Mar 05, 2017, 02:34 PM
Arxangel's Avatar
Build Log
X-UAV Clouds Twin-tractor 1880mm FPV plane - full review / build log / mods
Hey guys, here is my review of the X-UAV Clouds. Sadly it got delayed because the plane took 50 days to arrive to me... but now that it's here... its GOOD! I hope we will be able to pull together some other builds in this thread to make it easier for people to find information on this great model!
You can also find the full review as well as parts list in my blog: ArxangelRC.blogspot.com
As times goes by I am starting to notice a very surprising trend with Chinese RC plane manufacturers - nowadays more often than not we are starting to see planes that are definitely better designed than ever before and require very little, if any, additional work and modifications in addition to the assembly process to make them fly, and make them usable! And that didn't use to be the case just a few years ago! Not only were planes badly designed and manufactured, but there were very little purpose built FPV planes, and most of them were not very good at that anyway!
Today, though, thing have changed... and for the better! There is now a vast array of purpose designed and built FPV planes, and they are GOOD! And I mean it... last few planes I built I didn't have to modify or fix! They were good to go as they were designed... because someone had put some thought into designing them with a purpose to be usable... not just to get your money. And so we come to the X-UAV Clouds - it is simply VERY GOOD!
X UAV Clouds - will it reach the clouds? (a review aided by VTX03 and L9R) (13 min 23 sec)
X UAV Clouds - well... it reached those clouds!! (10.3km on L9R and VTX03) (8 min 43 sec)
X-UAV Clouds - another distance record, still no loss of signal! (L9R + AKK 5.8G 600mW Vtx) (9 min 44 sec)
X-UAV Clouds - Where it belongs! (6 min 40 sec)
X-UAV Clouds - L9R smashing all distance expectations! (6 min 33 sec)
X-UAV Clouds - the perfect day to chase clouds... RUINED by the camera! (29 min 53 sec)
A Cloud's tale (3 min 51 sec)
THIS is what a LiIon battery can do for your long range model (X-UAV Clouds & FrSky L9R) (12 min 44 sec)
Long range proximity flying atop the Mountain (FrSky R9 and AKK X2 Ultimate Vtx) (3 min 25 sec)
Well... you guessed it... even more cloud chasing! (6 min 51 sec)
SPECIFICATIONS
Wing span: 1880mm
Wing area: 53dm2
Length: 960mm
Flying weight: no official AUW announced (around 2552 grams for the current configuration)
CG: will update tomorrow
ARRIVAL STATE
Oh boy... where do I begin! Recently there has been a series of packages that have arrived in pristine condition... sadly the Clouds was not one of those packages! In addition to taking 50 days to arrive, the box looked as if somebody had been jumping on top of it. It was so bad that the women at the counter suggested I opened it then and there to see if anything is broken! I don't think I've ever received a package so abused!
Luckily inside the box things weren't as bad as the box promised! Considering the damage on the package, the plane had gotten away with very minor damage and a few dents, but that was about it. Honestly... one can throw blame around as much as one wants... but I am just glad the plane was OK, and the damage was very easy to repair.
There was an interesting deformation in the middle of the top hatch... it looked as if it has been pressed down by something for a long time, so now it was permanently deformed! Not a big deal really... but it does make inserting the hatch in that section a bit of an effort.
The middle supports for the hatch have also been deformed to hang lower. Not sure what that's about but it doesn't bother me much.
The only notable damage on the plane was at the tail section. One of the sides was torn off and the other side was deformed a little.
There were also a number of dents and scratches on the wings, and especially on one of the wings, I guess the one that was on top in the box.
The wing with the more dings was also slightly deformed towards the wing tip, as you can see it is sticking over the other half when placed on the same level surface.
The bottom half of the fuselage is also deformed at the tail, luckily there was nothing torn there, so a quick hot bath straightened things out real nice.
There is some sign of some serious bending on the parts that hold the tail to the fuselage... luckily its nothing serious and there are no tears.
One of the wing adapters also had some serious damage on it, but I wasn't overly worried about that becuase this whole section will be glued to the wing, so it should hold without much issues.
Well... it could have been much worse! Now lets move on...
