Mar 19, 2017, 08:27 PM
FPV -Antenna Radiation pattern
Because of the working relationship, know a lot of antenna type, the following describes some FPV commonly used antenna
The first, double diamond antenna
Mar 19, 2017, 10:05 PM
The gain of this double diamond antenna is about 9.5 dB
Mar 19, 2017, 10:15 PM
The second is a 4-diamond antenna
The antenna horizontal state is used for vertical polarization,The antenna gain is about 11.5 dB
Mar 20, 2017, 01:21 AM
This circularly polarized antenna gain is about 1.5dB and it is a small mushroom
Mar 20, 2017, 01:30 AM
Double diamond antenna, 4 diamond antenna, mushroom antenna, work at 5.8g frequency
Mar 20, 2017, 01:56 AM
Double diamond antenna is suitable for 3-10km fpv
Mushroom antenna is suitable for nearby fast FPV,Circular Polarization Wave Suppresses Multi - path Effect
Mar 21, 2017, 02:46 AM
wazoo22's Avatar
Thanks for this- very useful.
I presume the radiation patterns would be similar for 1.3G antennas?
Don't quit now. I would be very interested in the Yagi and a 3-5 turn helical data.
However, reallly poor choice of colors on the graphical plot. Could you change them, and label what we are looking at a bit more clearly?
Thanks again.
Mar 21, 2017, 08:01 PM
Thanks again.
Yes, as long as the same proportion is maintained, 1.3g antenna and 5.8g antenna radiation pattern is the same
Horizontal radiation half power angle of 36 degrees,Vertical radiation half power angle of 66 degrees
You are interested in Yagi antenna and helical antenna,Tell you when the calculation is complete
Thanks for the message!
Question Worst question about monopole radiation pattern... nonoze FPV Equipment 5 Nov 29, 2015 02:29 PM
Question BODA antennas radiation pattern sssmasherrr Radios 4 Oct 29, 2014 04:08 PM
Discussion Help me read this radiation pattern Dimitris76 FPV Equipment 5 Jan 06, 2014 10:31 PM
Discussion I need a CP antenna for a tx that semi-sphere radiation pattern Koo FPV Talk 11 Apr 25, 2013 12:35 PM
Discussion BWAV 600mW Tx Radiation Pattern? MX Aerial Photography 37 Sep 17, 2006 09:19 PM
