFlash Eagle Tree Systems 1 Mar 02, 2017 10:31 PM
Question ET Vector OSD configuration EdDial Eagle Tree Systems 5 Mar 24, 2015 06:57 PM
Question Setting Alarms in Vector & OSD question SidneyKi Eagle Tree Systems 0 Mar 05, 2015 12:13 PM
Question Mini Servo Tester for usage with ET-OSD Pro? lichy FPV Talk 0 Jun 22, 2011 12:46 PM
