Nov 15, 2017, 09:05 AM
StatGSR's Avatar
^ have you checked your prop installation and rotation direction?
Nov 16, 2017, 03:37 PM
AcroRC
HI every body
I would like to know if someone has managed to put a couple of EDfs?
If you can put photos and information on how you have done it?
Thank you
Nov 18, 2017, 12:06 PM
Deadguy's Avatar
Hi there, this is my new MkII before tomorrows maiden. It will be a sleepless night
Nov 23, 2017, 12:01 AM
what ya mean i have to land?
Got the SU done and put the prop on.Went in the backyard and checked the motor out.Think I started every dog within a 3 block area start barking.Sounds good tho.Already cut some foam around the prop.Gotta wait for weather to maiden
Nov 24, 2017, 04:18 PM
BenVK's Avatar
Looks great Deadguy, I dig the paint scheme.
oly_rcer, can't believe you actually like the sound! It gives me a bloody headache so I've been experimenting with how to reduce the noise.
I don't know if you guys have heard of Q-tip props? I hadn't until I looked into it. The curved over tip design is meant to reduce the turbulent airflow around the tip of the prop and therefore reduce noise.
I tried it out by heating some cheap props and bending over the tips and it definitely works but not as much as I hoped. Plus no one makes a Q-tip propeller in the 6 to 7 inch range so it's DIY time and modifying props so drastically always scares the crap out of me even if I carefully balance them afterwards.
Nov 28, 2017, 03:39 AM
MigLovin'
I haven't read every post in this thread, but if nobody has said it yet; I would recommend cutting away some of the foam ahead of (and behind, if you like - but mostly in front of) the propeller to allow better airflow to the prop. This will also cut down on noise.
Dec 22, 2017, 01:33 PM
Suko's Avatar
Absolutely amazing. How did you do that? Decals or...?
Dec 23, 2017, 02:00 AM
Thanks! Car foil.
Dec 23, 2017, 03:23 AM
Suko's Avatar
Never heard of it before. Can you elaborate a bit? Do you print it like printer paper? What type of prep work is needed? How is it applied?
Dec 23, 2017, 06:44 AM
Each item has passed a photo processing program. Adjusting sizes and colors. Photos are printed on non-home printers on self-adhesive PVC film. This technique is used in advertising. For inscriptions and pictures on cars. The foil used is ORAFOL. I cut my pieces with scissors. The foil is thermoplastic. When the foil is heated with a hairdryer, it becomes softened. Using a spatula, he presses to cling to the plane. The film increased the weight of the aircraft by 80 grams.
20171223 132357~1 (0 min 57 sec)
I apologize for my bad English.
Dec 25, 2017, 03:14 PM
Plane crazy
Tartago's Avatar
Excellent finishing!
What software did you use?
Is it possible tha t you share the file?
Dec 27, 2017, 02:00 AM
I used a Photoshop. I'll upload all the files ready to print. I need a little time to finish them. What's on my plane is the working version.
Yesterday, we made several flights with the plane. With a few settings, the plane flies. Planning well. When the throttle increases, the plane crashes the nose. Has any of you had such an airplane behavior? And how is the problem solved?
Dec 27, 2017, 02:26 AM
Plane crazy
Tartago's Avatar
At half throttle she flies level?
Dec 27, 2017, 02:44 AM
No. From the beginning. He constantly wants to support the elevators.
I tilted the motor up. There were improvements, but not enough.
Build Log Foamboard SU-27 SU-35 Flanker Dual 55mm carcynic Scratchbuilt EDFs 71 Mar 15, 2018 10:48 AM
su 35 pusher conversion supershuey Pusher Prop Jet Models 6 Dec 04, 2017 08:24 PM
New Product SU 27/35 from hobbyking bandetlol Foamy EDFs 9 Apr 12, 2017 11:33 AM
Discussion Su 35 3D pusher jet kiko popo Foamies (Scratchbuilt) 11 Mar 05, 2014 02:57 PM
Discussion 3D su 35 pusher jet kiko popo 3D Foamies 2 Feb 28, 2014 11:36 AM
