Dec 07, 2019, 01:37 PM
Frankenstein recycled packs
rampman's Avatar
I use a 270 or 330 ohm, 1/4W, 5% and all have turned on so that concurs with Oz's findings.
Rick
Dec 07, 2019, 02:34 PM
Quadaholic
--Oz--'s Avatar
Looking at the guts to the DPS-1200FB (here https://github.com/raplin/DPS-1200FB) vs the DPS-1200FB-1, they are quite a bit different inside. (sorry for the blurry picture)
Dec 08, 2019, 04:19 PM
Quadaholic
--Oz--'s Avatar
Originally Posted by maleduc
Hi,
I got a HP 1200FB A with a Breakoutboard atx64p6-n02 ver003 and the problem is ;
I plug the power outlet;
The LED on the PSU doesn't turn on;
The Watt display on the Breakout board doesn't show anything;
The LED on the brekaout board blink green,red,bleu......
The fan on the PSU turn a little bit
The GPU connected to it doesn't turn on ;(
I have tried 3 different PSU with 2 different breakout board = same result.
Thank you in advance for your help
Look for the turn on resistor (its connecting pins 36 and 33), measure it, if its above ~500Ω, I would lower it or short it. Post a good res picture of that part of the breakout board, good luck.
Feb 27, 2020, 02:03 AM
Originally Posted by ldomingos
I have two HP DPS-1200FB-1 Platinum and after soldering the 1K, 1W resitor, I tested each one but they are not working.
When I plug the power cord , the fan starts spinning very quietly but the LED is off and the voltage is around 0.08V.
I followed the following threads :
http://studio939.blogspot.pt/2016/01...ystem-for.html
http://www.rchelination.com/setting-...-power-supply/
Any help will be much appreciated.
Thanks in advance,
Luis
I am just getting into using these for lipo charging.
Is this particular Power supply being discussed here a better and more reliable PSU than the HP HSTNS-PL12 750W ??
Mar 27, 2020, 03:16 PM
'All Airy' theres nowt better
Trevor C's Avatar
Ignore me - Id made a schoolboy error
Build Log DPS-1200FB Build franknitty69 Batteries and Chargers 52 Mar 28, 2020 12:17 PM
Discussion HP DPS-1200FB A PSU - No output after runningat 13.5v tuprox Batteries and Chargers 4 Dec 17, 2017 05:31 PM
Help! Dps 1200FB no voltage output after floating it MicroRasus Batteries and Chargers 6 Apr 02, 2017 12:52 PM
Question HP DPS-1200 FB problems when running in series jarppi Batteries and Chargers 1 Aug 09, 2016 05:55 PM
Discussion Topic Hijacked - Closed TazRC Batteries and Chargers 25 May 23, 2016 09:32 AM
