Apr 17, 2017, 01:57 AM
Video
giant four engines cargo foamy
i build a four motor cargo with depron. Inspired by the plan of the cargo twin enlarged to 140%. Wingspan 2 meters, four Torcster A2212 / 10T 1400 Kv engines with APCE propeller 8X4, four ESC 30A and two 3S battery 2200 mAh 35C
this is the maiden flight and you can see at the start of the video the mounting of removables wings
giant four engine cargo maiden /vol de test quadrimoteur géant (5 min 18 sec)
Apr 17, 2017, 10:52 AM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Excellent !
Apr 17, 2017, 07:09 PM
Awesome. Well done!
Apr 18, 2017, 04:41 AM
the second test fly for batterys
after 6 min of flight battery at 50%
giant four engine cargo second fly test /quadrimoteur géant deuxième vol de test (6 min 24 sec)
Apr 19, 2017, 02:22 AM
giant four engine bomb drop and reverse flight
I must strengthen the wings, on the looping after the second flight back they fold dangerously .....
giant four engine bomb drop and reverse flight / mon quadrimoteur géant largage bombe et vol dos (3 min 31 sec)
Apr 19, 2017, 12:18 PM
Build more, websurf less
FlyingW's Avatar
Beautiful plane. I could see the wings bending - good idea to reinforce now. Paul
Apr 19, 2017, 12:28 PM
When cows fly!
Love the flying field! The runway might be a little hard to hit though
Apr 25, 2017, 03:24 AM
four engine crash
i don't know wath happen with the transmitter but she beep continuously and no control of the plane (the esc is not fail i think because the motors is on before the crash)
the transmitter is a turnigy GTY-i6
if anyone had an idea ?
thank's
Yves
crash four engine / crash quadri moteur (6 min 54 sec)
Apr 25, 2017, 11:54 AM
What is supplying power to the receiver/servos ? If it is the BEC of one of the ESCs , it may have had a voltage drop causing the receiver to brown out . The best solution is to power your receiver/servos with a separate power supply , such as a receiver battery . If you do that , be sure to disable the red wire from the ESC/BEC currently supplying the power to the receiver/servos .
Apr 26, 2017, 04:34 AM
thank you
i made that now, i think also it is a ESC fail
Yves
Apr 26, 2017, 01:24 PM
test receiver
hi
i test receiver with a stabized voltage power and i found the alarm when the voltage drop behind 4.2 V, the sound is the same behind the crash i put an UBEC on all my model no
Yves
Apr 26, 2017, 02:40 PM
Originally Posted by momo5400 View Post
hi
Yves
On two of my planes ( that I DON"T want to crash ) I use this external BEC with this tiny 750mah 2S battery ( from HobbyKing ) to power my receiver and servos . That way : if the flight pack battery or ESC fails during flight , I'll still have control of the rudder/elevator/ailerons to bring the airframe in for a landing .
Apr 26, 2017, 03:18 PM
12th Pursuit Squadron
TheAeronut's Avatar
Instead of a LiPo and BEC, I would suggest using a 2S LiFe pack of similar capacity. This would eliminate the possibility of the BEC being overloaded and/or failing. I use a couple of nice Cheetah 850 mAh LiFe packs from BPHobbies in my sailboats and would use them in planes that I would not trust to an ESC/BEC.
J.P.
Apr 26, 2017, 05:13 PM
J.P.
That would work too .
But in my case I already had several small 2S lipos ( and I don't have a LiFe charger ) - so I just had to add a BEC .
I don't think a BEC will overload and/or fail if it's appropriate for the voltage and amp draw of the receiver/servos/accessories/etc that it will be supplying power too .
Apr 28, 2017, 11:34 PM
he fly new
It's flying, it's broken as if it came from the war but it holds in the air. After 5 minutes of flight battery has 40% and Ubec cold to the touch (to the wattmeter not more than 2 A with the 4 servos and it is a 4 amp)
On the other hand one of the reinforcing rods between the wing and the fuselage has unhooked on take-off so I have not forced on the figures
four engine test fly after repair/vol de test après réparation (6 min 3 sec)
Video Playing with the GIANT electric foamy in the sand pit. "500th. flight" jofro Giant Electric Planes 12 Apr 09, 2019 04:50 AM
Article Four Giant Scale Trainers To Consider Matt Gunn Giant Scale Airplanes 12 Aug 01, 2017 08:44 PM
Discussion IC Engine on a foamie Plane speedactyl Fuel Plane Talk 14 Nov 13, 2015 11:00 PM
Rant Foamie cargo 5' wing NixANerd2 Foamies (Scratchbuilt) 5 Jun 09, 2014 12:29 PM
New Multiplex Cargo foamie CH47slg Foamies (Kits) 7 Aug 03, 2001 01:18 AM
