5087 servo - RC Groups
Mar 31, 2017, 10:32 AM
Ohio AV8TOR's Avatar
5087 servo
I ordered a set of these for my new Extreme Flight 52" Slick. My Gecko 85 ESC just has 7.4 and 8.4v for HV options. Is a steady diet of 8.4v okay for the 5087 or better to set at 7.4v? I ask because I read some negative comments about servo centering and that higher voltage helps. I don't want to reduce the servo lifespan in doing so.
Apr 03, 2017, 01:25 PM
Xpress..'s Avatar
Shouldn't have a problem operating them at 8.4V, they are rated for it.
Apr 03, 2017, 01:35 PM
Thanks for the reply.
I sure wish the industry would provide a max safe voltage. I would even think the speed and torque would show better numbers as well. A 2S battery will lose voltage where by a BEC set at 8.4v will stay at 8.4v.
Apr 03, 2017, 03:58 PM
Xpress..'s Avatar
Max safe voltages on any of our HV servos is 8.4v, for our 6.0v servos I would not exceed 7.2v. There's 2 reasons we use nominal voltages for ratings:
1. Batteries are rated at nominal voltages, not fully charged voltages.
2. You will know how the servo performs when your battery is under load.
Apr 03, 2017, 04:02 PM
Thanks for the clarification.
Apr 27, 2017, 02:37 AM
Altitude is my friend...
Depronicus's Avatar
Annoyingly, you can't set the voltage on a Castle Creations BEC Pro at 8.4. Only 8.5 is available.
That extra tenth of a volt is not a problem, right? Seems like it wouldn't be.
Apr 27, 2017, 07:34 AM
That is incorrect, the BEC Pro output voltage is adjustable from 4.8v to 12v and in the range for our HV servos you can select 7.5v, 8.0v and 8.5v. Set it at 8.0v and your golden
Apr 27, 2017, 12:45 PM
Depronicus's Avatar
Of course 8.0 is available. I didn't say it wasn't. I said 8.4, which is what I want to run the servos on, is not available.
Apr 27, 2017, 12:59 PM
Sorry I miss interpreted your line, "Only 8.5 is available"
Apr 27, 2017, 06:29 PM
Xpress..'s Avatar
8.0v is plenty, I doubt you'll feel much difference between 8 and 8.4v.
Apr 28, 2017, 06:14 PM
Depronicus's Avatar
Okay, I'll stay with 8.0.
For Sale 4 Hitec MH servos (1 5087 / 3 5070) propchief Aircraft - General - Radio Equipment (FS/W) 0 Nov 19, 2016 08:31 AM
