Tower Hobbies P-51D Mustang MkII Racer Red Rx-R - RC Groups
The Tower P-51 is loaded with iconic Mustang details, like molded exhaust stacks, panel lines, instrument panel and a painted and installed pilot figure.
What better way to win air races than with a plane patterned after the popular P-51 Mustang?
The Tower Hobbies' P-51 Mustang Red Racer is Rx ready, and the ESC and servos are pre-installed. It is made of AeroCell foam and repairs easily with CA adhesive. It has lots of scale touches, along with a distinctive trim scheme featuring red, white, black and gray on top and a cool checkerboard design underneath. You get all of that for a price of $119.99.
Features
  • Construction: AeroCell foam, repairs easily with CA glue
  • Wing: One-piece
  • Aileron Control: Dual Servo
  • Flaps: Optional, hardware included to make flaps operational (two
  • servos and Y-harness required, see COMMENTS below)
  • Brushless Motor: 30-35-1000 1000Kv
  • Electronic Speed Control: 30A
  • Landing Gear: Fixed, can be easily removed for hand launches and
  • belly landings, steerable tail wheel, optional prehinged flaps and
  • retracts
Includes
  • Preassembled Wing, Fuselage and Tail Sections, Fixed Landing Gear,
  • Wheels, Motor, ESC, Propeller, Spinner, Servos and Instruction
  • Manual - Retracts are not included and can be purchased seperately.
Requirements
  • Transmitter and Receiver: At least 4-ch, 6-ch required for optional
  • retracts & flaps
  • LiPo Battery: 3S at least 1800mAh
  • Battery Charger: To match selected battery
  • Building and field equipment
Specs
  • Length: 34" (864mm)
  • Wingspan: 40" (1016mm)
  • Wing Area: 282 sq in (18.2 sq dm)
  • Weight: 30 - 34oz (850 - 964g)
  • Wing Loading: 15.3 - 17.2 oz/sq ft (46.7 - 52.5 g/sq dm)
  • Center of Gravity (CG): 3" (76mm) behind the leading edge of the
  • wing measured at the fuselage
  • Control Throws- Low Rate High Rate
  • Elevator, Up & Down: 1/8" (3mm) 6 1/4" (6mm) 12
  • Rudder, Right to Left: 1/2" (13mm) 14 11/16" (17mm) 18
  • Ailerons, Up & Down: 3/8" (10mm) 18 1/2" (13mm) 23
  • Optional Flaps, Down: 1" (25mm) 24
Video
Tower Hobbies P-51D Mustang MkII Racer Red Rx-R (2 min 16 sec)
Photos
Learn More
Head over to the Tower website for more info on this P-51.
Mar 16, 2017, 02:50 PM
Mark 42's Avatar
Now you need an Me-109, Spitfire, Zero and FW-190 to build a series of fighter planes from the same era.
Mar 28, 2017, 07:19 PM
YeeeeeHaaaaa!! With a couple of mods I see a hundred mph racer...e
Anyone else see it?????
Apr 04, 2017, 02:37 PM
AMA 34191
Vulgar Vulture's Avatar
The first pic kinda/sorta looks like Gunther Balz' 1972 Reno winning 'roto-finish' Mustang.
I really like the contrasting underside graphics!
