This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Apr 12, 2017, 04:03 PM
Lithium Member
Herb's Avatar
Build Log
F-16 70mm edf by Freewing
I picked up one of these as an "airframe only" from MRC for $159 :
http://sz-freewing.com
https://www.motionrc.com/products/fr...mm-edf-jet-arp
They also sell it (the airframe only but with LG) for $104 in China :
https://www.aliexpress.com/item/RC-a...782118518.html
It seems slightly larger than my JePe F-16 (35" ws vs 31" ws) :
https://www.rcgroups.com/forums/show...by-Jepe&pp=100
so a rough comparison will be interesting.
On this one the wingspan is 88 cm and the length is 131 cm, whereas the real one has a 9.96m wingspan at a 15.06m length
https://en.wikipedia.org/wiki/Genera...ighting_Falcon
so the model is in the ~ 1:11.4 scale range.
I plan to possibly have a tailerons only setup, to reduce wing drag.
Fan will be an 70mm one with quality inrunner, and a 150A YEP esc I already have.
Finish will be in a simple 1984 Belgian TigerMeet scheme, which I have done a few times before ...
Edit: Video added Oct 22
F-16 70mm EDF by Freewing with WeMoTec EVO fan (3 min 17 sec)
Takes off and lands like a feather :
F-16 FW 70mm edf takeoffs and landings (1 min 14 sec)
Apr 12, 2017, 04:11 PM
Lithium Member
Herb's Avatar
Fan setup will be either 70mm WeMoTec MiniFan EVO, or a (properly balanced) 80mm FMS fan, as I discussed here earlier :
https://www.rcgroups.com/forums/show...EDF-fan&pp=100
Apr 12, 2017, 04:16 PM
Lithium Member
Herb's Avatar
Might try a Schuebeler DS-30 carbon fan in it at some point, possibly, or perhaps just the shroud to save some weight ...
Apr 17, 2017, 06:20 PM
Lithium Member
Herb's Avatar
Here's a side-by-side size comparison to my hollow molded composite JePe F-16, https://www.rcgroups.com/forums/show...by-Jepe&pp=100
which is slightly smaller (31" ws vs 35" on the FW one) and yet flew/flies on a 90mm fan
Apr 17, 2017, 06:23 PM
Lithium Member
Herb's Avatar
It's quite comparable in size to the Freewing F-104 70mm edf, https://www.rcgroups.com/forums/show...reewing&pp=100
and a bit smaller than my larger Freewing F-16 90mm, https://www.rcgroups.com/forums/show...reewing&pp=100
Apr 17, 2017, 06:37 PM
Lithium Member
Herb's Avatar
The WeMoTec MiniFan EVO 70mm fits right in nicely
Apr 24, 2017, 10:52 AM
Lithium Member
Herb's Avatar
The 62mm outlet is way too large for a decent 70mm fan setup, so that will have to be fixed, plus that step looks pretty bad.
Apr 26, 2017, 01:38 PM
Lithium Member
Herb's Avatar
Foam hinges don't work too well on fast EDF's, they tend to fly off eventually, so I rehinged everything using blenderm hinge tape.
https://www.amazon.com/dp/B00HHR4RHQ?th=1
It is the exact same one that Dubro / Tower has been selling for years :
https://www.towerhobbies.com/cgi-bin...1p?&I=DUBQ0916
Reinforcements were glued in using pu glue, and servo openings were closed with tape.
Apr 26, 2017, 01:40 PM
Lithium Member
Herb's Avatar
A simple mylar exhaust tube was cut out and secured with tape.
Apr 26, 2017, 01:41 PM
Lithium Member
Herb's Avatar
To install the fan, that plastic cheesegrater had to come out ... Also it will be easier to install the ESC if that ply tray comes out as well.
Apr 26, 2017, 01:44 PM
Lithium Member
Herb's Avatar
Mylar exhaust, 70mm WeMoTec MiniFan EVO and esc trial fitted
Apr 26, 2017, 02:46 PM
Lithium Member
Herb's Avatar
This is incidentally the stock $46 unit that comes with the 6S Freewing 12bl plastic fan / outrunner setup,
https://www.aliexpress.com/item/New-...528302267.html
3048-2150kv outrunner motor ... https://www.motionrc.com/collections/motors/freewing
I don't own one (fan or motor), so I really have no idea how it performs...
It seems rather similar to these other inexpensive "don't fit in the shroud" outrunner motors :
https://hobbyking.com/en_us/turnigy-...-70mm-edf.html
Apr 26, 2017, 07:00 PM
dusmmdb34's Avatar
Herb what motor is that in the evo?
Discussion New freewing 70mm f-16 vic0207 Foamy EDFs 6038 Oct 04, 2019 01:13 PM
Discussion Freewing 70mm F-16 V2 Mod thread/ build log Hawk Driver Foamy EDFs 123 Mar 16, 2018 08:39 AM
Discussion Freewing F-16 V2 4S-Standard 70mm EDF Jet Suko Electric Ducted Fan Jet Talk 1 Jan 22, 2017 12:55 AM
