Mar 13, 2017, 04:24 PM
Whadda YOU lookin' at?
CactusJackSlade's Avatar
Help!
Can I apply for class C airspace authorization with my temp 107 cert?
As the title says:
Can I apply for class C airspace authorization with my temp 107 cert? I am awaiting my actual certification number but need to file a Class C authorization request ASAP.
I know they take time and I'm worried if I wait I will not get the authorization in time.
I've been "on hold" with the FAA question center several times and have not been able to get through... and have not found that info on their website.
Anybody know for sure?
Thx
Mar 13, 2017, 08:49 PM
Running jokes into the ground
b-29er's Avatar
doesn't the process to request class C exemption take 45 days?
Mar 13, 2017, 09:27 PM
I guess its like asking if a temporary license plate is valid.
Mar 13, 2017, 10:18 PM
BirdsEyeView Aero
ErichF's Avatar
Yes, put "Pending" in the certificate # field.
And yes, they can take anywhere from weeks to months to approve, depending on the situation and how well you stated your safety case.
Mar 14, 2017, 12:44 AM
That is what I was looking for - thank you
I do not need any un-needed slow downs during this process...
Mar 14, 2017, 12:45 AM
I know my cert is "valid" but I wanted to know if it would work for the online authorization form... I don't need any slow downs...
Mar 14, 2017, 07:50 AM
To fly in class C airspace all you need is prior authorization. If you can get ahold of the tower (controlling agency) and say who you are, where you are, how high and how long you are going to fly that should be all you need. Done it many times in the class delta that I live in.
Mar 14, 2017, 08:39 AM
It may or may not also require a Mode S transponder according to what Class C airspace you are intending to fly in.
Vimlossus's Avatar
You are somewhat correct mhartman. If doing it for hobby, all you need to do is contact the ATC, but if you are doing it for commercial under your part 107 license, you need a waiver from the FAA to fly in any controlled airspace.
Mar 14, 2017, 09:00 AM
107.41 Operation in certain airspace.
No person may operate a small unmanned aircraft in Class B, Class C, or Class D airspace or within the lateral boundaries of the surface area of Class E airspace designated for an airport unless that person has prior authorization from Air Traffic Control (ATC).
I teach a 107 Class. And im also a Commercially rated pilot This is straight from CFR Title 14 Part 107.41
all you need is prior authorization to operate in B,C,D, or E to the surface under part 107
here is the source http://www.ecfr.gov/cgi-bin/text-idx...2.107&rgn=div5
Hobby use is under CFR Title 14 part 101
this is what is says for hobby use part 101.41
(e) When flown within 5 miles of an airport, the operator of the aircraft provides the airport operator and the airport air traffic control tower (when an air traffic facility is located at the airport) with prior notice of the operation.
and the source for hobby regulation http://www.ecfr.gov/cgi-bin/text-idx...=14:2.0.1.3.15
and here is the list of current waivers that the FAA has granted https://www.faa.gov/uas/request_waiver/waivers_granted/
there are no waivers in here that exempt 107.41
Mar 14, 2017, 09:40 AM
BirdsEyeView Aero
ErichF's Avatar
Transponders are not required for UAS operations, even in Class B Mode C Veil.
Mar 14, 2017, 09:44 AM
BirdsEyeView Aero
ErichF's Avatar
If you teach a 107 class, you should know that airspace authorizations MUST be made via the online portal, not through direct contact with the facility. If the facility has been working with you in that manner, then great. However, that is not how it is supposed to be done. Others reading this may try direct contact and will likely be directed to the online portal:
Mar 14, 2017, 09:45 AM
Flying R/C since 1964
kallend's Avatar
Approach Control is the controlling agency for Class C. It may or may not be co-located with the tower. You need to check on the relevant chart or chart supplement.
Mar 14, 2017, 09:46 AM
BirdsEyeView Aero
ErichF's Avatar
Correct, but there is a difference between an authorization and a waiver. Authorizations are coming a lot quicker, but are generally granted for a shorter period.
Mar 14, 2017, 09:49 AM
and if you look here they haven't actually granted a 107.41 waiver. only 107.29 107.35 107.25 107.31 and 107.51
