Apr 05, 2017, 08:00 AM
OlliW
it's called BLHeli_32
Apr 05, 2017, 08:11 AM
will there be a buzzer(with flip of an aux switch) funktion posible with these 32bit esc?
Apr 05, 2017, 08:29 AM
Originally Posted by tbrady420
You can buy the airbot esc already on there website.
http://191.235.139.195/index.php/
I get a your connection is not secure warning when i try to check out through their website using paypal.
Apr 05, 2017, 08:35 AM
Originally Posted by myairbot.com
Firefox likes this site much, much better. Ordered 5, they better not suck!
Apr 05, 2017, 08:40 AM
Originally Posted by sbstnp
How will you or the manufacturer handle updates?
FW updates will be distributed through BLHeliSuite, the same way as before.
Parameter settings will also be like before, using BLheliSuite.
Apr 05, 2017, 08:43 AM
Is this a function of BF through dshot commands?
I haven't gotten around to implementing the BF" dshotprog" functionality yet, but it's coming close to the top of the todo list .
Apr 05, 2017, 10:09 AM
donīt think so, but remeber ther was some talk about this funktion some time ago when 32bit esc first came out.. would be nice if it was possible..
Apr 05, 2017, 10:21 AM
FPV Enthusiast
rehrlich's Avatar
Any chance to get this on the gemfan maverick 32 bit escs?
Apr 05, 2017, 01:00 PM
JulianGoesPro's Avatar
omg 32bit sexyness in it's closest form
Apr 05, 2017, 01:29 PM
Originally Posted by candy76man
15 amps
The Plus has double mosfet(12pcs. instead of 6pcs.), so will works better on high current
Apr 05, 2017, 03:31 PM
Crash specialist
pFrancisco's Avatar
Can I mount these upside down to show off the LED's without causing cooling problems with the MOSFET's?
Apr 05, 2017, 04:05 PM
The closed source thing is unfortunate. Alas, finally the common family of ESCs goes 32bit. This 8bit stuff needs to die.
Apr 05, 2017, 04:30 PM
This. This hobby has its roots in open source, and large names moving away from that is a sad sight.
Apr 05, 2017, 04:37 PM
Should be fine, a lot user already did that on BumpbeeS_RGB, seems fine.
Apr 05, 2017, 04:41 PM
depends on what you "define" as the roots... at least here in Europe the big brands like Graupner, Futaba and Co which definitely are part of the RC roots (before 2.4ghz) here in Europe were and are far from open source... not sure about the rest of the world (and when they "started the hobby")