WHAT I LIKE
The first and foremost that I LOVE about this plane is the design choice to put the motor nacelles on the fuselage part of the plane, and not on the part of the wings that will disconnect from it. It is similar to the design of the MyTwinDream plane, and I think this is the better way to do it. This way you only have one servo wire to worry about when removing the wings, and whole process is alot less tedious! And I should know... I have the Skywalker EVE-2000, which has the whole wings disconnecting from the body along with the motors and ESCs on them. That is probably fine in the summer... but in the winter when it is cold and the foam has frozen and shrunk... I have to ask at least 2 people at the field to help me put the wings on and remove them from the plane after I am done flying! There is just so much carbon that needs to go into so much shrunken foam... it is close to impossible to do it alone! I am not saying it is a bad design... the wing connectors really help with the wiring... but I can also attest to the tedious task of re-soldering all these connectors because the factory had done a crappy job! Until I see otherwise... the MyTwinDream's and Clouds's way of doing it is better in my view!
So... wings aside... I also like the fact that this is designed so that the whole length of the fuselage can be accessed via multiple hatches, which in fact do not compromise the integrity and rigidity of the plane!
And speaking of hatches, there is one that is accessible only from the bottom. Interestingly enough the manual says this is the parachute hatch!! Honestly, I don't think this plane needs a parachute to land... given my experience that is!
A really nice little GPS module nest has been placed on top of that "parachute" hatch.
At the front of the plane there is a small piece of foam that is removable... right off the top of my head I can't think of what could fit there stock... but I do see great potential for some custom work... possibly some pan/tilt thing mounted there, and it could be good!
The fuselage parts of the wings are in two parts, and you need to glue them together. I suppose this was left that way with the idea to be able to do the wiring before assembly, but honestly the wiring channels are big enough to allow for easy wiring even when they are glued together.
Even the motor wiring channels are designed wide enough to be easy to wire the motors once the wing is glued together.
What I especially like are the ESC nests. Unlike the EVE-2000, where I had to cut openings in the foam to get to them once I glued the wings together, the Clouds has these designed so the ESCs are easy to access and replace if need be. I think these also allow for better ESC cooling, as the hatches that close these in have a large cooling hole right inthe centre.
Moving on... for the first time I didn't have to cut the servo beds to enlarge them in order to fit the 12 gram Coronas I usually use on these planes! I also like the size of those control horn beds. This will give more support to the control horns, which means that they will last longer in there and will not easily dig into the foam when under load.
And so we get to the bottom part of the fuselage.
The front compartment is free of any obstructions, so it could allow for use of multiple batteries, or to install a lot of gear in there. Actually a 6S 12000mAh battery does fit in there leaving lots of room for a mapping camera!
Those things on both sides of the compartment are wiring routes, which will definitely help improve the cleanliness of the wiring... at least initially before you have to re-do 100 things and really can't be bothered to put everything back in its place!
There is a special place for a mapping camera, and you only have to cut out a very thin layer of foam to make the opening. The size of it suggests it will fit a Sony A6000 or similar size camera with lens.
Right behind that is the compartment that I put the autopilot in, i.e. my central wiring hub, and behind that is the parachute compartment.
There is even a very small rear compartment at the end of the tail, though it doesn't have a hatch. I am really liking all these compartments and the way they are sectioned so you can easily separate electronics and keep things nice and organized.
Also, if you take a closer look at the sides of the bottom fuselage part at the rear, you will notice there are some plastic rods pre-installed. I guess these will add some additional strength to the fuselage in that area, though I don't see why they are necessary since the fuselage itself it quite bulky yet short, and probably will not twist during flight.
At the front part of the undesride of the bottom fuselage is covered with a plastic cover... or should I call it a landing shield, which will definitely protect the foam much better than fibre tape during landings, and will be lighter than fibreglass cloth and resign.
Continues in next post...
Arxangel's Avatar
... continued from previous post!
Moving on to the wing and tail joiners, I have to say I really like that design, because it is easy and quick to disassemble the parts and pack the plane away quite compactly if necessary! Same goes for assembly. One thing I would do at some point though, would be to replace the philips head bolts with hex head bolts.
I have to say that I like the scheme with 1 central spar and 1 smaller in each wing much easier to slide in and assemble, than what the EVE-2000 can offer with those long spars that have to go quite a ways in the wings... and makes it really hard to do in the cold!
