Apr 06, 2017, 10:47 PM
FlySky FS-i6 firmware
Hello All, I just want to know if my FS-i6 transmitter has the latest firmware. I tried the internet but could not get a definitive answer. I bought it a month ago so since this is 2017 I suspect there must be an update. My version is
1.1 27-MAR-2015.
Oct 15, 2017, 08:35 PM
jecchile's Avatar
1.1 27-MAR-2015.
I have the same firmware... bought my radio August of 2017... have not been able to find which is the latest version, only thing I have found is an update to convert it to a 10 channel radio which is something I don't care to do.
If you find out, please let me know... Thanks.
Oct 15, 2017, 10:35 PM
Jecchile, If you bought your i6 new so recently with the same firmware as mine, then it must be the latest. I would like to update mine but I'm afraid of bricking it. I haven't heard of anybody updating successfully. Have you?
Oct 16, 2017, 06:44 AM
jecchile's Avatar
There are quite a few posts on Youtube which indicate that it is OK to update to the 10 channel Mods. I just don't have the need for it. 'I also have a Hitec Eclipse 7ch Pro, a great radio, which I use for my airplanes. Never have used more than 6 channels... I bought the FS-I6 for my quads.
Regards
Nov 07, 2017, 09:07 PM
The easiest way is to use the official firmware update cable to update the firmware, but unless you want to have extra channels or need a flight timer or want to increase the 1min no usage beeper to 10 minutes I see no reason.
If it ain't broke, don't fix it!
Nov 08, 2017, 06:00 AM
jecchile's Avatar
Thanks OlderDan... I decided not to do anything to the radio as it works just fine... You are so correct by saying "If it ain't broke, don't fix it"... many times one tries to update/fix things and the work turns out sour.
Happy flying.
Nov 08, 2017, 07:12 AM
OlderDan, I agree. "If it ain't broke, don't fix it". But if you want more channels, Flight timer etc. for only the cost of an update cable, Why not? I am still looking for that you tube or article that tells me the exact software to use that's "OK" to flash my i6.
Nov 08, 2017, 08:07 AM
There is two different firmwares, this one is the most current 10 channel firmware https://github.com/benb0jangles/FlyS...rogrammer_V1_5
And this is the firmware with the timer mod https://github.com/benb0jangles/FlyS...rogrammer_V1_4
Nov 08, 2017, 09:40 AM
OlderDan, Dan, thanks a bunch. Can't wait to brick it. uhh install it.
Apr 23, 2018, 07:20 AM
Help please!!
I recently bought my flysky fs-i6 transmitter the included receiver is fs-ia6 now we know that it doesn't support the RX voltage sensor because of the crappy way the receiver is designed but I come across a video on YouTube on how to hack it up and get it to work now after a few weeks it works fine but now it doesn't show up at all the only thing
I can see is the Tx.V1 what seems to be the problem ,is it the transmitter or the reciever? I tried reseting it using the system menu and the other hidden menu but still nothing.
thanks in advance:😀😀😀
Sold FlySky FS-I6 with 2 RXs, 10 channel firmware RickyRoss Aircraft - General - Radio Equipment (FS/W) 2 Mar 16, 2017 07:36 AM
