Yeh I have my batt wires strapped under and actually touching the 8 channel RX. No other of my XPS installations do that.
I will make changes and report back. Its so refreshing to get help from the owner himself! This why I have been very happy XPS customer since 2008ish!! I have flown helis for many years but can't solo a rc plane yet! Im very excited to tweak my wires and finally solo this trainer! I think I'm on right track now! But I also will check orange led and power off like ya said! |
I powered everything on till I could move servos and then unplugged power from RX with TX left on. Plugged back in the RX always blinks orange and tattle tale stays solid green. I did find a damaged aileron plug almost letting the contacts touch which I fixed. I moved RX and wires and made some tweaks so I will try to fly this again!
http://www.big-mick.com/uploads/edit...gqmld1knrd.jpg http://www.big-mick.com/uploads/edit...drany87ig5.jpg |
Close call last flight
Plane still glitched/ failsafed 3 times during its last flight! Damn! I thought i had it fixed! Did y'all know up elev with left rudder failsafed together will instantly KILL all lift under the left wing??? Who's the ass that set that up?? (me!) I fought it each time that last flight with my failsafes trying hard to lose altitude and crash me each glitch! My instructor Brett couldnt get my neck strap disconnected so he asked to fly it then stepped in and grabbed my Tx and pulled my face over his shoulder! Two grown ass men standing WAY too close to each other! He landed it like a boss! I had a few heart attacks during that flight. But it lives on to get this right and solo this plane! Im putting all blame right now in my molex 8 pin shunt thingy i installed between a123 2300mah batts and rx. ..im starting from sc ratch and will post here as i go. Positive take aways is my fuel and engine system is spot on! |
Yeh i added my 8 pin molex shunt idea to my heli which was reliable till then....it failsafed on heli pad, all coontrols hold wngine to idle, slow mo tipping over with its XPS 10 channel blinking orange..minor damage slow headspeed luckily.
Wait let me be honest that heli slowmo tipped ovr two times in 2 weeks! I didnt realize some molex pins vibed out till after second crash. This happened same day as exciting plane flight |
Ok the lil wood rx shelf I had made onto the airplane frame sidewall (pic somewhere here) was only partially glued down. So I had my 8 chan Rx strapped to shoddy shelf! I said Im now going through this plane meticulously!
Im making a SOLID Rx mount (LT-40 didnt have a good spot at all for the rx in the plans build) Im moving it as high as I can in the plane. Im giving the older tech 8chan XPS its best chance to blow my socks off in this plane like it always have in my helis! I know I can just swap in a RFU or nano right now and most likely be issue free due to their newer tech. But I'd still wonder why a 8chan didnt work in my plane? Would the newer XPS tech just be a "band aid" over my problem? So if doing things by the XPS book gets my 8 channel happy then I KNOW a RFU or nano will be extremely happyin my new RX location yes? |
Garland,
Yes, if the 8ch is happy, so will the Nano and RFU. I had my 8ch XPS receiver on a shelf high up in the fuse just under the wing in a plane similar to an LT-40 and it worked well. Note that you need another device called the X10+ to work in conjunction with the RFU. The RFU has a single output that plugs into the X10+ and the X10+ in turn provides connections to the servos. The X10+ is also where you connect power for the receiver and servos. The Nano includes servo output pins. Paul |
Thanks Paul! I have nanos, a X10, and a RFU new in package here. I will probably install a nano in this plane later as I think a RFU is over kill in a trainer plane.
If I can get a 8channel happy then Id prefer that choice. Ok I made my shelf and Imade a window so I can see what my RX is doing! Let me know what ya'll think on my install! |
Ok today I'll resolder all the module pins on my 8U and 9C radios. These radios have been good to me but they never have seen a service dept and I bought them in 2001. Spending almost 100$ Each to have them looked at (not parts or any possible repairs) when they worth less then 100$ doesnt make $$ sense. So the last thing I do to them will be cheap insurance on their module pins by resoldering all of them.
I just bought this brand new! Hitec Aurora 9! But XPS is closed a few weeks moving so no module for it yet! BAD TIMING ON XPS PART! ![]() What ever glitch I am having I will find and fix it! |
I'll update this thread
Work has been crazy past few months but Im determined to get this plane reliable this season! Ok shortly I will have 2 new hitec Aurora9s on XPS modules. I have RFU , nanos, 8 chans, 10 chans, old parkflyers 6 chans rx, or even 8 chan sailplane rxs standing by in case the current 8chan rx in this plane, and it was sent off to XPS last year to check out then returned to me, acts up this season also. Failsafes are set and I will re verify as I program these radios. I know throttle gets failsafes...rudder too if I remember. I dont think this RX actually bad not sure though yet. There are dual A123 2300 6.6v RX packs in this plane and ALL puny battery 28guage wires currently to RX will be removed and upgraded to 16guage (14 gauge if needed) with sermos connectors. No switches anywhere. Hitec HS-311 servos all around. Beyond these changes Im running out of ideas. Note my new RX location I cant get it any higher in the plane. I can fly helis but never soloed a plane or line one up on runway for landing. I have a trainer cord coming and i SOO hope to solo this LT-40 i built from a kit this season! |
Just remember that you can never get "uncommanded" input from any 2.4Ghz system, and if anything is blinking it is caused by the reboot notification which deliberately blinks when the receiver re-establishes connection after a complete loss of power. Blinking will never occur if power has never been lost.
This season the 8 chann RX will be mounted up high and I have a window to see LED on RX which I never had last year. A tattletale will also be mounted outside of the plane. Last year I think I had a futaba 8U/9c to XPS module issue and I did some pissy battery molex mods .
Thanks JD! |
other like two sets of knuckles back to back. Contact is held by the springiness of the plastic casings. there is a weak point in the design where the casing will crack , thus removing the pressure on the contacts. point two; the little tab that holds the contact in the casing can and does sometimes fail to grip when joining the contacts, this allows one contact to push the other contact back instead of sliding over each other. all my sermos connectors went straight to the bin. Maybe an over-reaction, but I am careful with electronics, been flying since 1952, R/C since 1957. case to point, I still have and fly my first electric plane from the days when sub-c Nicads batteries were the top of battery technology. |