The plastic on these parts where the bolt goes through has been thickened to make it more durable, which is not a bad design choice... though I would have made it even thicker!
The bottom side of the joiners has a hex shaped hole meant for the locknuts that come with the plane. It is always better to use locknuts on all things moving.
And speaking of bolts and nuts, you get a full set of them for the tail and the main wings. You also get a set of plastic ones for the top hatches, and a full set of control horns and push rods and all that sort of stuff... and guess what, there are even spares! That doesn't happen very often!
There is also a complete set of wood and plexiglass pieces, and nothing was missing!
WHAT I DON'T LIKE
Right... so the first problem I noticed was with some of the... not sure what they are called... fuselage assembly/alignment pimples for when you are joining the two fuselage halves together. Some of them look really weird and malformed, which means that not enough material was injected into the mould at the time this was made! I certainly hope this is not the case with all units! To be completely honest the material feels a bit softer and not as dense as the one on the EVE-2000, but it has been OK so far and I think it will be fine!
Anyone familiar with my Ranger review would know that I am a bit sensitive on the subject of hinges... and guess what - this plane has none! I can't call the foam hinge they have made a real hinge, beacause I am painfully aware of how easy those tear off mid flight and cause the plane to nose dive into the ground at over 120km/h! And while the Ranger has a tough plastic body that survives such a crash without any effort, a foam plane in a similar situation explodes on impact and destroys most of the electronics on board! I am not sure why it is so hard for manufacturers to put proper hinges on these planes! I am at least glad after 3 years of talks I finally made Volantex put hinges on the Ranger.
Now I need to bring your attention back to the plexiglass pieces! Not sure what happened there, but they were pretty badly burned! May be the laser used to cut them was too hot... or something else was wrong with it, but the edges were too melted and the protective foil on it was stuck to the plastic, I barely managed to remove it.
Another thing that I found interesting in the negative sense, is the tail mounts. I received two separate pieces that had to be glued to the fuselage, and as separate pieces that was not the easiest job in the world. Funny enough, the manual shows that part being a single piece, which would have been so much easier to glue on!
And last I do need to mention that there is a manual... but it is not very detailed! Building steps are show a few at a time, and at some point it could get confusing which parts come first and what should be the order of things! Looking at that manual seemed weird, so I didn't exactly follow it while putting the plane together.
THE BUILD
So lets get down to business!
First thing I did was to glue in the ESC hatch pieces that the crews go into to hold down the cover. Since this was the easiest thing to do it took about 30 secods for all 4!
Next one of the easy things to do first was the plywood battery plate. As usual the piece was not perfectly flat, so when I put it in with the glue, I put some weights on top of it to hold it down flat till the glue dried. Since I am again using the Moment Classic glue I used for the EVE-2000, I had to leave it overnight to dry well.
Next was the plywood structure that glues to both the top and bottom fuselage halves and also provides additional support for the spar. The manual does not show how to assemble it steb by stem, so make sure you pay very good attention to the drawing in it to see how the parts are oriented. When I assembled it I actually put it in the plane while the glue was drying so that it would stay in the proper shape and not get warped!
Next step was to actually glue it to the fuselage! If you take a look at the manual, it shows to glue it into the bottom half first, but I glued it into the top half first. I did it this way because I actually glued the wings pieces together before gluing the top and bottom halves together. I used some clamps to hold it down firmly in place while the glue dried. Make sure that when you glue this in you allign the spar openings well with the channel in the wings to avoid having issues when inserting the spar later on.
While waiting for the plywood piece's wood to dry, I glued in the plastic nuts for the bults that would be holding down the top hatches. Take a good look at the manual and where these nuts should be, because I didn't and consequently glued two of them in the wrong place, and later had to cut them out and glue them in the propper one.
Turns out 2 of the nuts actually go at the front and back of the main top hatch, not the sides, so after gluing them in the side supports I had to cut them out and re-glue them at the front and the back where they should have been in the first place.
Following the nuts, I glued the wings together. I did notice that the wings were pointing up a bit from the fuselage, so I inserted the spar in there while the glue was drying so that they can dry straight and not be deformed. I used the right amount of glue so the sapar was not glued in the wing permanently... although that may not a bad idea. I am actually keeping this inserted in there all the time. I did use tape around some of the edges to make sure the parts are well pressed into each other and will have a strong bond.
