Apr 15, 2017, 04:06 AM
Plane crazy
Tartago's Avatar
Originally Posted by Groovechampion
What do you guys think? Would a dual 50mm setup work in this>?
I will check the dimensions when my plane arrives
Apr 15, 2017, 05:26 AM
Plane crazy
Tartago's Avatar
The Su-30 is also nice:
Su-30SM Russian Knights Team @ LIMA 2017 (6 min 59 sec)
Apr 15, 2017, 09:08 AM
Fly,Crash, Burn,Fix, repeat
Gravythe Clown's Avatar
Originally Posted by shadowfox
There should be a CG indicator red dot inside a square like the ones here.
https://www.aliexpress.com/item/new-...708238613.html
Yep there are and they came on the sticker sheet not on the plane. But thanks for the link that helps me eyeball where the sticker should go. I guess that will be a good place to start.
Gravy
Apr 15, 2017, 09:17 AM
Sorry for dibble post but I couldn't edit to add pics
Here is it with 50mm edf for you guys concidering to change out. I think your going to have a hard go of putting them in. Not big enough and not enough foam to cut yo put them in the nacelles. However you maybe able to get them to fit in the hollow space were the prop goes. You'll have to cut some of the foam before or after and find a way to seal the exhaust up to the edf' and then a way to support the edf's.
Gravy
Apr 15, 2017, 11:11 AM
Plane crazy
Tartago's Avatar
Nice. Thanks GC!
One DIY with EDF
https://www.rcgroups.com/forums/show...nker-Dual-55mm
Apr 15, 2017, 01:30 PM
Micro enthusiast
Groovechampion's Avatar
Dual 40mm edfs?
Apr 15, 2017, 02:02 PM
Dual 40mm edfs?
Might not get enough thrust out of 40's
Gravy
Apr 15, 2017, 11:30 PM
Micro enthusiast
Bummer
Apr 16, 2017, 12:08 AM
edwen303's Avatar
Single pusher is just more efficient. I used to own a twin 50mm EDF Su-34, but like it better with single pusher:
https://www.rcgroups.com/forums/show...usher-LPU-only
Apr 16, 2017, 01:19 AM
Plane crazy
Tartago's Avatar
I had the same. The EDF started to deteriorate after 10 flights and after that no more power.
Apr 16, 2017, 06:20 AM
BenVK's Avatar
Bought one of these a few days ago, should arrive from the EU warehouse soon!
I really like the concept of a pusher SU-35, not that keen on EDF's and the short flight times, can't wait to fly it.
Apr 16, 2017, 09:59 AM
I have lots of EDF's and jet prop plans. The jet props are faster and way more efficient than my EDF's. I still like flying the EDF's but the prop jets get the old adrenaline pumping.
I'm almost done putting my kit together. I'm using a 2836 2200kv with 50A esc on 4 S 2700 mah 65c battery.
Gravy
Apr 17, 2017, 06:25 AM
BenVK's Avatar
Cool, please tell us how the maiden goes.
I bought a 2212 2700kv motor to use with my 3S 2200mah 40C.
I wonder if I could fit a set of retracts..
Apr 17, 2017, 07:35 AM
I am also struggling to find the c of g. Unfortunately the link doesn't work for me. Please could anyone help, perhaps with a photo? Cheers ��
Apr 17, 2017, 10:13 AM
Saturday I had experienced flyer maiden in my airplane. He was able to fly for about 5 minutes trimming it out linkage
definitely needs to be tightened up very sensitive to input power was sufficient but not sure if we have the prop on the right way or going the right way this is my first pusher plane we'll try again on Wednesday
Build Log Foamboard SU-27 SU-35 Flanker Dual 55mm carcynic Scratchbuilt EDFs 71 Mar 15, 2018 10:48 AM
su 35 pusher conversion supershuey Pusher Prop Jet Models 6 Dec 04, 2017 08:24 PM
New Product SU 27/35 from hobbyking bandetlol Foamy EDFs 9 Apr 12, 2017 11:33 AM
Discussion Su 35 3D pusher jet kiko popo Foamies (Scratchbuilt) 11 Mar 05, 2014 02:57 PM
Discussion 3D su 35 pusher jet kiko popo 3D Foamies 2 Feb 28, 2014 11:36 AM
