Associated RC10B64 Team Kit - RC Groups
The all new Team Associated RC10B64 builds on the previous RC10B44 with more adjustment points for dialing in high-grip clay and carpet tracks.
A Race Winning Roller from Team Associated
The all new Associated RC10B64 Team Kit represents the pinnacle of off-road racing development. The shortcomings of the B44 were identified and addressed with the new B64, including increased traction and handling on high-grip surfaces, especially carpet. Additional adjustment points are another change for the new RC10B64, including caster adjustments and swaybars. Two versions are available: the B64 for dirt and clay, and the B64D for carpet. The only difference between the two versions is a gear drive center diff versus a slipper center diff on the D version.
Features:
  • Narrow 7075 hard-anodized aluminum chassis with centralized mass.
  • Four-wheel shaft drive.
  • Clear body with JConcepts screw-mounted wing.
  • V2 12 mm Big Bore oil shocks with 3 mm TiN-coated shafts and low-friction X-rings for improved smoothness.
  • 0.16" (4 mm) thick carbon fiber shock towers.
  • Aluminum/carbon fiber steering servo mount.
  • Suspension with adjustable axle height and roll centers, plus front/rear anti-roll bars.
  • Adjustable center slipper clutch with Low Coefficient Friction Pads.
  • Three gear differentials.
  • Factory Team aluminum motor mount with floating design allows consistent torsional chassis flex.
  • Full set of Factory Team ball bearings.
  • 5 mm front aluminum drive hexes.
  • Adjustable toe-in/camber.
Team Associated B64 & B64D 4WD Buggy Overview (5 min 36 sec)
CLICK HERE for more info on the new Associated RC10B64 Team Kit
Mar 21, 2017, 08:23 AM
Did I make the A Main?
bill_delong's Avatar
it would be a little less confusing if they would've called it the B64C and B64D in similar fashion to how Schumacher names their KC and KD variants for respective "Carpet" and "Dirt" editions.
I think these are reversed, the tell tale signs are respective tires used in the illustrations
