Mar 10, 2017, 09:39 PM
New Product
X-UAV Clouds
Purchase link:https://www.foxtechfpv.com/x-uav-clouds-kit.html
The Clouds is a big but light weight EPO plane featuring large size, light weight and heavy load. The specially made EPO material also offers it a strong structure that could sustain a few crashes.
The dual engines design gives this plane a lot of redundancy power and great efficiency for long fly time and high speed at the same time. The UAV shape gives the Clouds a speed range up to 50-80km, but the power consumption is very low at the same time. The huge fuselage makes it possible to load many equipment eg. Gps, gimbal, camera, Autopilot, parachute. The Clouds is an ideal platform for long fly time, high altitude and maybe high flying speed and the same time.
Since the engines are arranged on the front edges of the wings, so you can easily launch it with your hands or using rubber bands(I prefer the latter), and then land it with either gliding touch down or parachute.
With the help of FPV equipments or UAV autopilot , the Clouds can go over 80 km and back thanks to its maximum 3 hours fly time.
Battery that we can use on the Clouds is up tp 4S 22000mah or 6S 16000mah to guarantee the long fly time and long fly range.
The wings and tails are also quick detaching type that makes the transportation much easier.
Mar 10, 2017, 09:40 PM
Specification:
Material:EPO
Wingspan:1880mm
Length:960mm
Height:260mm
Wingarea:53d㎡
Wing assamble:detachble
V Tail assemble:detachble
Load:600-1200g (Excluding battery)
Lauching:by hand or bungee launching
MAX altitude:6000m
Cruise speed:50-80km/h
Flying time:1.5-3h
Wing resistance:LV 6
Camera load:SONYα7 R or smaller thanα7 R
Landing:parechute or slip landing
Recommend Drive System:
Motor:2814 kv1000
ESC:40A*2
Servo:9g*5
Propeller:10*6
Battery:4s 10000-22000mah
6s 10000-16000mah
Mar 13, 2017, 03:48 AM
The load you says is 0.6kg-1.2kg, battery included in these?
Mar 13, 2017, 08:40 PM
I think so.
Mar 14, 2017, 08:24 AM
no, it doens't include the battery,
since a 4S 22000 battery is around 1.5kg already.
the total load I think is around 5kg.
Apr 10, 2017, 04:39 AM
Yes, can you pls tell me what is the differences between FPV mode and UAV mode on your web?
Apr 11, 2017, 04:24 AM
foxtechtech's Avatar
The UAV type have a ejection hock and a camera more than FPV type.
Latest blog entry: FOXTECH GAIA 120 Hexacopter
Apr 19, 2017, 10:38 PM
En~~~~I 'd like to try one, however, I have very little experience on UAV air planes, should learn more, then have one set.
May 25, 2017, 02:00 AM
what's the differenc between FPV mode and UAV mode ?
May 27, 2017, 02:44 AM
Flyawayyy's Avatar
the UAV mode has a launch hook so you can easily launch it by using rubber bands
Jun 08, 2017, 04:41 AM
Do you have UAV mode in stock now?
Jun 09, 2017, 12:35 AM
Jay92's Avatar
do you also have the arkbird VTOL aircraft?
Jun 09, 2017, 12:40 AM
yes the uav mode is available now and you could order now if you need. the link is https://www.foxtechfpv.com/x-uav-clouds-kit.html
Jun 09, 2017, 12:42 AM
the arkbird VTOL aircraft kit is also available https://www.foxtechfpv.com/arkbird-v...-aircraft.html
Jun 19, 2017, 09:36 PM
Jay92's Avatar
thanks for the information, already ordered
New Product X-UAV "CLOUDS" Twin-Tractor FPV Airplane LexusFPV FPV Aircraft 710 Feb 19, 2019 10:44 AM
New Product X-UAV Clouds 1880mm Wingspan EPO FPV Aircraft--Seeking reviewer BG Tobey FPV Talk 54 Jul 23, 2017 02:15 AM
Cool X-UAV new product clouds iamtron Electric Plane Talk 96 Jul 17, 2017 11:49 AM
Sold Brand New X-UAV Clouds Kit Hmerly FPV Equipment (FS/W) 1 Jan 17, 2017 05:54 AM
Sold Brand New X-UAV Clouds Kit Hmerly Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2017 02:23 AM
