78" scratchbuilt wing - RC Groups
Apr 14, 2017, 09:05 PM
Hello,
I wanted to post the progress I've made on what is intended to be a stable fpv platform and good all purpose wing. This was my first hotwire cutting project so there will be some inevitable sanding and spackling to do before covering it.
I will cap the trailing edge of the center section and make the elevons out of balsa. I haven't decided whether to glass it, doculam it, use brown paper or just monokote.
My intended setup is an eflite park 480 910kv motor and a 9X5 prop, two metal geared servos, 30 amp esc and a 3cell 3300 mah lipo. I may try a 2200 if it will balance.
If I like how it flies I'll be giving it landing gear to set it apart from my other wings.
Apr 14, 2017, 10:37 PM
therealfloppy's Avatar
That is a beautiful wing already.
Probably a challenge to launch this baby into the air.
Looking forward to see more of it.
Apr 14, 2017, 10:47 PM
psychedvike's Avatar
Nice design. Looks like a good start. Hotwire airfoils are my favorite scratch builds. I'll be watching your progress.
Apr 15, 2017, 11:06 AM
Watching with interest. I'd like to try my hand at hotwire foam cores in the near future.
Apr 15, 2017, 07:33 PM
Thanks everyone! I do anticipate my first launch to be a bit difficult although this thing should have a low wing loading which helps. Landing gear will help more though.
My main priority now is to sand and then fill where needed then add the balsa parts.
I will post a picture of my cutter soon, it wasn't hard to build and runs off of a 3cell lipo. This project wasn't a good place to start with the hotwire though, it is big and has tapered wings that are swept. Had I made something more simple these cuts would have been super easy. That being said this was not too bad.
Edit: here's the cutter. It has a 22" blade made of #6 music wire on a 3/4" birch ply frame. A guitar tuner tensions the wire. The battery is connected to a 30amp brushed esc which is controlled by a servo tester. I made the leads extra long so I can connect the alligator clips to a larger cutter when needed using the same electronic parts.
Apr 21, 2017, 12:03 PM
More progress: all the filling is done, elevons are finished and I added strips of brown paper soaked in a water/pva mixture to give a hard and uniform edge. The fiberglass cloth is on its way as well.
Apr 24, 2017, 07:54 AM
bmblb's Avatar
that's a BIG wing ! Are you considering a spar(s) before glassing it or would FG alone suffice? do you have an estimated range of the AUW ?
Apr 24, 2017, 10:45 AM
Thanks for the details on your cutter. Looks pretty simple to set up.
Apr 25, 2017, 12:08 AM
The AUW needs to be under 50oz which is what my first mega wing weighed. This should be less though and I plan adding three spars first.
May 17, 2017, 11:09 PM
bmblb's Avatar
[QUOTE=Lepidopteran Ape;37383334]The AUW needs to be under 50oz which is what my first mega wing weighed. This should be less though and I plan adding three spars first.[/QUOT
LA.... thanks. Were you able to make any progress? I am keen to know how it turned out
May 17, 2017, 11:25 PM
The eBay seller who sold me the fiberglass scammed me, however I got the spars in and mounted the motor. I need to make winglets and hinge the elevons temporarily then I'll test it out. I may just put some econokote on it instead of glass because it's very stiff.
May 26, 2017, 12:20 PM
I maidened the wing today at a deserted park. It was surprisingly easy to launch and climb out was strong. It won't do vertical with this motor but that doesn't bother me because it behaves like a sailplane. That did make landing in the limited space difficult though. I need to make some adjustments to the motor mount to compensate for torque, otherwise I am very happy with the plane.
Now comes glassing and deciding where all of the fpv gear should go, what color it should be, landing gear and hatches.
Jul 08, 2017, 11:59 AM
Ready for flitefest! I will keep adding things to it over time, but for now it's done!
Jul 10, 2017, 10:18 AM
bmblb's Avatar
.. nice to hear about the successful flight....it looks great....any video?
Jul 11, 2017, 06:58 PM
Here's the video!
Silver lining (3 min 20 sec)
Discussion CNC hotwire scratchbuilt flying wings mt92 Flying Wings 7 Oct 02, 2015 12:56 PM
Help! New to wings, odd problem with scratchbuilt wing Rota Flying Wings 8 Nov 11, 2009 01:59 PM
Discussion Ideas for 78" wing kits.... smitty240 Scale Kit/Scratch Built 9 Feb 20, 2006 12:42 AM
Whats the best way to ship a 78" wing RandyK1 Electric Plane Talk 6 Sep 24, 2003 05:03 PM
Anyone know 'Blade' (Dymond 78" powered wing) Mark Sanders Electric Plane Talk 1 Jul 23, 2001 07:21 AM
