New Product
Foxtech Devourer 130(D130)Titan Gaint Co-axis Octocopter Combo
D130 X8 Titan Version Combo is a great milestone of Foxtech product line. It can lift very heavy load with a relatively small wheelbase, combining with its folding arms and landing gears.
D130 Titan can be your ideal tools for aerophotography,emergency rescue,aero-logistics and other applications more than your wildest imagination. D130 Titan uses FOC ESCs and high power motors that ensure very fast response and very big loading capacity and a very stable fly performance within its thrust range. Being an very unique X8 co-axial multicopter, D130 has at least 20 kg lifting capacity on each arm, and each arm has enough redundancy power,so the D130 can still fly even with two motor failure on different arms. D130 Titan is equipped with dual folding landing gear system, it has enough space between the center board and the ground that can hold a red epic camera and its gimbal. The dual landing gear system can also sustain some impact in case of a hard landing, which can not be done with those single landing gear system. You can also ask for a customized D130 Titan multicopter,with a strong technical team, Foxtech is able to design and build the parts you need that should be able to make D130 able to lift heavy load over distance, or to be an agriculture sprayer, water gun drone, illumination drone and any other drone types that you can imagine. You can get more specs info here: https://www.foxtechfpv.com/d130-x8-titan.html Welcome to join facebook D130 group:https://www.facebook.com/groups/1034...?ref=bookmarks
Latest blog entry: Foxtech Five Oblique Aerial Cameras...
D130 Titan on the Set.
There are two options for D130 Titan:
ARF Purchase Includes: -1x Foxtech D130 X8 V2 frame -8x XRotor 8120 100KV FOC ESC HV Combo -4x Foxtech Supreme C/F Propeller 3010T -1x DJI A3 Flight Controller -1x Foxtech 300A Ultra Power Distributor -1x D130 Gimbal Loading Kits -1x Plug/Cable/Wires/Shrink Tubing etc -1x D130 Dual Landing Gear RTF Purchase Includes: -1x Foxtech D130 X8 V2 frame -8x XRotor 8120 100KV FOC ESC HV Combo -4x Foxtech Supreme C/F Propeller 3010T -1x DJI A3 Flight Controller -1x Foxtech 300A Ultra Power Distributor -1x D130 Gimbal Loading Kits -1x Plug/Cable/Wires/Shrink Tubing etc -1x D130 Dual Landing Gear -1x Futaba 14SG Radio Control Optional: -Foxtech D130 Canopy -Foxtech Motor Cover -Foxtech Foldable GPS Seat -Foxtech 6S 22000 Lipo Battery -Futaba 18SZ 2.4Ghz Radio Controller |
folable props are under testing on D130
Foxtech Supreme Foldable 30'' Prop Stable Test
Thread Tools | |
Similar Threads | |||||
New Product | Foxtech Devourer 130(D130) V2 Co-axis Octocopter Official Thread | glassfox | Multirotor Drone Talk | 815 | Jul 05, 2017 12:10 AM |
Discussion | Foxtech Devourer 130(D130)Titan Version Co-axis Octocopter Combo Introduction | foxtechtech | Multirotor Drone Power Systems | 6 | Apr 11, 2017 01:45 AM |
News | Foxtech - The Devourer 130 | Jim T. | Multirotor Drone Talk | 12 | Jul 01, 2015 09:15 AM |
