Apr 10, 2017, 05:41 AM
nitbeat's Avatar
New Product
Matek F405-OSD BetaFlight STM32F405 Flight Controller /w 32khz Gyro ICM20602
New F4 + Betaflight OSD with the new gyro sensor: ICM20602 that supports up to 32khz refresh rate !
Matek F405-OSD BetaFlight STM32F405 Flight Control Board Built-in OSD Inverter for SBUS Input
http://www.banggood.com/Matek-F405-OSD-BetaFlight-STM32F405-Flight-Control-Board-Built-in-OSD-Inverter-for-SBUS-Input-p-1141282.html
Betaflight Target (thanks SextonVBG):
Originally Posted by SextonVBG
https://github.com/betaflight/betaflight/wiki/MatekF405
I think it will be available in next release
* I wish they chose to add 1 more inverted UART for smart port but I guess only SBUS will have one...
Specification
Brand: Matek Systems
Item name: Flight Control Board
Mounting hole: 30.5mm
Weight: 7g
MCU: 168MHz STM32F405
IMU: 32K ICM20602 accelerometer/gyro (SPI)
OSD: BetaFlight OSD w/ AT7456E chip
Blackbox: MicroSD card slot (SD/SDHC)
PPM/UART Shared: UART2-RX
Battery Voltage Sensor: 1:10
Currsnt Sensor: No (FCHUB-6S option)
BEC 5V & 10V: No (FCHUB-6S option)
LDO 3.3V: Max.300mA for Spektrum RX
S1~S6: ESC signal 1~6
VTX: Video Transmiter Sginal
Cam: Camera video sginal
5V: Power the board from external BEC 5V or output 5V to other devices.
3V3: LDO 3.3V, Max. 300mA
4V5: 4.4~4.8V, the voltage is also supplied when connecting via USB
G: Ground
LED: WS2812 LED sginal output
Buz- & 5V: For active 5V buzzer
VCC: LiPo Voltage input, for bettery voltage detection only.
Curr: External current sensor sginal input (Max.3.3V)
Rssi: Frsky RSSI(PWM) input
SBus: Built in inverter of RX2 for SBUS input
RX2: UART2-RX for PPM, DSM2, DSMX, IBUS
RX1 & TX1: UART1
RX3 & TX3: UART3
RX4 & TX4: UART4
SCL & SDA: I2C pads
TX1, TX3 & TX4 w/o inverter, Can be used for Smartaudio or Tramp VTX directly. Non-inversion hacks must be
required for Frsky Smartport on TX1, TX3 or TX4 DSM2, DSMX, IBUS sginal can also be connected to RX1,RX3
or RX4 PPM share UART2-RX pad
Features
-Firmware based on OpenSource BetaFlight, Matek F405 Target
-Support 32K Gyro update & 16K PID Loop
-Built in inverter for SBUS input (UART2-RX)
-WS2812 Led Strip, Beeper & RSSI supported
-Micro SD Slot: support SD/SDHC with FAT32 format, but Max.4G can be used.
-2x LEDs for FC STATUS (Blue, Red)
-6x PWM / DShot outputs
-1x Group of G/S1/S2/S3/S4 pads for 4in1 ESC or ESC sginal group connection
-4x pairs of corner pads for ESC Signal/GND connections
-1x pair I2C pads
-1x Side-press button for BOOT(DFU) mode
-1x 16pin bottom mounted FFC Slot for FCHUB-6S connection
Apr 10, 2017, 06:11 AM
Coming from Matek should be hot... When I mean hot is burning problems... Another junk.
Apr 11, 2017, 07:09 AM
NoGuru's Avatar
Looks like a nice layout and packed with features. Might give it a try.
Apr 11, 2017, 08:52 AM
nitbeat's Avatar
I used a few Matek products in my life, never had any issues, often very popular products gets bad reputation because so many people use them. I had many Matek PDB's, LED strips, other products like Lipo -> USB hub and more....
I guess you're talking about burning problem in their PDB's ?
Apr 11, 2017, 09:41 AM
Yes and lots of caps needed to work properly, very poor designs and quality in PDBs.
Apr 11, 2017, 01:57 PM
Physics, or is it fizzix?
flyandride's Avatar
I don't see a Betaflight target for a Matek F405.
Apr 14, 2017, 11:14 AM
Apr 18, 2017, 06:09 PM
nitbeat's Avatar
Thanks, good find I'll add it to the main post
May 10, 2017, 03:23 AM
It just came available on BG: https://www.banggood.com/Matek-F405-...p-1141282.html
Really looking forward to use it together with the Matek FCHUB-6S. Seems like a solid combo. Loved using Matek products in the past. High quality products for a good price.
May 10, 2017, 06:45 AM
Add to cart with FCHUB-6s
May 12, 2017, 10:55 AM
moophus's Avatar
has the noisy ICM20602 been fixed? this video is from 5 months ago
edit:nevermind
May 12, 2017, 02:57 PM
edit:nevermind
The 20602 gyro run to 32k, not 6050...
And new furious FPV Fortini F4 use the same gyro !!
May 14, 2017, 05:13 PM
nitbeat's Avatar
thanks for the update, I do agree Matek has a good reputation IMO
May 21, 2017, 10:45 AM
Hey there,
sees like softserial supports inverted telemetry, which can be set to S5 / S6
Enable SoftSerial_TX on S5 or S6 pad
Type “resource motor 5 none” in CLI, ENTER,
Type “resouce serial_tx 11 A15” in CLI, ENTER
Connect the inverted telemetry signal to S5 pad
Source: http://www.helipal.com/mateksys-f405...ontroller.html
The FC is under restocking on BG, I'll try one soon.
DanO
May 21, 2017, 02:57 PM
run
run
run's Avatar
i think myrcmart has them... i've had really good luck and really fast shipping with them so far:
http://www.myrcmart.com/matek-flight...d-p-11218.html
