This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Mar 20, 2017, 07:21 PM
old4570's Avatar
Mini-Review
Eachine H8 mini + Multi Protocol Module
In my previous post I mentioned I had the Eachine bound to my Turnigy 9XR Pro VIA a multi protocol module ...
https://goo.gl/cJvDpd Multi protocol Module ... FYI , this module only does ( NRF24L01 )
https://goo.gl/R6ALz5 Eachine H8 mini ...
These are the instructions for binding ..
When you turn on the Tx hold the sticks in the following position ( on start - not after )
Rudder right + Aileron left = EAchine H8 mini 3D
Elevator up + Aileron right = EAchine H8(C) mini
Will the real Eachine stand up please !
These were the instructions , but for the Taranis transmitter .
For the 9XR Pro I found the following worked
Transmitter is mode 2 Left stick is Throttle / Rudder
Throttle Down / Rudder left ( bottom left corner )
Right stick = top right corner
Once the (?) model is bound , you should not need to repeat the process as the protocol ( model ) will be remembered next time you want to fly .
Like I said , the instructions are for the Taranis , so if you plug the module into any other Tx , you will need to explore for a bind .
Eachine H8 mini ...
I still haven't tried the factory remote .
The H8 bound to my 9XR pro shows great promise for a really good flying mini quad ( or is it micro ? )
It handles a breeze relatively well for it's small size
The H8 lacks power / or is a little heavy
Very strong , takes bumps well
Might be stunt able .. ( Very nimble )
For the price - seriously ! ( A lot of people will spend $13 on a take out order that gets Number 2'ed a few days latter )
My H8 seems to have a bad motor , and it makes the little quad tricky to hover as the motor runs rough ( see video )
Over all I was impressed by the H8 when bound to the 9XR Pro , I always thought the budget quads were limited by the factory transmitters and the H8 proves that to me . Unfortunately my H8 has a bad motor , and if not for that it would probably hover in place like a champ ..
If you get a good H8 ( no problems ) then it could make for an excellent learning quad .. Either set up rates or limit input ( Less than 100% ) .. The rudder on my H8 was super sensitive so I set it to 50% and fantastic .. ( Also reversed the rudder - for me )
Do I like the H8 ? Even with a bad motor = YES !
Do I like the multi protocol module = Even though there are no instructions for the Turnigy 9XR pro = Yes ..
I like the small cheap micro quads / helicopters .. I hate the nasty transmitters they come with ( should I call them controllers ) .. What the hobby desperately needs is a transmitter ( decent quality ) that will bind to every last one of these products .. One transmitter and hundreds of toys to chose from , that's how it should be .. And modules like this one help to address this short coming put in place by the RC Industry . ( If anything I think they are limiting sales rather than maximizing sales )
Anyhow , what I have found is that many of these mini / micro's will fly really well when bound to a better transmitter ..
I still remember the first time I bound the WL toys V911 to a 9x .. It was like chalk and cheese .. ( Flew so much better )
Eachine H8 mini bound to my Turnigy 9XR pro (2 min 39 sec)
Mar 21, 2017, 08:44 PM
old4570's Avatar
A bit of an update !
After 10 flights the bad motor seems to have come good .. ( Runs smooth )
The H8 really does hover like a champ when the motors are running properly ...
Mar 31, 2017, 12:49 PM
Hi,
Thank you for your post. :-)
I got the H8 3D and a turnigy 9xr.
Could you tell me if the range is good with your module.
Can I had an antenna ? I can't see what is the plug for antenna.
Thx
Mar 31, 2017, 07:58 PM
old4570's Avatar
Originally Posted by Chaipaky View Post
Hi,
Thx
Range ? I haven't pushed range as yet .
Module antenna , it does not have one per say .. The board has a certain amount of trace on it that would act as an antenna .
This is meant to be short range , but soldering on some wire to the end of the trace might push the range ...
I was actually planning on testing this .. ( Range and if it can be extended )
Apr 02, 2017, 02:37 PM
Thanks for your answer, Nice to know that.
You can go with this module in an other room of your house without bad signal?
I plan to put a Fpv cam :-) (like TX02)
Do you know if another module with antenna exist for Turnigy 9x series ?
Apr 02, 2017, 09:23 PM
old4570's Avatar
Yes !
http://www.banggood.com/2_4G-CC2500-...050916201204IS
There is this one ... ( I plan on getting this one when the V2 version comes out )
Room to room !
I have not tested that ( I have only flown line of sight to maybe 20 meters ) It is a small quad ...
Apr 03, 2017, 08:23 AM
Thanks !
I buy the same module as you !
It's cheapest way to play with my H8 ;-)
I see the second one but it's 4x the cost !
I'm enjoyed to receive it
Thanks for your support buddy
see ya asap
Apr 03, 2017, 06:06 PM
old4570's Avatar
I want the V2 version so as to eliminate some Transmitters ..
I really want to get down to maybe 2 transmitters .
Dec 16, 2017, 08:23 PM
Morcegolas's Avatar
In the original H8 mini TX you have the left key to select the speed, Hi/Low with two/one beeps. Can you do this with taranis and this module? If yes what is the channel and the configs for that?
Thanks.
Dec 16, 2017, 09:32 PM
old4570's Avatar
Thanks.
Speeds = Rates I assume ..
A) I have never used the original Factory Tx
B) I now use the iRangeX IRX4 multi protocol module
C) If you need to set up rates just do it in the transmitter . I don't know that a non Factory Tx would activate rates ? But if you wanted to try then you would need to experiment with the special functions menu .. A lot of times rates are not set to a channel .. ( Ch5 / Ch6 ) because they are on a separate rates Ch .
How you would find that ? or activate it ? ( Just easier to set up rates in the Tx )
I have the 9XR pro with a multi protocol module ( iRangeX IRX4 ) as well the Taranis Q x7 with a IRX4 module .
The Eachine H8 mini flies best with the 9XR pro transmitter ( for some reason ) ..
I still fly my H8 , and a couple of days ago we had a fantastic wind free morning and I had a blast with the H8 in the back yard .
Sorry I can't be of more help !
Dec 17, 2017, 05:33 AM
Morcegolas's Avatar
That’s the rates that I was talking, I also bought the iRangeX IRX4 module, so to change the speed rate I don’t have to create a special function in the TX?
Dec 17, 2017, 07:19 AM
old4570's Avatar
Thatís the rates that I was talking, I also bought the iRangeX IRX4 module, so to change the speed rate I donít have to create a special function in the TX?
Open Tx : https://www.youtube.com/results?sear...anis+qx7+rates
Some tutorials on youtube ...
Dec 17, 2017, 10:54 AM
Morcegolas's Avatar
Thank you old4570 I got it. So when I bind my taranis with any eachine it will be always 100% rate correct? Then I can setup other rates on the TX.
Thanks.
Dec 17, 2017, 04:31 PM
old4570's Avatar
Should be 100% by default = Yes .