Now that the wings were done it was time to put the two fuselage halves together, the only problem was the warped tail section and the torn bit back there. In case some of you don't know this, you can straighten out warped foam by soaking it in hot water for about 30 seconds. Heat the water till just the point before boiling and remove it from the heat, then insert the piece to be recovered in it and hold it there for a bout 20-30 seconds, then take it out, repeat it if it needs more work. So... a quick hot bath and everything was back to original. I also used epoxy to glue the torn bit, because I didn't have 24 hours to wait for the Moment Classic glue to dry!
And last before gluing putting the fuselage together I glued in the tail skid piece. Make sure you insert this in there as far as it will go, because it would serve as a nice support when gluing the fuselage and will prevent the tail from warping during the drying process.
And so we finally come to the fuselage assembly part. I tried to use the right amount of glue because the Moment Classic makes the foam a bit soft while drying, and if you use too much it will almost melt and warp and will look ugly when it dries. Around the centre of the fuselage I had to put some weights in some key areas to make the halves fit together better.
At other places, like the tail and the nose of the plane, I used tape to hold the pieces fastened together, but since I know the glue softens the foam, I made sure not to tighten the tape too much so it wouldn't warp the foam.
Next I glued the wing joiners. A good amount of glue and some tape to hold it securely was all that was needed.
Although the outer wing pieces and the tail pieces came with their plastic bits already glued on, I actually removed them and glued them back on with my glue, and by putting glue in more areas so that there would be a stronger bond! And rightly so, since I was able to remove those pieces without too much effort because there was glue only on the front part of the plastic, not the sides. Now after I re-glued them it seems impossible to move them even a little!
Next were the tail joiners. Sadly the fuselage parts were not a perfect fit at the back because of that transport damage. The joiner beds were not perfectly aligned between the top and bottom of the fuselage.
Despite that I was able to glue them one by one, but using 5 mins epoxy, because I actually held each piece for 5 mins myself while the epoxy would set. Because there were two separate pieces rather than one whole piece, it would have been very difficult to tape these parts in a way that would securely hold them in place for 24 hours while the Moment Classic had a chance to dry. The epoxy was the perfect adhesive in this instance.
I did have to trim a bit of plastic from one of the pieces to make them fit together, because they were overlapping.
The tail and wing assembly bolts are included in the kit. I glued the locknuts in their respective beds for all pieces.
And now we get to the part I hate the most when building a plane - hinges!!!!! Seriously people... start putting proper hinges on these planes in the factory!
Complaining aside, first I use a sharpie to mark the locations of the hinges on the foam hinge, and then I use a hobby knife to cut the controll surface off. I then cut slits in the foam where the markings are, put in some CA glue and slide in the pre-cut hinges. The glue hardens almost immediately, so if you are going to follow my example make sure you act quickly!
Once I am done inserting all of the hinges in to the control surface, I put glue in all of the slits on the wing and insert all of the hinges at the same time, thus putting the two pieces of foam together. Make sure you do this operation quickly as CA sets immediately when its thin, or use a slower setting glue so you would have time to make adjustments. Once its all done these CA hinges are solid as a rock! And a good thing is that there is no gap between the wing and the control surface! I do this for all control surfaces.
Mar 05, 2017, 02:35 PM
Arxangel's Avatar
Along with the hinges I also installed the control horns and the push rods. First you have to screw in one of the balls into the control horn, because otherwise that tast becomes really difficult once you've mounted the horn on the foam. The screw needs to be inserted into the ball from the countersunk side. The ball's flat side should be towards the control horn.
Now you mount the horn in the foam. I put a little glue under it just to make sure it will stay there for good.
Use the other screws and the smaller plastic plates on the opposite side of the control surface and screw the control horn securely in place. I also plut a bit of glue on this side as well.
Next I installed the servos. For the tail it is a bit easier, because there are no long wires to route. For the first time in a while I didn't have to cut out foam anywhere to make my servos fit! Push rods are quite easy to install after the servo is in - insert one end into the servo horn, connect the servo to a servo tester and centre it, then centre by hand the control surface and see how much you need to adjust the ball joiner at the end of the push rod. Screw it in or out in order to get a centred control surface. I used double sided tape and fibre tape to install the servo.
