Jul 23, 2018, 07:42 PM
Originally Posted by gt40Dave
libbyt, a question from a novice FPV pilot.
Building a fixed wing with Foxeer camera (monster pro 16x9) and Clearview TX + foxeer lollypop antenna. My question is; how long can I make the wires between the camera and the transmitter? The cable supplied is ~ 5.5 inches. Ideally I would like to make a cable about 12 - 14 inches long. Will this work or cause video quality problems??
You can extend the wires to that length without any problems as long as you are careful where you route them. The cable you use will likely be unshielded (just plain wire is) so you need to make sure it doesn't pass over anything that has a high current or an alternating current going through it.
As long as you keep the video wires away from the ESC, the motor, and motor wires, you shouldn't have any problems.
Jul 23, 2018, 09:46 PM
gt40Dave's Avatar
Thanks "BobFromMars".
The closest the wires will be to the ESC is about 4 inches, but I will be changing the video wire that I lengthen to shielded cable and using twisted pair for power and ground for FPV. FPV power will be from a separate battery (not from the flight pack battery).
Jul 26, 2018, 07:52 AM
Foxeer Offical Account
Foxeer New Camera Falkor release!
Welcome to Foxeer facebook page to win the GIVEAWAY!
https://www.facebook.com/pg/FOXEERTE...=page_internal
What comes to mind when you hear Falkor? Do you recall the flying lucky dragon? Let Foxeer Falkor take you to the sky.������
⬇️⬇️#GIVEAWAY ⬇️⬇️
��Spec:
1/3 Cmos 1200TVL FPV Cam
NTSC/PAL,4:3/16:9 switchable
Standard with 1.8mm lens
Color:White/ Red/ Black/ Blue
��Features:
Global WDR Camera
All-weather matching & Auto-environmental adapting
Brighter and more detail in the outside backlight surroundings
Good performance in dim LED scenes
Support camera remote control
Upgrade the harness to video & OSD separated
��#GIVEAWAY:
1, Like FOXEER page
2, Share this post
3, Answer this questions: Do you know Falkor? What’s your feeling/impression to Falkor?
Then you will have the chance to win the WHITE FALKOR !!! For every 100 shares,1 winner will be selected. Looking forward to your lovely answers!
(activity time: now-6th Aug)
��Welcome to join in FOXEER RC Group to share your FPV story!
��Pre-order: http://foxeer.com/Foxeer-Falkor-1200...SC-G-WDR-g-190
Shipping date: 10th Aug
Jul 26, 2018, 08:00 AM
This camera looks awesome.
Jul 26, 2018, 12:22 PM
UAV Integrations
Getting a 404 error when clicking on that foxeer falkor link (at the bottom of the post)
Jul 26, 2018, 12:24 PM
UAV Integrations
Hey Foxeer I'm 100% confident all FPVers would absolutely LOVE a global shutter CMOS camera.
Can you make one?
Jul 26, 2018, 07:54 PM
Three questions about the Falkor:
Is it possible to switch between NTSC and PAL in the OSD menu?
Can I order it with a different lens, like 3.6mm?
What is the price (right now I get a 404 error)?
Jul 26, 2018, 09:12 PM
Sorry, my mistake, please refer this link: http://foxeer.com/Foxeer-Falkor-1200...SC-G-WDR-g-190
Jul 26, 2018, 09:22 PM
Can you make one?
Good choice!
Jul 26, 2018, 09:24 PM
Hi, sir~OSD could set the N/P switchable. 3.6mm should be work, but don't you see the angle is so narrow?
Price: 39.9USD!
info link: http://foxeer.com/Foxeer-Falkor-1200...SC-G-WDR-g-190
Jul 27, 2018, 11:24 AM
Originally Posted by Foxeer Official
... 3.6mm should be work, but don't you see the angle is so narrow? ...
No, it's not too narrow. I believe that you think only about FPV with quadcopters for racing or freestyle, but 3.6mm is just right if you fly planes.
I wish there would be cameras for LR FPV.
Aug 02, 2018, 01:14 AM
Hi, guys, a review for Falkor!
16:9 / 4:3 & P/N switchable!
Falkor is a super wide dynamic range camera that is well processed with its whole picture. Uniform and bright exposure, it produces clear and crisp image. It can adapt to various environments, making it easier for you to see and avoid obstacles.
Foxeer Falkor FPV Camera Review 📷 (9 min 22 sec)
Aug 02, 2018, 01:27 AM
Lollipop 2 Stubby will be ready soon
Lollipop 2 is released. Different inner structure, signal quality much better, gain much higher. locking more steady.
Support LHCP/RHCP, SMA/RPSMA/UFL/MMCX angle & straight.
Also stubby version will be ready in a month.
Aug 05, 2018, 07:42 AM
'Extreme Fabricator'
Originally Posted by libbyt
But feel curiosity, what PWM used for on VTX?
Selecting output power with a switch on the radio. It will save battery power and minimise interference to others if you can switch up once there's some distance gained.
Aug 08, 2018, 09:44 AM
Foxeer Predator V3 release!
Foxeer & Rotor Riot Predator V3, Strive for the best racing cam!
⬇️⬇️ #GIVEAWAY ⬇️⬇️
💜Increase:
4:3/16:9 & NTSC/PAL switchable
Upgrade harness to VIDEO & OSD separated
💜Spec:
Excellent Super WDR Function
1000TVL / 4mS Latency
Image Flip (up-down-left-right rotate) / No Jello
OSD / 5-40V input
Seven Languages
🌞Predator V3 Mini/Standard
-Full size & mini size switchable with multi-functional bracket
Size: 21.8*21.8mm, Weight: 8.7g (excluding bracket)
🌞Predator V3 Micro
-Size:19*18.6mm, Weight:5.5g
💜GIVEAWAY:
go to Foxeer facebook page to win the GIVEAWAY: https://www.facebook.com/FOXEERTECH/...type=3&theater
💜Pre-order:
Standard/mini: http://www.foxeer.com/Foxeer-Predato...able-OSD-g-191
Micro: http://www.foxeer.com/Foxeer-Predato...-Latency-g-192
Shipping date: 14th Aug 2018
