How can I connect a rev c power panel to the eagle eye? - RC Groups
Mar 13, 2017, 09:41 PM
Help!
Hi to everyone.
I need to connect a rev c power panel to the eagle eye, the cable that come with the new power panel is the same that the GPS and air speed sensors uses, is designed to connect to the bus port but the eagle eyes don't have that kind of port.
The EA have a four pin male conector, do I need cut the original power panel cable and solder a four pin female? In which order the cables go? or Is this rev C PP not compatible with the EA?
Thank you.
Mar 14, 2017, 08:49 AM
JohnET's Avatar
Hello,
That is the Info Panel which is not compatible with the Eagle Eyes. You need the Power Panel.
Regards, John
Mar 14, 2017, 09:20 AM
Nice, how lucky am I, don't you think?
