Linux install OpenSSL issue when trying to flash ESCs
Hi!
I have Ubuntu 19.04 installed on my computer, so I appreciate it very much that there is a Linux version available. I have a problem when I try to access the internet (e.g. flash new firmware, check for updates). It tells me in a pop-up that it's missing the OpenSSL library or I have a wrong one installed. Does anyone have an ideo on that? Thanks in advance! |
Stupid question but with the latest stable version of BLHeli_32 which is currently 32.7, can we run custom starting tones and bi-dir telemetry? Or should we forget about using starting-tones?
As far as I know, it shall be possible to combine music and bidirectional dshot.
Thanks for your answer, i will give it a shot as soon as i can reboot on Windows since the last Linux beta release of BLHeli Suite 32 is giving me some issues on my GNU/Linux Debian 10
How to recover a blheli32 when the computer locks in the middle of the update? Now only 3 escs are detected from a 4in1, with Arduino?
That does not work, does Arduino work? Like the older blheliS?
Not sure if this was addressed, only the #1 esc will let me save music on?
I have a few more technical questions,
Regarding active freewheeling: are there reverse diodes in all ESCs in case this is disabled? "Power limited to X%" .. this is relative, right? For example if thermal protection limits power to 25% then if the motor is heavily loaded the "limited" current through the motor could be higher than "unlimited" current through an unloaded motor? Low RPM power protect: what is considered low RPM, low Kv, low supply voltage? PWM frequency: what is meant by humps in throttle response as mentioned in the manual? But more importantly, what do you think about the suggesting of using a low PWM frequency with high inductance motors? |
My quad (4006-380kV, 15 inch, 6S, Furling32 F3) runs butter-smooth in all scenarios bar one.
If I do a fast descent - with PWM around 1200 - and I try to stop it sharply with throttle, it wobbles a couple of times before restabilizing. Where should I start tweaking values ? |
