H-King Glue-N-Go Series EPP Shark - RC Groups
Novelty planes can be a fun addition to your hangar and the HobbyKing EPP Shark kit looks to be another plane you can take to shows and get all the smiles with. It would be especially fun at the beach, you know children would go nuts chasing this plane up and down the beach while screaming "SHARK!!!!"
Yes You Can Fly a Shark
Novelty planes can be a fun addition to your hangar and the HobbyKing EPP Shark kit looks to be another plane you can take to shows and get all the smiles with. It would be especially fun at the beach, you know children would go nuts chasing this plane up and down the beach while screaming "SHARK!!!!" This kit is part of H-King Glue-N-Go series which means it arrives in parts and you have to build it and install your own electronics to make it fly, but the foam is already painted so that's less work for you. It's made from EPP foam which is incredibly durable and you glue it together with super glue, epoxy, or contact adhesive. They do include the hardware you'd need like control horns, pushrods, and clevises as well as a full color instruction manual to help you with the building process.
The Shark can fly slow and the wing design with the angled tips give it plenty of dihedral that will ensure the plane is stable and easy to fly for even beginner pilots. If you have any mishaps during the flight, the EPP foam will bounce and retain its shape with little to no damage and the wing is mounted with rubber bands which protects it even more from damage during a crash. The kit costs $58 and it seems it is already very popular as it is currently on backorder at H-King.
Check out the H-King Glue-N-Go Series EPP Shark Here.
Specifications:
  • Wingspan: 1420mm
  • Length: 970mm
  • Weight: ~700g
Recommended Equipment:
  • 1 x 3S 2200-2800mAh LiPo battery
  • 1 x 2212-1100kv brushless motor
  • 1 x 8040 (8 x 4) propeller
  • 1 x 20A ESC
  • 2 x 9g Servos
  • 1 x 3CH or more Radio TX and RX
Mar 15, 2017, 11:08 AM
rcnova
when will it be available from a US based warehouse?
Mar 15, 2017, 11:26 AM
RCG Admin
Jason Cole's Avatar
I don't have any knowledge into that one.
Mar 16, 2017, 01:47 PM
Mark 42's Avatar
I think they should put together a few complete packages with everything in them available with different radios (FrSky, Spektrum & budget brands)and a few other simple choices (motor upgrades, extra batteries, battery charger, etc).
Mar 16, 2017, 06:53 PM
Category Manager - Planes
HobbyKing_Ian's Avatar
Hi Mark,
If you take a look at the related towards the bottom of the page you'll see the items we recommend.
Ian
Mar 16, 2017, 11:05 PM
Terry Dunn
mopar_man's Avatar
Seems just a wee bit similar to the Foamtastic Models Park Shark, circa 2004
That one was a fun flyer...even better on floats.
Mar 17, 2017, 08:00 AM
serial scratchbuilder
Granted's Avatar
If you mean they're both blue, I'm with ya. Other than that I see little resemblance.
Mar 17, 2017, 09:15 AM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Looks like it would be a good plane for a first time RC flyer - with EPP , high polyhedral wing , 3 channel RET Rudder-Elevator-Throttle .
Apr 06, 2017, 10:11 AM
遙控 大飛鯊 RC fly Shark EPP @ 深圳市中心公園 20161222 (1 min 30 sec)
My RC Fly Shark video.
Apr 15, 2017, 06:56 PM
Cg??
I just got my shark in the mail today and as i reviewed the manual i found that in step 17 it gives a cg of 179mm from the leading edge, however in the picture below that it shows the cg mark at 129mm. Anyone know for sure which is right?
Oct 03, 2017, 10:19 AM
rcnova
129mm from leading edge is correct (179 is a typo)
Jan 26, 2018, 07:39 PM
Space pirate
For anyone who cares these are on HK deals of the week for 20$ lol I might pick one up to modify and mess around with or teach someone on, doesn't get cheaper than that.
Jan 27, 2018, 12:07 PM
Out of stock
Mar 19, 2018, 12:05 AM
They're in stock in the AU warehouse now. Stupendously cheap at AU$21, could not resist.
