SE 5 Swap Pod Series - Page 2 - RC Groups
Apr 04, 2017, 05:20 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
This was the SE5 flying today, I had a few more flights with her (not recorded) and then the last flight was almost a disaster ... no damage done ... last segment on the video
Don't know why my videos are going black when I clip or add a bit of another video, so I have added another video with the SE5 near crash
Lockey
3rd flight of the SE5 and almost a 4th flight (5 min 2 sec)
Mini Magic and SE5 almost disaster (3 min 2 sec)
Apr 04, 2017, 07:07 AM
scorchythebear's Avatar
Looks like a lovely day for it.
Bit of a shame about the last one but at least nothings broken! Will you be installing an extension on the front?
Apr 04, 2017, 12:10 PM
Lockey's Avatar
Not that easy to do now Adam, maybe I will just have to make sure that I use a slightly bigger battery ... the 1300 BOLT battery seemed to be heavier and help with the balance
Lockey
Apr 12, 2017, 07:18 PM
Lockey's Avatar
I gave my little pilot a head rest, his neck was beginning to ache
Lockey
Apr 12, 2017, 07:40 PM
It's a little cutie pie that is i like the head rest and the pilot.
The staggerwing could probably carry an SE5 under each wing!
Apr 14, 2017, 08:14 PM
Lockey's Avatar
I bonged the nose of my little SE5 ... doing inverted too low AGAIN ...
I so I fixed it and extended to length of the nose by 20mm, a bit more room for the batteries now and can use the 1000/3s as I can get it further forward to balance the CG .. and of course the pod is further forward too ... not a perfect repair but good to go again
Marking the position of the blind nuts presented a bit of a dilemma, so I made a simple paper pattern of the bottom of the pod with the holes (blind nuts) and cut-out for the battery connector and then transferred it to the ply base .. worked very well
Lockey
Apr 14, 2017, 11:59 PM
Lockey's Avatar
As I see it ... this is the only trouble with the "Swap Pod" idea on smaller models ... finding room for all the bits and battery
Lockey
Apr 15, 2017, 12:24 AM
psychedvike's Avatar
It looks like you have a really fun plane there. How is the T 28 coming along?
Apr 15, 2017, 01:07 AM
Lockey's Avatar
Just posted new pics https://www.rcgroups.com/forums/show...0#post37319781
Lockey
Apr 15, 2017, 01:36 AM
Lockey's Avatar
Wonder how the stagger wing will stack up against the little SE-5 ?
Wonder if I should give it dihedral and elevator / rudder only like the SE5 .. or add ailerons and keep the wings straight ?
Lockey
Apr 15, 2017, 02:28 AM
Lockey
I think I'd go with the ailerons and straight wings, but your the master. I'm sure how ever you do it, It will fly great.
Apr 18, 2017, 07:19 PM
Lockey's Avatar
If anyone is interested, I have started a list of supplies I use on most of my builds ... it might help some of the newer guys to scratch building .. most I buy from Hobby King (cheap and easily accessible) but similar items are available elsewhere .. try E-Bay you can get some good bargains with free shipping
https://www.lockeysrcplans.com/supplies
Lockey
Apr 19, 2017, 10:16 AM
When cows fly!
Great way to advertise your website Lockey!
Apr 19, 2017, 11:03 AM
Lockey's Avatar
REALLY David, hadn't thought of that ...
Lockey
Apr 20, 2017, 03:52 AM
Lockey's Avatar
Stagger Wing Bipe (Swap-Pod) is almost finished
For some reason, this one uses just a bit over a sheet
Lockey