On the wings you will actually have to route the servo wire through the wing first, before you can install the servo. I used a 15cm servo extension, and put a servo extension lock on it, so it wouldn't disconnect when assembling and disassembling the wings. The wire chanels is nice and wide, so routing the wire should be pretty easy.
Next I thought it was time to install the motors and ESCs. For this built I got a pair of Racerstar 3508 580Kv motors. I saw then when they came out and thought the specs are pretty nice, as well as the price, and the Kv would be perfect for a 10" prop on 6S. Only problem was that as with the EVE-2000, this plane's motor mounts were designed for thinner motors... something like 2814 or 2820, which meant that it will be a bit tightening the screws in! Also, the motors came without any mounting hardware, but here is where I got lucky for once - when I received the EVE-2000 and installed the MultiStar 3508 640Kv on it with the printed mounts, I also had a few mounts cut out of aluminum but never got around to installing them on the Skywalker since the printed ones worked out so well! Well guess what - these aluminum cross mounts fit the mounting holes on the wing plastic mount perfectly!
But because the motors is wider than it was meant to be used on this plane, I had to insert the screws before I installed the motor, otherwise they can't be inserted into the holes because the base of the motor overlaps the screw holes a bit.
A short while and a bit of an effort later, the motors were installed on the plane and felt solid as a rock on those mounts!
Only downside was that motor base got chipped a bit where the screw heads were, because the screwdriver would rub against them while tightening the screws.
Next were the ESCs. I used the same HobbyWing Platinum Pro 40A ESCs as on the EVE-2000! These ESCs are a bit expensive, but they are solid and I would say well worth the investment, especially if you are going to be hauling expensive gear on board.
The wires were a tad on the short side of things, but luckily well placed access openings on the wing allowed the ESC and motor wires to be connected without too much trouble, and actually eliminated the need for excess wires.
Once all of the ESC wires were routed I screwed on the lids and was done with that bit.
On the inside of the fuselage I connected a power harness to both ESCs.
And then installed the power module... which sadly has refused to work properly and would not give me voltage or current sensing!
After this I installed the GPS unit in its designated location and it looks rather good sitting in there all flush with the fuselage!
Next I routed the extension cables from the ailerons to the flight controller location.
Making sure to take full advantage of the wiring channels in the main compartment.
Next I mounted the tail pieces.
Funny enough those bolts are about 5mm longer than they need to be! Since I will be replacing them with hex bolts, I may just get the correct size... you know... every gram counts!
Following the tail was the receiver. Since I wanted maximum range I decided to mount the antennas as high up as I can, and as optimally placed on the fuselage as I can, without mounting the L9R receiver outside of the fuselage. I printed an antenna holder that would hold both antennas vertically, but rotated at 90 degrees one against the other. Glued it to the flight controller compartment hatch, which sits about midway on the fuselage, and used a small piece of strong double sided tape to attach the receiver on the inside, under the antenna mount.
Since I am using a Micro APM for this build, and it only supports CPPM, I had to use an FrSky SBUS to CPPM converter.
I am not expert, but I think this is a pretty optimal position for the antennas!
Next I remembered that there was a plastic cover for the underside, so I decided to mount that back on. This will give the plane some real nice protection during landings, and I really wish more manufacturers will include parts like this one... definitely the lightest option to protect the foam during belly landings.
I had to make some cutouts in the plastic to fit over these plywood rings sticking out of the fuselage. There are two on the bottom and two on the top and I assume these for the parachute, although they turned out to be quite easy to break so I wouldn't really tie a parachute to those! May be if they were made out of carbon...
So, back to the electronics! The parachute compartment actually became the TeleFly OSD compartment. I am not using this board as an OSD, but rather it is listening to the GPS and encoding the coordinates into the video stream. On the ground my antenna tracker is decoding them and tracking the plane quite accurately!
Next I installed the Micro APM autopilot. I used a soft double sided 3M pad to mount it. Since it would have been quite difficult to plug all the connectors into the board after I mounted it, I had to have all of the wiring done before that, so that I can plug it in before I taped it down.
Next I made a really long wire to power the Vtx, which I chose to put right at the back of the plane. I printed a mount and glued it in an opening on the tail, right between the tail fins, as far away from interference as possible!
