Oct 16, 2018, 10:04 AM
Is that an M12 lens on the Falkor Micro?
I'm quite interested in this one!
Oct 17, 2018, 12:21 AM
Look at the specs M8, it's M8!
Oct 17, 2018, 12:41 AM
M8 lens~
Full, Mini and Micro size are all same chipset. all functions on them are same!
FOXEER FALKOR REVIEW WITH DVR 🔥🔥🔥 | BEST FPV CAMERA ??? 😮 (4 min 0 sec)
Oct 17, 2018, 12:27 PM
I feel embarrassed. I got hung up looking at the picture. The lens looks huge for an M8 though, doesn't it?
Oct 17, 2018, 02:03 PM
Must agree, that lens indeed looks huge compared to the usual Foxeer lens. I hope it will be the same on the real cam. Now we only have computer generated picture.
I'm also feel excited about this new Falkor cam!
Oct 18, 2018, 03:40 AM
This is our pilots flied at the morning seaside~
Foxeer Falkor on the sea! Standard/mini/micro size for your optional! (1 min 40 sec)
Nov 22, 2018, 02:27 AM
F722 Dual Gyro Flight Controller
Feature:
Dual Gyroscopes MPU6000 and ICM20602 built in to give both smooth and high-speed flying experience
Latest STM32F722RGT6 Processor with wide 3-6S input
Support both soldering pad and plug to ESC
Support both 4 in 1 and Single ECS connection
SPEC:
Hole to Hole: 30.5*30.5 φ4mm
Processor: STM32F722RGT6
Dual Gyro: MPU6000 and ICM20602 (32K)
Memory: 16MB
Voltage regulator: 5V/2A 9V/1.5A
OSD Superposition: support
Input: 3-6S (10-30V)
Firmware: FOXEERF722DUAL
Uart: 5 ports
Welcome to Order: http://foxeer.com/Foxeer-F722-Dual-G...ntroller-g-208
Nov 26, 2018, 12:16 AM
Foxeer F722 Dual Gyro Flight Controller - Overview & Giveaway (5 min 19 sec)
Dec 05, 2018, 04:58 PM
lurking in the HOLE :)
KCV6's Avatar
libbyt,
Can you please provide an answer on the built in OSD on the Falkor mini. See my post here.
https://www.rcgroups.com/forums/show...3&postcount=65
Cheers
Mark
Dec 12, 2018, 07:11 AM
Originally Posted by KCV6
libbyt,
Cheers
Mark
Hi,Mark, replied you on this link~
Dec 12, 2018, 07:16 AM
KCV6's Avatar
Thanks Libby
Dec 13, 2018, 07:58 PM
josephr's Avatar
Hello Libbyt,
I have a new Falkor Micro and installed it into my micro quad last week running a HGLRC F428 Stack and ran into what I consider to be a big issue with this camera.
I previously had a Predator Micro V3 installed in my micro quad and wanted to see if the Falkor gave a better image after seeing all of the hype about the camera and the specs looked promising.
Well within 30 sec of plugging the Falkor into the cable and powering up the quad, I had a bit of a smell out of the camera and the PCB on the back got really hot, so I quickly unplugged and checked to see if I had a polarity issue with my cable.
No, no issue, same connection for the Predator and all was OK with the Predator. Scratching my head because all of my other Foxeer and Runcam camera's do not have a hot PCB I contacted the local supplier and told him about the issue thinking I had a faulty camera. After a day of chat back and forth, I delivered the camera to the supplier and he contacted Foxeer. Both my supplier in Australia and Foxeer at the factory ran tests on the Falkor Micro for temperature and the current draw.
To my surprise your Foxeer engineers have said that this camera runs hot, up to 70 degrees C to be precise and will draw up to 260mA which floored me as I don't have another camera that runs that hot or draws that much current.
The camera I purchased is now on its way back to me from the Australian supplier with the view of Foxeer that there is nothing wrong with it.
From my point of view, you cannot use this camera on a micro as it draws too much current not even considering how hot it gets and how long it will last running at those temperatures, not to mention how hot the camera will end up when the ambient summer time temperature in Australia is 30 degrees C plus.
I feel it is only suited to go on something like a 5 inch quad where you have a larger battery. This is a shame because the Falkor Micro is a little smaller than the Predator and in some way's suited for Micros.
Hope this info helps, if others have the same experience, please add your comments below. Regard's, JosephR.
Originally Posted by libbyt
🍦🍦🍦Who wanna it, FOXEER Falkor Micro!!! :P :P :P
(PS: Please follow Foxeer Facebook page to win the #GIVEAWAY Activity !!!)
🍦Spec:
1/3 Cmos 1200TVL FPV Cam
NTSC/PAL,4:3/16:9 switchable
Support Foxeer title & Voltage & Time on/off
1.8mm M8 lens (FOV-H 115)
Color:White/ Red/ Black
🍦Features:
Global WDR Camera
All-weather matching & Auto-environmental adapting
Brighter and more detail in the outside backlight surroundings
Good performance in dim LED scenes
Support camera remote control
Upgrade the harness to video & OSD separated
🍦BUY Here: http://foxeer.com/Foxeer-Micro-Falko...Camera-16-4-3
( Shipment on 16th Oct)
Jan 11, 2019, 08:28 AM
Feature:
SPEC:
Memory: 16MB
Uart: 5 ports
Ive been rocking this FC, it's simply my best FC working, the F7 have something special in it, my f4's dont fly as good with same settings and hardware
Jan 19, 2019, 04:23 AM
Foxeer MIX 1080P 60fps & FPV Cam
Foxeer MIX Camera:
Features:
Support 20*20mm and 30.5*30.5mm mounting hole
Both connector & soldering pad connecting available
Audio, less noise on FPV
Power-on recording & Power-off saving (The last 2s video maybe lost)
Anti-drop SD Card protector
Wide voltage (5-24V) input
FPV aspect ratio 16:9/4:3 switchable
Foxeer & Voltage & Time Screen OSD
Video Playback, 64G SD Card
Size: Lens Module: 1919mm
Mainboard: 3737mm/2929mm
More details: http://foxeer.com/Foxeer-Mix-1080p-6...V-Camera-g-213
Review:
Foxeer Mix HD FPV Camera FIRST LOOK 📷 (21 min 36 sec)
Footage:
Foxeer Mix First test! Loving it! (2 min 20 sec)
Jan 19, 2019, 07:00 AM
Any chance to get a review sample of the Mix?
