Apr 09, 2017, 10:34 AM
OlliW
there are also
* sapog: https://docs.zubax.com/sapog, https://github.com/PX4/sapog
* VESC: http://vedder.se/2015/01/vesc-open-source-esc/, https://github.com/vedderb/bldc
these are IMHO even advanced since they use FOC, nothing I have heard here so far
it's not like there wouldn't be options to contribute
Apr 09, 2017, 11:46 AM
Originally Posted by sskaug
Sure, the current plan is that ESCs will be validated (and serial number recorded) at the manufacturer. So when an end user gets the ESC, it is fully operational, just like any open source BLHeli ESC. For upgrade/update, BLHeliSuite will check that the serial number of the connected ESC is valid.
So it only checks on upgrades, that is perfect and about as unobtrusive as it gets. I was going off your earlier statement that BLHeli suite would always need an internet connection and assumed that meant to even change settings at the field we would need a connection.
Will definately pick up some of the myairbots escs, I have been using their bumpbees/super racer bees and they work great.
Apr 09, 2017, 11:50 AM
Originally Posted by juuuut
just for all that cry abaut not being able to contribute on a 32bit ESC FW.. the ESC32 is open for ages and done completly in C https://github.com/svn2github/esc32.. its not up to date ATM, but free for being improved by the community..
regards
Felix
Good idea , thanks for the link. I don't think all the fuss is just about code contribution. That's only a small part of an open source community. I think thousands of people have cumulatively commited thousands of hours of support and feedback via forums and github to make blheli what it is today.
Apr 09, 2017, 12:13 PM
DOLLA DOLLA BILL YALL
quad007's Avatar
Originally Posted by OlliW
there are also
at a minimum i would think blheli_32 should use bipolar complementary pwm, but it seems they're still only pwming one side
Apr 09, 2017, 12:17 PM
Originally Posted by JulianGoesPro
I am worried they are max current protected like Kiss... that really sucks since you will get some weirdness when looking at max acceleration stats on a motor/prop combo when there isn't like a delay before the "current limit" kicks in...
Some BLHeli_32 escs will have current limiting support in hardware, some will not. But it can always be disabled. Limiting current can maybe help protect against toasting escs, but it will reduce the BLHeli "snappiness". So of course it can be disabled .
Apr 10, 2017, 02:39 AM
7bpm asked previously about the max burst amp rating on the 35A and 50A wraith. I'm curious about this also. I'm about ready to make 2 builds. Would it be safe to pair the 35A version with motors like the new F40 Pro 2400kv and the Cobra CE 2207 2600kv? According to mini quad test bench they can draw up to 40-44 amps on at 100% load. I wouldn't push them too hard, but sometimes I like letting loose if it's clear fields.
Just curious what are your thoughts pairing the 35A wraiths with these newer motors? Also what protocol would be used as default? Will the dshot 1200 be available for these ESC as soon as they are released? I just ordered 8pcs of your new ESC. Looking forward to trying them out.
Apr 10, 2017, 03:05 AM
Don't worry your batteries will die way sooner than the escs burn.
Apr 10, 2017, 06:09 AM
I can't answer for the amps rating of the Wraith ESCs, Airbot can comment on that.
But as for Dshot, once a code is released, it supports fast Dshot, at least up to Dshot1200, which has been tested.
As for now, we are in a limited distribution phase where we want to test the code as much as possible before we go to a full release.
Apr 10, 2017, 06:36 AM
Sam Richard's Avatar
@ sskaug...
are this ESC legit or a scam?
http://www.banggood.com/Racerstar-Ra...087943201210XZ
Apr 10, 2017, 06:43 AM
ledge-team.com
Rust's Avatar
Originally Posted by Sam Richard
@ sskaug...
The name "racerstar" usually speaks for itself Most is rebranded low end stuff.
Apr 10, 2017, 06:57 AM
In this case perhaps, but my Racerstar 30a V2's have gone through more abuse than my LittleBee's or even DYS ESC's could handle. It really depends on the model with them.. sometimes they hit a homerun.
My question is how is this possible though? Is it? Hmm
Apr 10, 2017, 07:11 AM
aka BaronVonRiot
Hackjob's Avatar
two of my racerstar esc's died within 10 packs... ymmv
Apr 10, 2017, 07:35 AM
"Racerstar Racer33 33A 2-4S Beheli_S 32bit"
Its running BeHeli! I wonder if that's like BLheli?
Apr 10, 2017, 07:46 AM
@ sskaug...
As of now, it is scam. Because there is no BLHeli_32 code released yet. But also they are not yet available.
So maybe it will be legit and available once code is released.
Apr 10, 2017, 07:50 AM
cyrilfpv
lostcontrol's Avatar
Sounds like you don't want to disclose something
