Apr 07, 2017, 08:26 AM
Not a noob but I'm stuck on a VERY simple issue
Had a bit of a break from flying and realised you forget everything when you come back!
Receiver tab in betaflight all looks good, full travel of inputs from 1000-2000. In motor tab the motors will only start when i push the slider over 1500 or so.
This feels like a REALLY simple issue but I cant find any solution?
On configuration tab the min throttle is set to 1000, max 2000 and min command 1000. I have calibrated the ESCs by connecting battery with slider full but then as i reduce input i hear it beep at around 1500 (i guess finding its "minimum"). Why is it doing this? Why?
Apr 10, 2017, 06:04 AM
It seems ESC Calibration. Have you try motor by motor?. Can you change to dshot?
