Fixed wing Vector Closed Loop Flight Mode - RC Groups
Apr 02, 2017, 07:23 AM
Question
Regarding this new and Experimental mode I would like to ask if Closed loop flight mode will be disabled when passing the switch from 2HS to 2D
Supose I am flying on 2DH+Speed and then switch to 2D no Hold ... will the closed Loop be disabled ?
On the addendum manual there is an alert ........>>>
Selecting a closed loop flight mode will result in the propeller spinning at its maximum speed, even on
the ground, if the model is moving more slowly than the commanded speed, when closed loop is armed
and the throttle is in any position other than off!
.....>>> on the 1.5.4.3 Closed Loop Flight Mode Fallback there are no reference for changing mode but I think I could assume as it should be DISABLED.
Could JohnET or some one with experience on this subject please clarify?
Regards
JMCN
Apr 03, 2017, 09:27 AM
JohnET's Avatar
Hello,
Closed loop does not affect 2d no hold. You still have direct throttle control in 2d no hold.
Regards, John