And here is the little bugger... at only 3 grams the VTX03 has some impressive performance! A friend of mine was able to receive the video from the plane up to 6kms out only with a CP antenna on his goggles!
Stock it comes with a linear antenna, but because I don't yet use a directional linear antenna for the video on the ground, I had to change it for a CP antenna. Thankfully the Vtx comes with IPEX connector for the antenna, so I was able to easily replace the stock antenna with an FrSky antenna extension cable that also converts the IPEX connector to an SMA one, making it very easy to mount a bigger antenna on there.
The extension also allowed me to print a talled mount so I can get the video antenna as high as possible for optimal results.
It is entirely possible that I may have made this mount a bit thin in my desire to reduce the drag it will introduce... I may design an optimized version later on and replace it.
Next I finalized the video system and servo wiring and power. I am really glad this plane provides so many wiring channels and electronic mounting spots so that I can do sort of a clean install!
Right at the bottom there in the camera lens opening you can see the micro telemetry unit. Just above that is the Micro OSD that came with the AP set. Above that is a UBEC providing 5v to the RunCam, and above that is the LC filter that filters the power for the whole video system! And on the right of it is the step-down regulator that provides 5v to the Vtx at the back of the plane, and the Micro OSD.
Mar 05, 2017, 02:36 PM
Arxangel's Avatar
The step-down mounted on the wooden brace drops the voltage down from 25v to 12v so it can safely go through the LC filter, since it is only rated up to 16v.
This UBEC powers only the servos, and nothing else. It does not go through an LC filter, because the servos don't really care all that much!
So, with that sorted, the built was pretty much complete. I test fitted some batteries and found out that I can fit a 6S 6600mAh pack easily, but the plane will also easily take a 6S 12000mAh pack. Since I want to go as light as possible on this however, I will be using the 6S 6600mAh pack. And here is where the Clouds has another advantage over the EVE-2000 - the EVE's long body meant that I was not able to balance the plane with anything less than a 6S 12000mAh battery, the sub 1 meter body of the Clouds, however, allows me to balance the plane perfectly with the 6S 6600mAh pack, which will make it much lighter and will be very beneficial for performance.
And finally, before flight every plane needs its wings, but unlike the EVE-2000, these are pretty easy to install! However, since they don't come with connectors like on the Skywalker, when I connect the servo cable I pull it from inside the fuselage, so it doesn't get wrinkled when I connect the wing.
A quick bolt tightening later the wings are mounted and the plane is pretty much ready for flight!
I have to say though, I really like how these turned out, and what's better as of this moment I can't say I can feel them increasing the airframe's drag too much!
And now I have to appologise for not having photos of the Clouds in its original form when I finished the build, but I was so enthusiastic to go flying that I forgot to take some shots. So here are some shots from the second day of flights with the camera pan/tilt mount installed, and a new OSD... because the old one burned out just before the maiden... as you will learn in the video!
The props are APC Style 10x7" CW and CCW from HobbyKing. Even though they are not original APC props, once you balance them with a good balancer they are pretty good, and provide the plane with lots of thrust, and I haven't noticed any prop stall during take off either... the power is quite impressive. Both motors combined give over 3kgs of thrust, while the plane weights around 2600 grams with the pan/tilt and I have tested it... and it can go vertical if necessary... and with authority!
THE VERDICT
Right... so I am going to ignore the arrival state of this plane because it is not really the manufacturer's fault for this... and I will also make a mental note never to order planes and other large items via regular economy shipping! I am pretty sure that if I have to order it again and I pay for the expedited shipping it will arrive in a timely manner, and it will not be squashed flat!
As for the plane itself... apart from a few small quirks (the melted ESC covers, and the fact the wooden thing in the middle of the plane should have been at least made out of glass fibre, if not carbon) the plane has been so well designed that I really did not find a reason to modify/fix anything on it to make it fly, or to make it safer. Actually I do have one suggestion for X-UAV - to make the wing and tail plastic pieces a bit thicker... and possibly add an option for fixed connectors, will make mounting those so much easier since it is only servos that need to be connected! Just to be safe I do put fibre tape where the tail fins join the fuselage and also where the wings join the fuselage when I connect them, but I've flown without the tape, and its been fine. So build-wise this plane has been stellar, and I can definitely tell that it has been definitely designed with FPV and mapping in mind, and everything is designed very smart and convenient to make for a clean wiring job and easy placement of electronics!
