Castle Creations 14 Series - Sensored Crawler Motors - RC Groups
These new sensored crawler motors have a laundry list of features packed into each one! Let's take a look at the 14-Series sensored motors from Castle Creations.
Low KV Four-Pole Sensored Motors
Castle Creations just dropped the proverbial bomb on the crawler market with announcement of the new 14 Series sensored motors. These 4 pole brushless motors are perfect for rock crawling, scale and off-road trucks, and even Ultra4 "Hammers" style rock racers and bouncers. There's a whole lotta tech packed into these motors, so let's take a look at their features.
Torque and Control
The 14-Series motors offer monsterous torque and precise throttle control: two things required for rock crawling. Their 4-pole 12-slot design offers up improved heat dissipation and great efficiency.
QUIETSENSE Technology
The 14-Series from Castle Creations come with QUIETSENSE Technology that shields the sensors from magnetic field noise to deliver precise startups and higher precision while driving. Additionally, conformal coated sensor boards offer exceptional waterproofing.
Castle Link-3
When paired with the Castle Creations X-Series ESCs, the 14-Series motors offer multiple modes such as Crawler Mode, Rock Race Mode, and an adjustable drag brake that can be adjusted from a 3-rd channel on your transmitter on the fly, when using the auxiliary wire.
CLICK HERE for more info on the new Castle Creations 14-Series Crawler Motors.
Specifications:
  • Input Voltage Range: 3S-4S LiPo
  • Kv: 1900 -3800 (depending on motor)
  • Max. RPM: 100,000
  • Size: Length: 49.5mm
  • Diameter: 36mm
  • Weight (w/wires): 197 g / 6.9oz
  • Shaft Size: Length: 15mm
  • Diameter: 1/8" (3.17mm)
  • Mounting Hole Specifications: M3 @ 25mm
  • Cooling Fan: Optional - Coming Soon
  • Connectors: 4mm male Castle Bullet Connectors
  • Items Needed for Operation: Compatible Electronic Speed Control (ESC)
  • Application Guidelines: Ideal for 1:10 scale rock crawlers on 3S-4S and low speed setups on 1:10 scale touring cars, stadium trucks or buggies.
  • Recommended ESC(s): Mamba Max Pro, Mamba X, Mamba Micro X
Video
Check out this demo video, showing how slow the 14-Series motors from Castle can turn. That's precise control!
ROCK READY - Castle Creations LOW KV Crawler & Scaler Series (1 min 56 sec)
Apr 11, 2017, 06:53 PM
would be awesome if this breathed a little life into the dead comp crawler scene.
Apr 11, 2017, 09:03 PM
Destroy's Avatar
Not sure I'd want this. Don't brushless tend to have issues with cogging at low rpm?
Apr 11, 2017, 10:22 PM
RCG Admin
Jason Cole's Avatar
Not with sensored motors like this. It is so smooth. The first time I drove a sensored motor was a Losi 22 and it blew me away.
Apr 12, 2017, 01:27 AM
fATAL's Avatar
They should advertise for Wildlife photography rovers, Why use a telephoto lens when, you can creep up on those P Dogs! I could see them... "Oh!, Im sure it moved this time!"
Apr 12, 2017, 06:53 AM
RCGroups Editor
Matt Gunn's Avatar
For a long time, Novak was the only sensored brushless rock crawler motors. They performed similar to any 55 turn lathe motor, but had extremely accurate movement down low and we're very efficient. I'm glad Castle Creations has offered another solution.
Once you try a sensors brushless crawler setup, you'll never go back to brushed.
Watch that video in the article; that should answer your cogging question.
Apr 17, 2017, 10:00 PM
KE Spins make me dizzy.
I might end up making a 6s crawler setup with that 1900kv motor
Apr 24, 2017, 10:51 PM
Looking for a Sensored brushless motor for my RR 10 W/2speed and 3S Lipo's
1 for crawling and 2 for running with Grand kids and the dog
I'm not sure what Kv is best for my stile driving ?
Not really sure how the KV numbers work
Any help would be appreciated
News Castle Creations Inc - Sensored Motors Jim T. Graham Car Talk 3 Nov 03, 2016 05:21 AM
Question Castle creation motor and esc with power supply Isti Castle Creations 0 Mar 21, 2016 12:48 AM
Discussion Tenshock Rock Crawler RC906 6 pole 1250kv Motor for 1/10 1/14 Crawler tf boy Rock Crawlers 0 Feb 14, 2016 03:44 AM
Castle Creations CM-series. TipStalled Electric Ducted Fan Jet Talk 2 Oct 03, 2005 01:34 PM
Castle Creations - New Phoenix HV series of controllers! Dave Lauck Product Announcements 4 May 11, 2005 01:53 PM
