Jun 28, 2018, 09:47 AM
Foxeer Offical Account
Foxeer new DATURA
Foxeer new DATURA motor will release!
matched 2207 1800/2450/2700KV!
Any opinions?
Jun 28, 2018, 01:18 PM
Any opinions?
Awesome Kv choice.
Jun 29, 2018, 03:05 AM
Originally Posted by downloader9
Awesome Kv choice.
Yep. We think to cover all racing, freestyle and 6S battery users.
Jun 29, 2018, 06:41 AM
New 1.8mm lens FOVD 160 degree for Foxeer Arrow Micro Pro
Good News: Foxeer release a new 1.8mm wider lens for =Arrow Micro Pro= camera, FOVD 160 / FOVH 125 degree, wider than ever!!!
Preorder (shipped on 4th Jul): http://www.foxeer.com/Foxeer-MTV-Mou...icro-Pro-g-187
Jul 02, 2018, 01:42 AM
How to use the Camera Remote Control on Foxeer F405 AIO
Guys here is a nice video to introduce you how to connect the F405 AIO and camera remote control operation!
Foxeer F405 AIO FC+PDB+OSD+Camera Remote control! Order:
http://www.foxeer.com/FOXEER-F405-AI...ntroller-g-183
Foxeer F405 AIO FC - Review & Giveaway (5 min 29 sec)
Jul 02, 2018, 09:13 PM
https://www.facebook.com/PudseyRc/vi...ged_with_story
Foxeer F405 AIO FC
Camera Control
Menu 1 - 0:20:00 Camera Features
Yaw / Throttle Full Center Right ( Then leave Center )
using Ail / Ele - Pitch / Roll to navigate up down left and right
Use Yaw / Throttle Full center right to select and confirm menu selection
Menu 2 - 01:30:00 Camera OSD
Yaw/ Throttle Center bottom - Pitch / Roll Full center top for 3 seconds
Once menu is active Put Yaw / Throttle to center and do as above to navigate and make selections.
IMPORTANT
YAW / THROTTLE MUST BE CENTER TO NAVIGATE With Elev / Ail - Pitch / Roll
Jul 02, 2018, 09:16 PM
Tutorial: How to build your Foxeer F405 AIO and Camera remote control operate!
Build: Foxeer Flight Controller F405 Build and Maiden Flight!!! (07.01.2018) (13 min 26 sec)
Jul 04, 2018, 06:05 AM
Foxeer ClearTX with Smart audio function!
Good news! Foxeer ClearTX transmitter will support Smart Audio function soon!!!
Foxeer ClearTX Transmitter with smartaudio function! (0 min 45 sec)
Jul 16, 2018, 03:02 AM
Foxeer Lollipop 2 will release soon!
Hi,Guys, new Foxeer Lollipop 2 is coming soon! RPSMA/SMA, UFL, MMCX straight/angle, LHCP/RHCP all support!
Jul 16, 2018, 03:26 AM
No LHCP SMA??
RHCP and LHCP SMA but shorter than V1 would be perfect. Thanks.
Jul 18, 2018, 07:22 AM
No LHCP SMA??
Red color support LHCP and SMA connector. How short size you suggest?
Jul 18, 2018, 07:34 AM
Foxeer Lollipop 2 5.8G antenna, new structure gives better gain & stronger signal
A copper omnidirectional configuration antenna makes a stronger signal, more stable gain and more strength anti-crash case!
💜Spec:
Frequency range: 5600-5950Mhz
Polarization direction: right circular polarization
Gain: 2.5dbi
Radiation range: 98%
Matching: VSWR <1.2 (center frequency)
Impedance: 50 Ω
Axis ratio: <3dbi
Support: RHCP/LHCP
Connectors: SMA/ RPSMA/ UFL/MMCX straight & angle
Color: Black/Red/Purple
Jul 18, 2018, 08:37 PM
How Clear it is? Predator V2 working in the night!
Late evening and Foxeer Predator Micro (2 min 52 sec)
Jul 23, 2018, 08:35 AM
New Foxeer Cam: White Falkor
New freestyle Camera from Foxeer, spec to be updated!
Jul 23, 2018, 05:23 PM
gt40Dave's Avatar
libbyt, a question from a novice FPV pilot.
Building a fixed wing with Foxeer camera (monster pro 16x9) and Clearview TX + foxeer lollypop antenna. My question is; how long can I make the wires between the camera and the transmitter? The cable supplied is ~ 5.5 inches. Ideally I would like to make a cable about 12 - 14 inches long. Will this work or cause video quality problems??
