Tamiya Mercedes-Benz Arocs 3363 6x4
The new Mercedes-Benz Arocs 3363 6x4 is a 1/14th scale tractor truck from Tamiya, and the first in their lineup that features a narrow body European design.
The First Narrow Body European Tamiya Tractor Truck
The lineup of scale 1/14 tractor trucks grows larger with the announcement of the new Tamiya Mercedes-Benz Arocs 3363 6x4. This is the first narrow body European truck in the series, and it's scale details are quite impressive. The modern form of the Arcos is captured in the ABS plastic body and metal chassis components. The Tamiya Mercedes-Benz Arocs 3363 features six wheels, with the four drive wheels getting power from a front mounted brushed motor. A multifunction unit is available for realistic sounds and lights, and requires a 4-channel transmitter with analog trim for the MFU to work. The Tamiya Mercedes-Benz Arocs 3363 retails for $429.85 and is scheduled for availability in late May 2017.
CLICK HERE for more info on the Tamiya Mercedes-Benz Arocs 3363
Features:
  • Length: 529mm (20.82 in), width: 190mm (7.48 in), height: 267mm (10.51 in)
  • The narrow body of the ClassicSpace variant Arocs 3363 is recreated accurately using newly-molded parts, complete with the distinctive "bucket-tooth" grille
  • Photo-etched parts recreate cab rear platform
  • Interior details include: seat and dashboard
  • 3-axle chassis utilizes a tough ladder frame with aluminum side channels and resin cross members
  • Realistic drivetrain setup sees the front mounted motor powering twin rear axles
  • 3-speed transmission can be controlled via a 4ch R/C transmitter
  • Highly realistic suspension employs metal leaf spring dampers and friction dampers
  • Coupler is included to enable connection with any currently available Tamiya 1/14 scale trailers
  • Use with Multi- Function Control Unit MFC-03 (Item 56523) (or MFC-01, Item 56511) for realistic LED lights and sounds