As far as flight performance is concerned... oh boy... it is simply put PERFECT! Now, it will depend on the configuration and equipment you choose, and ultimately on your AUW, but in my case the goal was to make the plane as light as possible without sacrificing functionality or performance, and I think I have achieved that, and in no small part thanks to the smart design of the Clouds, which allowed for this to happen easily! The plane is light, very nimble in the air, and it could easily be flown like a 3D aerobatics plane at my AUW of around 2600 grams. Stall is non-existent, especially in the AP stabilized modes, which will make for an amazing slow flying FPV platform and clouds chaser. Thrust is in abundance, hence take offs are trouble free and quick, and once in the air it can cruise around comfortably at below 50% throttle, which on a rough calculation could give me close to 1 hour of flight time on the 6S 6600mAh pack I have chosen!
Now, you have to keep in mind that if you choose different motors, different voltages, batteries, equipment... all of the above will change, but based on what I've seen so far I am pretty sure up to a point this jewel of a plane with be a pretty good performer and will serve a multitude of tasks without so much as a single issue!
So, do I like this plane and would I recommend it... DEFINITELY!
Mar 05, 2017, 02:38 PM
Arxangel's Avatar
UPDATE INDEX
UPDATE 1: Servo and tail reinforcements, new distance record, antenna relocation for better results!
UPDATE 2: New servo mounts, new battery, new gimbal.
UPDATE 3: OSD troubles and a new LiIon battery.
UPDATE 4: FireFly 8S in the clouds
UPDATE 5: FrSky R9M module and R9 receiver testing
UPDATE 6: AKK X2 Ultimate Vtx 1200mW long range test
UPDATE 7: new motors, larger props, retractable video antenna mount
Mar 05, 2017, 02:39 PM
Arxangel's Avatar
Reserved..
Mar 05, 2017, 06:19 PM
stanordave's Avatar
Arxangel
glad the maiden went well!
Amazing you could build it after having the box pummeled!
Mar 05, 2017, 11:41 PM
Arxangel's Avatar
Originally Posted by stanordave
Arxangel
Yeah, I felt the luckiest guy on earth at that moment, when I opened the box and it turned out the plane has barely suffered! Weird!
Mar 06, 2017, 12:18 AM
Hmerly's Avatar
My Clouds had a box just like yours. There was a big gaping hole, like someone had kicked it. I thought it was for sure going to be damaged, but fortunately, not a single piece of foam was torn. Just some small dents and the tail was bent like yours. Lucky I suppose. X-Uav needs to box these up better
Latest blog entry: My fixed wings
Mar 06, 2017, 03:42 AM
Awesome write-up, Arxangel! Your reviews are the best out there!
Have you had the MFD?
Actually, It'd be nice if you could make some kind of comparison thread - where you would compare the planes of the same kind/purpose - like the Clouds VS the Eve VS the MTD and so on...
Mar 06, 2017, 03:53 AM
Arxangel's Avatar
We certainly are lucky! Will let X-UAV know that they need to do something about that! I guess adding those air filled pockets in the boxes isn't going to weight them down too much!
Thanks!
A week ago when I was considering whether to get the new MFD Nimbus when it is released, I though it would be real nice to get it, and afterwards make a comparison of the three planes - the EVE-2000, the Clouds and the Nimbus! So no worries, this will be coming as soon as I get my hands on that magical broomstick!
Mar 06, 2017, 03:54 AM
Yeah, the Nimbus - I noticed it, but couldn't find any info on the web - the only review was by AliShanMao, but it wasnt very enjoyable or comprehensive..
Mar 06, 2017, 07:13 AM
Arxangel's Avatar
Information will come in due time! Charles was developing it in secret... never could make him share a photo of the plane!
Mar 06, 2017, 08:51 AM
Have you had the MyTwinDream?
As I'm about to pull a plug on 1,8m twin motor plane, I'm interested in hearing from someone who has had both of these.
Mar 06, 2017, 09:24 AM
USA: LakeGeorge, New York
Counter-Rotation props?
6s 6600mah seems like the sweet spot for CG.
Latest blog entry: My FAVORITE FPV CockPits'!!!!
