Apr 16, 2017, 08:45 PM
New Product
Racerstar TattooF4S & Star F3S, StarF4 & StarF4S - $50 AIO FC/BF OSD/30A ESC/PDB/BEC
Update: A BLHeli_32 version of the board is now available, the Racerstar TattooF4s.
Racerstar Tattoo F4S Product Page:https://www.banggood.com/Racerstar-TattooF4S-30A-BLHELI_32-4in1-ESC-5V-BEC-w-F4-Flight-Controller-AIO-OSD-BEC-Current-Sensor-p-1184869.html
Racerstar StarF3S Product Page: https://www.banggood.com/Racerstar-StarF3S-30A-BL_S-4-In-1-ESC-5V-BEC-w-F3-Flight-Controller-AIO-OSD-BEC-Current-Sensor-p-1157101.html
Racerstar StarF4S Product Page:https://www.banggood.com/Racerstar-StarF4S-30A-Blheli_S-Dshot-4-in-1-ESC-AIO-F4-OSD-Flight-Controller-w-BEC-Current-Sensor-p-1165076.html
Racer StarF4 AIO F4 FC Product Page: http://www.banggood.com/Racerstar-StarF4-30A-2-4S-Blheli_S-4-in-1-ESC-AIO-F4-BF3_1-Flight-Control-Board-with-5V-BEC-p-1142990.html
Racerstar TattooF4S
Specification:
BLHELI_32 4in1 30A+F4+OSD
Con.current: 30A
Peak current(10s): 35A
SBEC: 3A/5V
Lipo: 2-4s
Programming: yes
F4+OSD+BEC+CURRENT
Input: 2-4s lipo
Output voltage: 5V/2A
STM32F4 CPU
ICM-MPU6000 Accelerometers and Gyroscopes
MicroUSB socket
Weight: 22g
Size(PCB): 36*36mm
Package inlcuded:
1* 30A 4in1 ESC built-in F4 flight controller
1* power cable
1* bag of screws
Racerstar StarF4S
Specification:
Brand Name: Racerstar
Model: StarF4S
Item Name: 30A Blheli_S 4 in 1 ESC AIO F4 OSD Flight Controller with BEC and Current Sensor
Lipo Battery: 2-4S
Con. Current: 30A
Peak Current: 35A (10S)
LBEC: 5V @3A
Programming: YES
F4 FC + OSD + BEC + Current Sensor
Input Voltage: 2-4S Lipo
Output Voltage: 5V@1A
Sensor: STM32F4 CPU
ICM-MPU6000 Accelerometers and Gyroscopes SPI MicroUSB socket
Size(PCB): 36x36mm
Weight: 22g
Features:
- Built-in F4 Flight Control Board integrated with OSD
- BB2, 48MHZ Chip
- Blheli_S Firmware,
- 4 in 1 ESC, Super small size (36*36mm) and light weight, easy to install and use
- With 5V 3A LBEC
- With Current Sensor
-Support 2-4S Lipo Battery
- Support Oneshot42, Oneshot125, Multishot and 16.5 Dshot600
- All codes use damped light mode.Damped light does regenerative braking, causing very fast motor retardation, and inherently also does active freewheeling.
Package Included:
1x Racerstar 30A 4 in 1 ESC Buit-in F4 OSD FC
2x Cable
1x bag of screws
1x Manual
Racerstar Star F3S:
Specification:
Item Name: 30A BL_S ESC w/ F3 Flight Controller
Model: StarF3s
30A 4 In 1 ESC
Con. Current: 30A
Lipo: 2-4S
BEC: 5V @1A
Programming: YES
F3 FC AIO OSD BEC and Current Sensor
Output Voltage: 5V@2A
Sensor: STM32F3 CPU
Size(PCB): 36x36mm
Weight: 22g
Features:
- BB2, 48MHZ Chip 4 in 1 ESC
- ESC has 5V 1A LBEC Output
- Built-in F3 Flight Control Board, MPU6000
- FC has 5V 2A BEC
Package Included:
1x 30A 4 In 1 ESC Buit-in F3 Flight Controller
1x XT60 Connector
1x bag of screws
1x Manual
Specification:
Item Name: 30A Blheli_S 4 in 1 ESC AIO F4 Flight Control Board
Model: StarF4
Lipo Battery: 2-4S
Con. Current: 30A
BEC: 5V @1A
Programming: YES
Racerstar Star F4:
Specification:
Model: StarF4
Lipo Battery: 2-4S
Con. Current: 30A
BEC: 5V @1A
Programming: YES
F4 FC + BEC + Current
Sensor: STM32F4 CPU
Size(PCB): 36x36mm
Weight: 22g
Features:
- BB2, 48MHZ Chip
- With 5V 1A BEC
Package Included:
1x StarF4 30A 4 in 1 ESC Buit-in F4 FC Module
2x Cable
1x bag of screws
1x Manual
Apr 17, 2017, 02:37 AM
As much as I like the AIO idea, that USB port location has to be the single most horrible choice ever. Unless you mount the whole thing quite tall in the first place, you won't even be able to plug a standard USB cable in, and it will point to the rear and always have the power wiring in the way.
