Faulty PL8 or user Error...?? - RC Groups
Apr 10, 2017, 07:52 AM
I think I may have a faulty PL8 - However before I raise a service request etc, I thought I'd run this through with the guru's as I may have missed something obvious...
I actually own 5x PL8's with the most recent one purchased in Dec 16. This particular unit seems to be playing up and I have only noticed it playing up when charging/discharging some AA and AAA NiMh cells.
The problem is that it seems to have very erratic charge and discharge ramps and it sometimes it even fails to reach the set discharge current. I suspect that it has been faulty since day one as Lipos seem to charge OK and I only noticed this when playing around with inconsistent bump controller results when charging my NiMh cells (Sanyo Eneloops).
Things I have tried so far:
  • Reset to factory settings
  • Reloading of library presets
  • Using inbuilt default preset for NiMh
  • Using my own custom preset
  • Downgrading firmware and then reloading current v3.33
  • Changing power supplies
  • Loading the exact same presets and options across all 5 chargers
  • Using exact same leads and battery for all the tests when testing with all 5 PL8's
My other 4 PL8's seem to behave as expected when charging and discharging the exact same battery - I have attached some jpgs to compare with one of my good PL8's Vs the suspect unit.
Tests carried out charging 3x AAA NiMh cells in series @ 200mA and discharging the same cells @ 300mA. The exact same cells were used in these tests to generate the graphs and highlight the problem.
BTW - One other irregularity I noted is that when testing/discharging at a relatively low current of 200mA (3x AAA cells), my 4 good chargers do not have the fan switch on at any stage - which is as expected. The suspect charger however runs the fan pretty much as soon as I start the discharge cycle...???
Any ideas? - I reckon its kaput but may have missed something...!
Attached thumbnails show total current in order of 'Good PL8 Charge ramp' - 'Suspect PL8 Charge ramp' - 'Good PL8 Discharge ramp' - 'Suspect PL8 Discharge ramp'.
Note how the charge/discharge curves for the suspect unit are all over the place as compared to one of my 4 'good' chargers.
Apr 10, 2017, 07:56 AM
Good detective work. I'd recommend opening a support ticket:
http://www.revolectrix.com/support_options.htm
Apr 10, 2017, 08:04 AM
My background is in Electronics - so that helps....
I'm located DownUnder - I'll log in to their website in the next day or two and initiate support from there.
Probably have to return it to Singapore - Still under warranty....
Apr 10, 2017, 07:31 PM
Does anyone know where the serial number is located on these units....?
I thought it was the number stamped on the bottom of the case however this unit does not have any numbers stamped on the bottom of its case..????
Apr 10, 2017, 08:29 PM
I'm not aware they have a serial number.
Apr 11, 2017, 04:53 AM
All my older units have a number stamped on the bottom of the case which I casually thought was the serial number.
Upon closer investigation today, the number is the same (1222) across multiple PL8's that I own, so I guess it is not a serial number...
Anyway I have raised a 'case' number/request with Revolectrix for them to have a look at my findings and initiate a return/repair etc
I have pointed them to this thread in the case notes - I wonder if they will refer to it as I could not attach pics in the case notes?
I will submit my detailed findings with the unit when I return it anyway. Always handy for the repair tech to have more info than required for prompt fault diagnosis rather than the standard 'It's Faulty' label attached to equipment....
May 11, 2017, 01:00 PM
Unregistered User
vimy g eaou's Avatar
Costas, how did you go with the PL8 fault?
