Mar 27, 2017, 03:46 AM
Careful!
Foxtech Devourer 130(D130)Titan Version Co-axis Octocopter Combo Introduction
D130 (Devourer 130) Titan is a great milestone of Foxtech product line. It can lift very heavy load with a relatively small wheelbase, combining with its folding arms and landing gears.
D130 Titan can be your ideal tools for aerophotography,emergency rescue,aero-logistics and other applications more than your wildest imagination. D130 Titan uses FOC ESCs and high power motors that ensure very fast response and
very big loading capacity and a very stable fly performance within its thrust range. Being an very unique X8 co-axial multicopter,D130 has at least 20 kg lifting capacity on each arm, and each arm has enough redundancy power,so the
D130 can still fly even with two motor failure on different arms. D130 Titan is equipped with dual folding landing gear system, it has enough space between the center board and the ground that can hold a red epic camera and its gimbal.
The dual landing gear system can also sustain some impact in case of a hard landing, which can not be done with those single landing gear system.
You can also ask for a customized D130 Titan multicopter,with a strong technical team, Foxtech is able to design and build the parts you need that should be able to make D130 able to lift heavy load over distance, or to be an agriculture
sprayer, water gun drone, illumination drone and any other drone types that you can imagine.
You can get more specs info here: https://www.foxtechfpv.com/d130-x8-titan.html
Welcome to join facebook D130 group:https://www.facebook.com/groups/1034...?ref=bookmarks
Mar 28, 2017, 01:55 AM
Jay92's Avatar
hello foxtech, this D130 Titan version looks great, and i have a question, if this d130 titan can work with the pesticides sprayer system? are these items all available now? i am looking for a copter to spread insecticide and want to know if the D130 is suitable.
Mar 31, 2017, 03:12 AM
is there more specification about motor and ESC ?
Mar 31, 2017, 03:14 AM
and what is FOC ?
Apr 01, 2017, 01:47 AM
Can you say more about the FOC power system? It seems so cool ! What is its Max left power for the motor?
Apr 01, 2017, 03:58 AM
foxtechtech's Avatar
Yes, Jay. We accept custom D130 to agriculture spray drone. You can send me details of what you need. like the payload flight time etc.
Latest blog entry: FOXTECH GAIA 120 Hexacopter
Apr 02, 2017, 03:14 AM
Originally Posted by Lucas987
and what is FOC ?
FOC offers extraordinary smooth throttle curve and very fast responsive speed
by using FOC ESC and compatible motor on big drones, we then can have less vibration, faster reaction and better also a lot better efficiency.
Apr 06, 2017, 04:36 AM
It seams much better and cheaper than T-Motor U10 kv100 motor and Flame 80A ESC. But they have to be replaced together when motor or ESC defective, can't change only one. Right ?
Apr 07, 2017, 04:17 AM
I have 32 inch props, can I use 32 inch also in your D130 Titan? Will this size prop available to lift your drone? Still with 8120 motor.
May 25, 2017, 02:23 AM
how about using Titan version to be a spray drone in agriculture ? Do you test it before ?
Jun 11, 2017, 09:56 PM
There is another frame for spray drone. and we have tested it already.:
https://www.foxtechfpv.com/gaia-160-...ter-frame.html
test video is also listed on the page.
Jun 11, 2017, 09:58 PM
we suggest 30'' prop. 32 inch props donot fit.