Apr 17, 2017, 04:15 AM
"Output Voltage: 5V@1A"
"1A" Meh, enough to run hs1177 and vtx03/mi200 in practice ?
Apr 17, 2017, 04:50 AM
Camera yes (only runs about 80mAh), but I'd worry about the VTX. It uses linear regs, at 4S those will get very hot even at low load.
Apr 17, 2017, 11:46 AM
5V 2A should be standard IMO
Apr 20, 2017, 02:31 PM
Can't you just position it so the port is facing sideways? Doesn't seem like the biggest deal and it's probably the best place they could find given how much they had to pack into the PCB. A newly released image shows that Racerstar opted for some nice, big ceramic capacitors. I think I will give this one a try.
Apr 20, 2017, 02:42 PM
The power plug would stand out pretty far to the side, and wiring motors would be awkward and you'd have to remap them, otherwise you'd even have to go across the board to wire the motors.
Apr 22, 2017, 12:32 AM
187
187
I built a bunch of these boards before they got released. At first I was really annoyed with the USB placement when I saw it. I have caps and 12awg leads on the battery pads but fortunately I can connect and disconnect the usb cable with no issue. However, these boards like so many others are prone to having the usb ports rip straight off so I have very carefully epoxied them with a small dab, to the pcb.
Aside from this, the mosfets are TINY compared to what you would see on a newer 30A ESC and Spek Sat isn't working but that seems to be firmware related.
Apr 23, 2017, 02:38 AM
187
187
Bumping even though this looks like an affiliate link
Anyone have this board yet or am I the only one dumb enough to be testing it?
Apr 23, 2017, 04:00 AM
Suteki's Avatar
I donr understand having only filtered 5v out when so few vtx's can run that low.
May 03, 2017, 03:41 AM
187
187
bumping, has anyone tried spektrum on these boards
May 20, 2017, 09:17 AM
Help.
I have this but sbus or ppm will not communicate to transmitter. Using fly sky radio and fsa8s receiver. Receiver binds and powers fine. All other functions like power to camera and motors work.
I have tried using ppm and sbus and all uart serial rx combinations. What am I missing?
May 20, 2017, 11:18 AM
I am also unable to get the FC to communicate with my RX, which is a FlySky X6B paired with the FlySky FS-i6. I have PPM enabled on my radio, which I've used with other models just fine. I have tried iBus and PPM on the RX. In Cleanflight I've tried each UART port and enabled iBus, nothing. I switched the RX connector to the PPM port and switched the FC over to PPM and still nothing. Everything is bound right, just no communications. Am I also missing something?
May 20, 2017, 11:39 AM
Same exact issue as me. I've tried everything for hours.
Help us! Did we both just get bad boards?
May 20, 2017, 03:51 PM
To test something, connect the ibus wire to RX6 and activate UART6 as serial/ibus port.
New Product Racerstar Star20 20A Blheli_S 2-4S Detachable 4 In 1 ESC D-shot ------Free Review BGjim Multirotor Drone Electronics 50 Oct 03, 2017 04:56 AM
Discussion Racerstar Star30 30A Blheli_S 2-5S 4 In 1 Detachable ESC scousethief Banggood.com 0 Apr 13, 2017 07:33 AM
New Product Racerstar RS40A V2 40A BLHELI_S BB2 OPTO 2-5S 4 in 1 ESC Dshot 600 RDroneW Multirotor Drone Electronics 0 Mar 24, 2017 05:25 AM
New Product Racerstar Star20 20A Blheli_S 2-4S Detachable 4 In 1 ESC nitbeat Multirotor Drone Electronics 5 Feb 24, 2017 05:36 PM
